Question about ASUS Computers & Internet
I want to boot from usb but my motherboard has no option to boot from usb drive is there any software which does not require bios booting and can make my usb to directly boot. Thanx if u can...........!
Posted by capricornhar on
Anonymous
    New Friend:
Yes, it is possible to boot to a USB device, even when there is no support in the system BIOS for such a feature. To do this you would need to install a freware utilty, a boot manager, called the PLoP Boot Manager. The PLoP Boot Manager is a small program to boot different operating systems. You can boot the operating systems from harddisk, floppy, CD/DVD or from USB. You can start the boot manager from floppy, CD, network and there are many more ways to start the boot manager. You can install the boot manager on your harddisk. There is no extra partition required for the boot manager.
It can be found at: http://www.plop.at/
Posted on Dec 14, 2009
Brandon Heins
  • 252 Answers
It is also possible that a BIOS update will add USB as a bootable device to your selection. CHeck your motherboard manufacturer for a BIOS update and ONLY update it if it fixes your specific issue.
Posted on Aug 31, 2009
  • Anonymous Aug 17, 2018
    last one was 2010
  • Anonymous Aug 18, 2018
    some will not, here is why.
    http://pcdied.com/USB%20BOOTs/usb-no-boo...
Anonymous
    New Friend:
It has that option except that is disguised like this:
boot priority:
-removable
-hard disk
-cdrom
-disable
I booted from USB dvdrw using this order:
1. removable
2. cdrom
3. hard disk
4. dsable
Succesfully installed windows :)
Posted on Mar 25, 2010
    very good, old BIOS sure did DISGuied the device. Removable was the name long long ago.
dewey wyatt
  • 202 Answers
No, if the bios won't support boot from usb you are stuck. only way is to update your equipment.
Posted on Jul 07, 2009
Larry Ng
  • ASUS Master
  • 5,982 Answers
Lots of hyjackers on this topic.
see here A P5Q BOOTS TO USB.
But not some MOBO made year 1998 to 2005
http://pcdied.com/USB%20BOOTs/usb-no-boot.html
Posted on Aug 18, 2018
Anonymous
The only way to do it is to set your USB driver as the first hard disk drive from the "hardware configuration" menu i think...it worked for me.
  • 11 more comments
  • Mahmuddinnf Mar 23, 2011
    I have tried. But it didn't work on my Asrok P4VM800... BIOS can read, but after I choose the first boot to Usb flash.. There is just black screen.. I have make my flash drive bootable, I used WintoFlash,. I tried to install windows xp sp 3..
  • Mario Aug 15, 2018
    I have Asus P5N-MX MoBo with USB2.0 and tried to boot from USB3.1 device to install Windows 7. It shows the Microsoft sign and then stuck. When I look into BIOS, it recognises the USB device being an harddrive. The device is made bootable by yumi. Yet still the computer refuses to boot from USB. I'll try PLoP and experiment with it.
  • Anonymous Aug 16, 2018
    bios seen it and booting it are 2 different things.
    My answers are to all Hyjackers here, 2.
    and use USB must be 1st in the boot order
    the Asrock is 13 years old today. so
    that is a problem as is running old BIOS firmware on it.
    did you try all USB ports ? be wise do that.
    that Asrock has 2 bottom usb ports that are shared, Id not use those @!!!
    use the upper ports for usb boot
    and the 2 on bottom (near audio jacks) for mouse and keyboard only. ok (this is serious limit here)
    The Asrock F11 key is the boot on the fly key
    hammer the F11 and it shows choices. like here.https://youtu.be/g0FJkX3aWqk?t=11
    ISO builders are not equal:
    NO USE RUFUS only ! If used this 100s of time.
    never fails.
    The P5N may not allow this, it's too old. 10 years old. does machine have DVD drive>?
    It shows the Microsoft sign sure but what sign.? the w7 ISO loads Windows PE.
    and says so as it loads did it show the PE statement to the screen?
    if yes, the ISO is bad, the USB is bad or too big or not a standard USB sitck.
