I have a Dometic RM 2607 fridge in my travel trailer. I am using gas right now and the freezer is getting cold but ht efridge isn't. I dont see any knob to circulate air. Any ideas?
It is possible that your cooling unit is failing due to a blockage. The solution used to cool starts at the top of the fridge and works its way to the bottom. If there is a blockage in the cooling unit it could produce the symptom you have explained.
G'day I have a Dometic RM4605,184LT FRIDGE, AES what setting on gas would you have the fridge set. Settings are between 1 to 5 for max cold in the fridge I did run the fridge for two hours on number 4 setting but it was still 10 degrees in the fridge and -0 in the freezer.
Thanks
Dometic refrigerator lp gas electronic Model # 3662. Same problem. gas works fine and power is there. as lights on top of frig work.... not even trying to be cold. Same suggestions as 2652? How to bypass thermostat? and will try relay after... thanks.. Bob in Canada<input id="gwProxy" type="hidden" /><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden" /><!-- from fixya rte -->
Check first if the distance of the fridge to the wall is enough or has similar air circulation as with its previous location. Inspect the coil at the back of the freezer for dirt or ice build up. See if cleaning the unit including the back of the freezer will help.
