Televison & Video Logo
Question about Sony Televison & Video
KV-32FS13, Unable to change channels.
I have a 32'' Sony Trinitron. Model KV-32FS13
None of the buttons on the television will work--only the power button; and the television will not recognize the remote. I unpluged the T.V. for a period of time and still will not work. However, when I turn it back on, the standbye light flashes 11 times before it comes back on. For some reason, the favorites box likes to appear and ocassionally dissappear and come back on. I'm pretty handy; so, I would appreciate anyone's help.
Thanks
Anonymous
    Problem Solver:
I found online that these televisions have a problem with the button panels shorting out. I pressed all the button on the television; when I would press the buttons, the favorites screen would appear. I'd press it again and it would dissappear. This would work for all the buttons except for the menu and the button below it on the bottom of the T.V. screen. I took off the back of the television and looked at the circuit boards. I removed the wire connector fot the top button panel, from the main circuit board, and op checked to see if the television would change channels with the remote. NOPE. So, my only other option was to pull off the little rectangular buttons from the circuit board for the bottom of the T.V. If it didn't work I was going to throw the T.V. away anyway. I know it sounds crazy, but it worked. I don't know how much it would cost to have someone troubleshoot and replace the pieces, but I'm not worried about it. I can still change the channels with the top buttons and adjust menu options with the remote now. The buttons that didn't work, the menu and *, the piece was corroded. However, just breaking this one off didn't work; I had to break off the piece for the up and down arrows. I'm not a specialist, but it worked for me.
Posted on Jul 11, 2009
Anonymous
I had the same problem with none of the front panel buttons except the power button working. So following Jess1's lead, I checked out the menu and navigation buttons at the front of the A-PC board and found that there was considerable corrosion build up (we have a little one who attempted to clean the TV with a little too much windex). Rather than ripping them out, I used a small pocket knife to remove as much of the corrosion as possible and put everything back together and problem solved.
Posted on Jul 25, 2009
Sony Wega KV-XF21M83 21" Color TV red LED flashing two times
mt sony trinitron power light is blinking from green to red twise and then pause for 3 seconds and then blinks again from green to red
Kv 32fs13 turns on with no video and light blinks 4 times
check d611 135v bridge rectifier for shorts.
location d611 on the (a) pcb board.
it is a comen problem for this unit.
regards,
daniel
1helpful
Sony kv-32fs13 chirps and flashes
Hello 0279737,
This problem is caused by a shorted Horizontal Output Transistor. I would suggest that you have this TV checked by a qualified TV technician. This type of problem requires dealing with dangerous voltages, and repair should only be attempted by a trained technician.
I hope this helps
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
No Sound Issues
Hello!
Try the audio out. Run the audio to a receiver to see if the audio is there. If it is, then I'd leave it hooked up to the receiver and save yourself some money. If there is not any low level audio out then I'd fix the set. The only Sony set I've ever seen that was not worth fixing was a 32" model from the early 1990's that had bad picture tubes after only 5 years. I am a Sony factory trained tech. Good Luck!
barneyluc
Channel changing randomly
the channel switch button had a contact to each other... or clean it...
Red light blinking
thear two ic that have gone bad this set need to go to a repear shop for this work to be done.
Sony Trinitron KV-32FS13 will not power on
The set should have a blinking standby light when you attempt to turn it on. Please update this with the count and that should give me enough to propvide some details.
Dan
1helpful
2answers
Sony trinitron KV-32FS13
The HOT transistor is shutting it down. (horizontal output transistor)
it cost about 8.00 for the parts and 100 for the labor.
you will require help from a tech.
Top Sony Televison & Video Experts
Jaime Hernandez
Nasir Muhammad
Nasir Muhammad
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
