2003 Kia Spectra Logo
C
Chris Ramirez Posted on Dec 06, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Im trying to install my pioneer navtraffic d3 cd player, but it keeps asking me to insert correct disc. Can i download and burn disc, or is there other option to get it to work.
Randy Ohler
Level 3:
  • Kia Master 14,585 Answers
  • Posted on Dec 06, 2014
Randy Ohler
Kia Master
Level 3:
Answers
14585
Questions
8
Helped
3945951
Points
39683
If you bought it off some one, Ask them for the disk. Look online fro the download for you cd player, the other option.
Disc player not working 2014 grand cherokss jeep
Replace the stereo in the Jeep.
Aftermarket or factory your choice.
There is no way to self resolve this problem...
And any junk yard stereo you buy will need an activation code. Just buy a good Pioneer or Kenwood stereo and install it. Problem solved. No more BS
1helpful
My radio on my 2001 accent wont play cds it says error code 6, does anyone know the security code?
Hi there:
From Hyundai Owners Manual: Er6 - DISC ERROR - CHECK IF THE DISC IS INSERTED CORRECTLY IN THE CD PLAYER.
MAKE SURE THE DISC IS NOT SCRATCHED OR DAMAGED.
Error 6 means your laser isn't reading disc... needs replaced pick up laser. I would try first to insert a clean up CD and test your CD Player with an original CD, if the problem persist, you have to go to fix it to a specialist.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
My 2006 trailblazer cd player keeps saying inializing. It won't allow me to eject the cd or put one in. It just keeps saying inializing.
I had the same problem with my cd player. Are you using burned disc in the cd player? I had to bring mine in and have a new radio installed good thing it was still under warranty at the time. I have not have the problem since.
3helpful
When i try cd it keeps writing error.and reject every cd plates i insert.it was playing normal 2days ago.pls what do i do when error notice appear.the car is honda 2003 model coupe.thanx
Unfortunately 90% of the time when you get error codes from the CD player/changer it means that there is a mechanical failure in the CD player/changer unit itself and it usually requires CD player/changer rebuild or replacement...
First make sure you have entered the correct anti-theft code. If battery power has been disconnected recently than the stereo display will read CODE if the incorrect anti-theft code is entered the display will read ERR1 thru ERR3. If this is the case you'll have to get the correct anti-theft code. Note; If you enter the incorrect code three times the stereo locks up. Disconnect the battery for more than 30 seconds and then retry.
FYI;Never use adhesive labels or protective disc covers on recordable CD's. Recordable CD's are actually thicker than pre-recorded CD's. Automotive players and changers use rollers to draw the disc into the unit. The added thickness of an adhesive label or protective disc cover may cause the disc to jam. Also CD players and changers are exposed to high temperatures inside the vehicle. High temp will cause the labels adhesive to soften which may cause the labels edges to curl or cause it to bubble. Either one may cause the disc to jam. If the player can not be disassembled and have the discs removed successfully than it will have to be replaced. -hope this helps.
1helpful
Radio problem check cd keeps showing even when no cd is inside
Sorry bud, replace the cd player.... it's probably worn out. Check out the JVC, Sony, Pioneer and Alpine units for quality at affordable prices. HarmanKardon is better - except on your wallet :P
MINI: Trying to eject non-existent CD
I have only seen this problem once and the only fix was to replace the cd player. I would suggest to get an aftermarket cd player from electronics store and have them install it. The factory option is over 700 installed. sorry
1helpful
2answers
Cd player
Try turning your cd disc over, it may be installed upside down!
Fix Error code 6 on CD player for 2003 Tiburon GT
From Tiburon owners manual: Er6 - DISC ERROR - CHECK IF THE DISC IS INSERTED CORRECTLY IN THE CD PLAYER.
2answers
Eer cd problems
Some recordable compact disc media, such as CD-R and CD-RW, may not comply with the standard CD format used in automotive CD players. When these CD's are used, customers may encounter error messages, skipping, or delaminating of the labels, which can cause an eject failure. It is important to question whether these kinds of CD media are being used. When customers encounter these symptoms, check the system with a known playable CD. Explain that the media may not be compatible with some automotive CD players. Replacing or exchanging the CD player will not address these issues.
Top Kia Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Kia Expert? Answer questions, earn points and help others