    If the PE windows loader jams. and the HDD is bad we test the HDD first
    Better, if you are tech savvy and know that 10 year old hdd can be bad.
    we boot Unbuntu v17 DVD, and run demo mode.
    if you have no DVD drive, (we keep on on the self just for testing) do you>?
    then DVD boot and tests disks are not possible
    a huge limitation in any shop. (old pc)
    Then boot the Ubuntu v17 from USB stick
    again using RUFUS, to make the stick.
    then run DISKTEST in Linux
    if parameter smart, 198 is not zero the hdd is bad, (its dying fast like that) ok>
    before loading any OS on ANY HDD
    we test the HDD first.
    or all forward progress can or will be impossible.
    like fetching water in a bucket, with holes in the bucket, SAME EFFECT.
    I read your manual for you, it does not show any mention of any such act with USB. zero.
    BIOS level booting, update the flash
    to 2010 last update.
    the book can lie (as it confesses) if the BIOS was updated, and USB boot added, ok?
    so only flashing the current bios is a solution to millions of PCs made this old.
    hyjaking posts where others above never once told what PC they own, is not too good.
    EVER,ok>?
    you PC is not their pc, and advice, will be wrong mixing them up, why not start new post.
    I call that a toxic soup . Is.
    yes, it is possible using tricky 2 way boot method.(per early poster .
    That trick is to cd boot it with spec software, and it (this cd) boots to USB.
    a hop skip-pity jump. trick. most folks go what? who or fail, now.
    as posted above but most folks don't want to do that. or finds out the windows installer gets lost doing that (w7)
    Normal steps below, no magic.
    let me show the steps.
    (i will assume target PC dead (or infected etc)
    do you have the w7 , as a simple ISO file
    or is it a DVD disk, since you demanded USB
    Ill assume ISO file. only. and from MS.com
    Some look and the CD drive can do DVD. oops
    so then make there own ISO, did you, context matters, source of ISO file never stated by anyone above.
    microsoft.com ISO takes good retail COA key to download it, did you?(your details lack)
    when you download the ISO did the MD5 checksum match> yes, good, no super bad. stop and repeat
    1: get a USB 16GB stick. (no giant sized sticks )
    2: go to modern PC.
    3 burn the stick (usb ) with RUFUS.
    4: the boot the stick on the alien machine.
    if the first page shows up, good, stop.
    if not working as test now the one of the steps above,failed..
    5: now at dead PC insert USB now.
    6: enter bios, go to usb advance, and turn on all 3 usb selections, including legacy mode.
    7: then go to boot page, boot order. see if the USB stick shows up. if not try all USB ports now. mine shows up as Sandisk superx.
    8: if it shows up with boot order set to stick name first. in order.
    power one again, and hit the space bar, hammer it 1 per sec. tap tap tap.. see?
    this forces many PCs(El torito spec) to boot to CD or STICK. this spec, allows boot throught happen on 2nd phase of w7 installation.
    9: ok it installed ok but needs 350 updates
    sad that. and takes all freak'n day.
    IE11 must be loaded first. (fresh and new)
    Hints.
    16GB USB is best size (only on old machines.)
    8 GB use to work. but if you learn about the ISO files, Microsoft will at any time they choose , add the 350 updates to the ISO.
    we can only hope that, but if they do
    or add other bloat ware to it , then it will not fit on the 8GB stick and fails.
    warning some silly stick makers made USB sticks that are UEFI only sticks, and will not work
    on old BIOS PCs, I bought one and found out it was (as maker said) "only for w8 or w10."
    UEFI, avoid these sticks.
    the ISO for w7 up
    can be huge if the ISO supports
    both 32bit and 64bit versions of w7
    in one ISO
    MY old sp1, 64bit w7 is. 4.77gb, with zero other updates or newer service packs.
    so download the ISO and read the size of it first. to see it is not MS, super sized.
    https://www.microsoft.com/en-us/software...
    it shows today, it is still 4GB sized.
    so 8GB USB is ok today.
    but note , no free trails of W7 , like in 10
    you have to have good retail coa key to get it.
    using the Asus coa keys will not work here.
    OEM disk only come from ASUS not MS.
    common reasons to fail usb bootings,
    1: the BIOS is not set to boot to it.
    (or the old BIOS needs the firmware update)
    mine has 4 setting or more for USB to work
    IN BIOS pages.
    2: you didnt hit (say) the space bar ,at power on to telling the BIOS to boot to USB.
    ("intel El Torito" rules)
    3: the USB is bad.
