Ticking is immediately behind the speedo/tachometer just a steady tick tick tick, doesnt increase on speed and still ticking when in park or stopped, with engine running
SOURCE: my gas, tachometer and speedometer are not working
check for blown fuse for gauges,light is a pro blem code,thatll have to be scanned to point at problem area.
SOURCE: Rough idle engine ticking
check for a lose spark plug lead or cracked elecrod insulation on spark plug
SOURCE: engine knocking, valve ticking loud in engine, when idle or drivi
Make sure the oil level is good, and have the oil pressure check by a garage or someone who can, by using a external gauge to see what the actual oil press is. Low oil pressure will give you the ticking, start there.
SOURCE: 06 honda accord won't start
correct, may be a bad starter, start there. test for power at small wire at rear of starter if theres power when key is held in crank position then replace the starter also make sure battery connectoins are clean and thight, good luck hope this helps.
SOURCE: 2006 BMW 3251 loud ticking sounds from engine
this is a very common issue with any of the bmws with n52 and n52k engine,as long as oil level is ok and is being changed regularly than than a "blleding proceedure" may solve this problem, when the engine has been running long enough that it is hot run the engine at idle to 4500 rpm for 10 to 12 min to start, if is still present after this attempt again.It has been said that this could take up to 30 min at longest.The reason for the ticking noise is a very tiny air gap in the hva and or lifters, try this and if does not work than the lifters should be replaced, although this noise doesnt really hinder the performance it does take away from driving such a nice car and having a loud noise come from the engine, good luck
