Icon F701WL 7 in. Car Monitor Logo
Anonymous Posted on Jul 06, 2009
No sound for Icon TV (DVD Player)
When I purchased the car the dealer pushed "5" on the radio presets and it played. When I do this, I still hear the radio.
Anonymous
Level 2:
  • Expert 53 Answers
  • Posted on Jul 14, 2009
Anonymous
Expert
Level 2:
Answers
53
Questions
0
Helped
27015
Points
157
Try to look for a switch under the dash it should be a toggle switch , what happens is that the switch turns on the Fm modulater that transmitts the sound of the Dvd to the station. If that is not turn then you will hear the dvd player. If you turn the switch on then you will hear the radio become more static, that means that the Fm modulator is working
I just bought the RCA CD/DVD home theater system RTD206. I cant figure out how to change the radio channels. Also cant figure out how to change the cd disk tracks. Does this system have a remote. Or do...
The system does have a remote (at least it should come with one if purchased new), and you need it to control pretty much everything. Here's what the manual says about the radio tuner (you can find the whole manual here) :
Manual Tuning
1. Connect the FM aerial and the AM loop antenna at the back of the unit. Rotate the AM loop for
better reception.
2. Press TUNER to enter TUNER mode and toggle between FM and AM.
3. When the FM station broadcasts Stereo sound, ST is displayed.
4. Tune a station by pressing repeatedly the TUNER+/- buttons until the desired station is found.
Alternatively, you can press and hold the same buttons down for about one second to activate
the automatic search function. In this mode the player will automatically tune frequencies until
it finds a station.
5. Repeat step 4 to tune to another radio station.
Storing radio stations
The player can store up to 30 radio stations in its memory. You can enter every single radio station
yourself or the player can store all available radio stations automatically in ascending order.
Automatic preset programming
1. Press TUNER to enter the Tuner mode.
2. Press and hold TUNER down for 3 seconds to start automatic preset programming.
Note: A weak signal can affect the "Automatic preset programming" function's efficiency. Adjust the aerial for better
reception and a more efficient search.
3. Radio frequencies will be browsed and radio stations stored automaitcally. When all the available
radio stations are stored or all 30 memory locations are full, the auto preset programming
function will stop.
Manual preset
1. Tune to a radio station (see "Manual tuning" for details).
2. Press MEMORY once to enter flashing Preset Loaction number.
3. While the Preset Location number is still flashing, input your desired preset number (1-30) using
the numeric buttons or press the CH+/- buttons, then press MEMORY to store it.
Retrieving preset stations
2. Press CH+/- to search up or down for the preset stations or directly press the numeric buttons.
As you see, you really need that remote. The same is true for disc play. While there are front panel buttons for play/stop, disc skip, and drawer open/close, you don't have any other control without the remote. Without the remote control you'll find this system won't do too much, unfortunately. If you bought this new, check the packing material before you throw it away to make sure the remote's not still somewhere in the box. They often come tucked into slots on the foam inserts.
Also, when you hook the unit to a TV, it's just using the TV as a video display device. The TV has nothing to do with any of the system's other functions.
I hope you have luck locating the remote! Thanks for using Fixya.
1helpful
Mitsubishi Lancer 2004 Radio Code Not Working
Use the first four radio station preset buttons to enter the code.
1: Push radio preset#1 until first digit of your code appears.
2: Push radio preset#2 until second digit of your code appears.
3: Push radio preset#3 until third digit of your code appears.
4: Push radio preset#4 until fourth digit of your code appears.
5: Push either tape or cd button.
What to do if your radio says OFF instead of CODE
(Courtesy of mittech)
If your radio says OFF it means you entered the wrong radio code three times. To get it to say CODE again do the following.
1:Turn the key to on or accessory.
2:Push the power button so that the radio display says OFF.
3:Let the car sit for 1 hour.
4:The radio display will go blank.
5:Turn the radio on and it will say CODE again.
2005 town and country mini van w/ farenheit dvd player
Some dealers installed a modulator for the radio; look under your driver's side dash to see if there is a small on/off toggle switch. If there is, flip it 'on', tune the radio to 89.1 and you should get audio.
If they haven't installed this, no problem. You can buy a modulator from most electronic stores that is used to play MP3 players through the car stereo; instead of an MP3 player, simply plug the cable into the headphone jack of your DVD player.
1helpful
2answers
Car stereo preset radio stations.
Manuallly set to the station you want,then pick a preset button & hold down until you hear a beep or 4 about 5 secs
2helpful
Dvd player
If you have a factory DVD player, then while the DVD player is on, press your radio preset numbers' 2 and 4 simultaneously. Then to listen to the CD or radio just press whichever button you want to listen to. You should hear sound out of your front speakers only, and won't interrupt the headphones. Good luck.
1helpful
2answers
Car DVD player will only play sound through wireless headphones, not through speakers
We have a GMC Envoy which also does not allow us to play the sound from the dvd player through the car's speakers. Although we purchased the vehicle new with the dvd player already installed, it was installed by the dealer, making it after-market. I assume those that were installed in the factory work differently. Maybe this is the case with your's as well. Good luck!!
No Audio through the radio
turn off the dual audio..by pushing the 3 and 5 button on the radio unitwhere the small headphone light on the radio is off and you should get dvd sound on the radio....that puts it in single mode not dual mode..also play with the mode button on the back of the center console ...
Trying to use rgb input
Cable TV: Connect the LCD TV to the cable with CATV and Digital cable. Preset the cable TV channels into memory with Auto Scan function when using a cable TV system. Make sure you set the INPUT SOURCE properly (TV, VGA, S-Video, etc)
Sound problem
no its not a problem..just that your radio is set to some surround preset and the other components are not..Probably the TV, DVD etc are set to 2 channel
No audio
FM station 88.1 or similar. Set radio to scan while dvd is playing. When the correct frequency is reached, you'll hear sound.
Top Icon Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you an Icon Car Audio and Video Expert? Answer questions, earn points and help others