    4: the USB formatted wrong, Use RUFUS
    5: wrong ISO or corrupted, ISO
    6: you didn't test the USB on other newer PC. (easy no? test it on a modern PC)
    7: using huge giant 512GB or 1TG stick that old PCs are cu
    8: Using ISO from not authoritative sources.
    NOT Microsoft, NOT ASUS (or your OEM)
    aka: hackers ISO or counterfeit.
    9: many times one must replace the MOtherboard
    to do this. (if old one is too old)
    10: do the complex trick of booting to CD
    that has code there that boots to USB.
    not always effective.
    testing.
    try to make a Linux install USB.
    using again, the RUFUS tool, (free)
    does that work, if not we can be more sure
    the BIOS is failing. just it.
    use 8 or 16GB usb sticks. (small) not huge.
    ISO : here:https://www.ubuntufree.com/download-ubun...
    boot the Ubuntu v17 LTS
    if it works , click TRY ME.
    this is DEMO mode or LIVE testing
    no install, here,its just test.
    we keep this USB stick ready 24/365.
  • Larry Ng
    Larry Ng Aug 17, 2018
    if the usb boots, the screen will
    show "hit any key to boot this device."https://youtu.be/g0FJkX3aWqk?t=11
    hit space key ,its big and most easy.
    I hammer it 1,2,3,4, boom the USB boots.
    this HIT rule is called Intel El Torito spec.'
    this allows 2nd boot up , installing windows
    to boot through and not start the setup.exe
    in and insane endless loop.
    on the 2nd auto boot, it boots from C:
    see?
    this is how it works. by design.
    some BIOS are buggy, and do this all wrong
    on those trash BIOS we must be ready at 2nd boot and snatchh out the USB stick just then.
    ok?
    Ive done this to VAST models of PC, brands and models, and know how to tell if the PC is too old or not.
    if the w7 ISO starts up, it will next tell you the W7 PE
    ORDER:
    BOOT TO USB, TRY ALL USB PORTS, even my newer
    PC will not boot from USB3 port, only USB2.
    The 1st screen must be "hit any key to boot to USB"
    if not your bios is set wrong or too old.
    next is this. screen. must get.
    the black screen below is the windows PE
    pre boot environment. EMS.
    then you hit enter and get screen 3 next below.
    that is it.
    if all 3 screens are dead and for sure the HIT screen, the BIOS is not booting to USB.
    hit any key to boot USB. (scr1)
    then screen2
    then screen 3
    P5 had this back in 2007 (11 years ago)
    if usb does not show up, here, and usb legacy is on, and all usb ports tried.
    he stick is not formatted correctly
    or this old BIOS last update 2010 is not supporting this activity.
    The 11 years old coin cell is bad.
    if its bad, you will never be able to set USB setting and retain them in CMOS NVRAM.
    use new Coin cell on any old board like this.
    7+ years is time for new coin.
    a bad coin cell = CHAOS.
    avoid CHAOS, and win.
    this Old mobo loves to show black screens
    if all boot device are missing, (bad BIOS software was common there, Design)
    on new ASUS, Z270 it freezes the last screen
    in bios, shows the sata and boot devices all missing clear as day.
    on this old PC see this screen.
    if like this, there is no boot devices or you set the order wrong or USB settings in bios are wrong.
    p5 below
    so remove the hdd, data cable.
    and CD, drive sata data cable.
    and see if the USB device is detected.
    if not (bad bios or bad stick)
    the oldest bios is buggy. after the below screen the silly mobo go black screened,.
    here is P5Q and its bios too, ended at 2010 last update.
    the F8 key is boot on the fly key
    that means hammer F8 at power on. tap, tap tap.
    then see my SANDISK USB>
    or set the the boot order.
    like this video shows.
    my guess is stick burned wrong.
    wrong type of stick uSB used,
    or wrong USB port used,
    so move it to next port hammer f8
    move it again hammer F8
    on my HP all usb3 ports are dead, in bios only.
    best is known tested uSB stick first on a newer PC then play with 11 year old PC last.
    https://youtu.be/6wPD7pBVjfk
  • Larry Ng
    Larry Ng Aug 18, 2018
    NO Motherboard even stated. JUST ASUS
    1995 to 2018 , name one of 1000s
    lots of hyjackers on this topic.
