I have a Jenn Air Down draft slide-in range. When we press the button to turn on the fan, a flashing "Warming Drawer" light comes turned with "High" and "Low" options also shown. The fan kicks on if we press either option but the flashing light continues. This has never happened until now (almost 3 years of regular use). What does this indicate?
SOURCE: Oven light won't turn off
It sounds to me like the switch that operates the light is malfunctioning. You're taking the right steps by pressing the switch by hand. Since that didn't work, either that switch is not working or there is another switch that is intended to keep the light on while the door is closed. You can look at that one too. The last thing to consider is if the light is relay controlled, the relay might be stuck closed and applying power to the light all the time.
SOURCE: Jenn Air Range SVD48600W (Circa 1998?)
Why are the oven indicator lights flashing?
Answer:
When power is first supplied to the appliance, a flashing time will appear on the display.
If a flashing time appears at any other time, a power failure has occurred. Press Cancel, and reset the clock if needed.
When the oven is not in use, the display shows the time of day.
If the indicator lights keep flashing after you have tried to reset the controls, then you may need to contact service person.
This is from the Jenn-Air website.
SOURCE: jenn-air jes9800AAB keeps buzzzing, front function panel flashes on and off
Your control panel is getting ready to quit. Mine did the same thing, I ignored it and now nothing on the touch panel works. About $150.00 for the part.
SOURCE: Jenn-Air electric range
my jen-Air has a problem with it continuing to beep. Ive tried to get it to stop by pushing all the buttons. When I pust the off/cancel button it just keeps beeping. Tried the stop timer button and same thing. When I turn on either the bake or convection bake button it automatically just shuts off by itself. It is approx 10-13 years old. HELP, or please tell me to get a new one.
SOURCE: Replacing Jenn-air down draft with new unit
Since Jenn-Air has been acquired by Whirlpool, there have been an explosion of problems with their appliances.
Please research your intended purchase before deciding on a replacement:
Jenn-Air info
Considering the array of early failures everyone seems to be having with appliances (US made and foreign) bought in the last few years, I couldn't even recommend a manufacturer any more.
