Question about Boating
1990 mercury 150 outboard motor
When I push the lever forward it does not make the boat go faster but while in nuteral i can make the idle go faster but not while it is in gear. also the buzer just started going off with short blasts. I know that that means oil though.
Posted by richard_s768 on
Anonymous
    Scholar:
  • 155 Answers
Sound like the throttle control (lever) is at fault not engaging the throttle in FWD position, but ok when in neutral, check the release button insure it pops out to lock the throttle...hope this helps...GL
Posted on Jul 06, 2009
Mercury 150hp Optimax outboard
many mercury motors use a rubber mounted prop on the shaft which is a sacrificial idea to prevent gear box damage and prop damage in with under water objects
what you suggests indicates that at certain load situations that rubber has failed and allowing the shaft to turn but is not driving the prop as required
It is driving just enough to give you steerage to get home
Sep 01, 2018 | Boating
How much does a 1996 Mercury outboard motor 115 hp weigh
FourStroke 150 hp - Mercury Marine
https://www.mercurymarine.com/en/ca/engines/outboard/fourstroke/75-150-hp/Mercury FourStroke outboard motors are incredibly powerful and efficient, and they feature a wide range of applications. Crafted for less weight and high displacement, they generate abundant torque and immediate power. ... 150 115 90 75. HP / kW‎: ‎150 / 110
Engine type‎: ‎8-valve single overhead cam ...
Dry weight *Lightest model available‎: ‎455 lbs / .
Jun 13, 2018 | Mercury Boating
1995 mercury 150 horse runs great idols great but very slow .when put in reverse quits seems like to slow idol . what screw do i turn for fast idol
Seems like your are describing a outboard motor. If so, the Boat section of Fixya may have more experts that you need. You would want to avoid turning any screws on the carburetor body. The externals on the linkage have some adjustments like throttle stops.
The linkage on boat shift mechanisms are tempermental. They usually combine 2 functions on 1 control lever. They are synchronized that when the transmission shifts from neutral to forward and neutral to reverse the idle speed is low. This keeps the gears from grinding and takes the shock out of the shifting process.
Another thing different than on a car engine is the effect of the propeller on engine rpm. You can change the "in gear"
rpm for both directions by changing prop size and/or pitch.
This also means you can over-rev the engine by having the wrong prop on the boat. There are engine rpm "stops" for the high end too, but some just rely on using the correct prop. As what you may be experiencing with a "stall" can be brought on by
A word of caution. The inboard/outboard engines can have the same problem as outboard engines. The shift levers are synchronized with a pivot system and adjusting the throttle can interfere with the shifting.
You may be able to view youtube videos by searching for these topics.
Mar 01, 2018 | Mercury Cars & Trucks
Is there any way to switch anything around in the control box in an outboard motor to make it pull instead of push the throttle lever on the side of the motor to make the motor accelerate?
Good Afternoon Ronnie Barnhouse,
Most Control Boxes Are Able To Be Switched,
Mercury Control Boxes Require A Lever To Be Purchased To Turn It Into Push Or Pull For Throttle. If You Would Like Specific Instructions Please Let Me Know The Type Of Control Box Or Post Photo.
Hope This Helps
Regards
Gordy
Jul 06, 2015 | Light Outboard Motor Boat Bass Fishing...
1971 MERCURY OUTBOARD ENGINE REVS WHEN PUT IN REVERSE
is that on the remote control lever ? if yes then adjust the throttle cable to push against the throttle stop on the engine end so when you select gears it only moves when you go to accelerate ! mite need to adjust the carb pickup to align with mark on main lever that moves the timing rod to the trigger under the flywheel !
Sep 30, 2011 | Light Outboard Motor Boat Bass Fishing...
15 horse mercury outboard
Clogged jets in the carb...clean out carb or rebuild carb.
Jul 28, 2009 | Boating
1999 Mercury Mariner 9.9hp outboard motor
should be on the side with a lever but could you give me more info please
Jun 07, 2009 | Boating
It will not go into reverse but will go into forward. what should i do first? 1986 mercury outboard
You did not tell us if you have a small outboard or if you have remote shift controls. If you do have remote shift controls you can try reversing the cable ends if it is a 2 cable system or disconnect the cable at the engine. By disconnecting the cable at the engine you isolate the problem to the motor. Then you can grab the shift lever manually at the motor and see if it will now go into reverse. Some remote levers lock out reverse if the choke is engaged or if you are new to this boat there may be a button to push on the throttle to allow reverse to engage.
May 17, 2009 | Boating
Boating Logo
273 people viewed this question
Top Boating Experts
ray gallant
Andrew Taylor
Andrew Taylor
Bill Boyd
Are you a Boating Expert? Answer questions, earn points and help others
