You could try a reset.
Hold both the Home and Power buttons until the iphone begins to start.
It should take about 10 seconds.
It this does not work, your battery may be low.
Connect charger and try reset again.
Additional help from Apple support page. If your iPhone iPad or iPod touch doesn respond or doesn turn on
If you have another phone connect it to the wall outlet to see if you get a dial tone. This will indicate if your base unit is faulty. Check the power adapter to the base unit, make sure it is getting mains power. If the base unit has dual phone lines and if line 1 is only connected and the line 2 has beed selected then you cannot get a dial tone. In the chase press the line 1 to get a dial tone. If your base unit has only one line then check the phone line at the wall socket make sure it is plugged in tight, also check the the connection at the base unit. If this does not work then ring the phone company and get the to test your phone line, you may have a faulty line to your home.
The locator? Service on a 7684 doesn't come from the base, it comes from the cell station. If it's registered properly, the base doesn't do anything but charge the handset.
Check with your Panasonic dealer or system administrator.
Please try the following procedure to register the handset:
Place the unregistered handset in the telephone base. If PRESS FIND HS 4 SEC ON BASE does not appear on the handset screen after a few seconds, remove the handset and place it in the telephone base again.
On the telephone base, press and hold FIND HANDSET for about four seconds (until the red IN USE light on the telephone base turns on) and then release the button. The handset shows PLEASE WAIT... and it takes up to 60 seconds to complete the registration. The handset shows HANDSET X REGISTERED (X represents the handset number assigned) and you hear a beep when the registration completes.
When the registration is complete, the newly registered handset is assigned the next available handset registration number. For instance, if you already have HANDSET 1 and HANDSET 2, the next registered handset will be HANDSET 3
Dialing the 8 numbers should not cause a problem.I have a few suggestions,you may have tried a couple already.Hang up the problem phone on the base unit for about 30 seconds.If that does not help,remove the battery for a few seconds and try the 30 second hang up again.Try unplugging the base unit for a half minute.I am trying to get it to reset itself and link to the base.Is the second phone part of this system too?We had a Uniden and I personally thought it ended up being garbage and will probably never buy another one.If you end up deciding to buy a new phone,the new technology is DECT 6.0 and is supposed to have better range from the base,clearer sound to name a few things.The strange thing about it is that it operates at 1.9 GHz.Also,if you decide on a new one,google DECT phones.There are all kinds of forums about peoples opinions/ratings of ones they have bought and used for a period of time.If you have any questions,just comment on this post and I will get an auto email saying you posted.Good luck! Greg
Hi, I solved this issue this morning. What you cannot confuse here is that handset and base. To do the registration successfully, the both must be in "Registering" mode. First, to get the base in the registration
mode, you have to press <page> (a paging function for handset in case you cannot find where they are - usually button that says <page>or speaker with sound symbol on
the base) more than 5 seconds, then the base is in the "Register Mode"(though you will hear no beep).
You can then go through the procedure you describe on the handset and the handset should beep with assigned number no more than 10 seconds after it flashed "Waiting". The above, however, works only
if the Base is still functioning. In my case, sadly, the base was more
likely dead (if I press any button on the base, i.e. answer phone etc.,
there is no response). Hence I went and bought a new cheap GAP
compatible BINATONE 1800 Single at Comet (14.99). I then set up the
base, put it in the registration mode as per the BINATONE instruction. Then on the Phillips CD240
handset and gone through the above registration procedure... and Voila!
It worked. Now I have a brand new base that came with 1 handset of its own, and 3 additional
CD245 handsets which are all registered with this base. So far, the sound quality is
good and they retained all the telephone numbers
registered with the handset. The BINATONE base came with 12 months
manufacturer's guarantee so I am sorted with the base problem for at
least a year, which is nice. I hope this is helpful. Best, Ken
Step 1: Press and hold FIND HANDSET on the main telephone base for 10 seconds.
Step 2: When the IN USE light starts to flash, release the FIND HANDSET button.
Step 3: Press and release FIND HANDSET again. The IN USE light will turn off and in a few seconds, all handsets will be de-registered.
Step 4: All handsets will show NOT REGISTERED.
To register a handset (register 1 handset at a time): Step 1: Place the handset in the base unit or a charger that is connected to a power outlet. If PRESS FIND HNDST 4 SEC ON BASE does not appear on the screen after a few seconds, lift up handset and place in base or charger again.
Step 2: On the telephone base, press and hold FIND HANDSET for four seconds. Release FIND HANDSET once the IN USE light comes on.
After
a while the handset will emit a series of tones, the newly registered
handset will be assigned the lowest extension number not previously
assigned to another system handset (1-4) when successfully registered.
Repeat Steps 1 and 2 if the handset does not successfully register to
the telephone base within two minutes.
YOU might need to deregister the hand set first by holding down the red end (hang up key) and keep it down while holding the # key. If deregister wont work use base unavailable and yes, you are sure twice.
List the handset numbers of those working handsets
Using a WORKING handset follow these directions
Resetting Handsets
If you want to register the handset to a different base or
replace a handset with another one, you must first clear the
registration information from the base and the handset.
1. Press and hold [ ] and [#] for
at least 5 seconds, until the
SYSTEM RESET menu
appears.
2. Select the DEREGISTER HS
submenu. WHICH HANDSET?
appears in the display.
3. Move the cursor to select the handset ID to be de-registered
from the list, and then press the OK soft key. DEREGISTER HS
appears. CHOSE A NUMBER THAT IS NOT ONE OF YOUR WORKING HANDSETS
4. Move the cursor to select YES, and then press the OK soft key.
When ARE YOU SURE? appears, select YES. You will hear a
confirmation tone.
PUT THE HANDSET IN THE BASE CHARGER AND IT SHOULD REGISTER