I have a Dell mother board model 0WF887. It has the usb boot option on the boot selection menu. There is no option for this in the BIOS setup. Does this mean I'm SOL for booting from a flash drive? It...
Some BIOS will only give you the option for USB if there is a USB detected upon boot. List all your boot options it could also be listed as something like Legacy USB, USB FDD, USB HDD
Aug 31, 2011 | Dell (0141E) Motherboard
My laptop usb not booting
1. Check from Bios that the option boot from USB is Enable
2. Check from Bio that In Boot Priority USB is first Booting Device.
3. Check that USB has all the required Booting Files.
4. If you need to have a software which will make USB bootable . download from the following link
http://www.bootdisk.com/pendrive.htm
5. Enjoy
Jul 08, 2011 | Sony VAIO FXA36 Notebook
The motehrboard bios doesnt boot from usb to install windows, how can i update the bios to boot from the usb?
Insert your USB jump drive into a USB port on the computer containing the bootable program. Copy the information to your jump drive, then insert the drive into a USB port on the computer you wish to boot the program from.
Power on the computer. When the computer begins displaying its startup information, hit the key indicated on screen to enter the computer's BIOS (the "F1" or "Delete" keys are commonly used to access the BIOS).
Browse through the menu options in the BIOS to locate the computer's startup and booting options to locate the "CMOS" menu, which is where you'll have the option to set which devices will boot at startup.
Browse though the list of bootable option---they'll be ordered as "First Boot Device," "Second Boot Device" and so on. Set the USB jump drive as the first bootable option---your BIOS may refer to the drive as a "USB Removable Floppy Disk."
Save and exit the BIOS. When your computer restarts, your program will boot first before your operating system.
Feb 17, 2011 | Intel QDI P2PE/800 Pro 82845PE Socket 478...
How to shut off usb drives from booting up in bios?
Go to bios options, and search for the option called "USB BOOT" Disable this option. and in the option "boot device priority" don't keep the first boot device as removable drive.
You can go to bios by pressing DELETE key at the point when switch on the PC
Any Questions you can contact me.
Rate my solution.
Regards
May 25, 2010 | ASUS P4P800E Deluxe (90M8LCW0G0EAY)...
I want to boot from usb flash drive. how can i do ?
Hi
Thank you for your query
Please try the following
1) Switch on PC
2) Press F12, del or the ESC key to enter setup
3) Go to advanced options and then choose boot options
4) In boot options choose USB peripheral to be set as first boot device
5) Save and exit from the BIOS screen
As the PC restarts make sure the USB flash drive is plugged into the PC
I hope this has been useful
Mar 12, 2010 | Biostar M7VKA Motherboard
Doesn't recognize SATA hard drives. BIOS option
Need to install latest bios update go to there website also if you are trying to boot up with usb installed take it out. BIOS ID:15
  1. Fixed the issue where SATA HDD boot up will fail if USB storage device is installed.
  2. Fixed the issue where SATA HDD boot up will fail if "USB keyboard/mouse" setting as "BIOS" section.
  3. Enhance the compatibility of SATA device on WIN98SE/ME.
  4. BIOS compile date: 06/07/2004
Nov 28, 2009 | Abit KV7-V Motherboard
Bios replacing
You will need to download the BIOS installation software for DOS if they have one from the motherboard manufacturer and the BIOS file. You will then need to make a bootable dos cd-r disc using windows. Once you have done this you can use the disc to start your computer in DOS mode. Then burn the BIOS DOS SOFTWARE and the BIOS FILE on a cd-r. Then you will be able to run the BIOS software from dos and install the bios file. You could also install windows on a USB hard drive then try to boot from it if your computer can boot from USB and the USB boot device option is still working.
Nov 26, 2009 | ASUS A8V-E SE Motherboard
I need to know how can I boot from my usb flash thanks
You need to know if your motherboard can do this option.
Enter setup otion generaly when you turn your computer on press the DEL key and you are in the BIOS SETUP configuration. Go to the BOOT SEQUENCE and if it is possible choose USB option.Place this option on the first place with the UP or DOWN keys. For exemple fist boot drive : USB second boot drive HDD ,...
You must format your USB device as SYSTEM ! and have the system installed on it. You can find on the Web a light version of WINDOWS XP called LIGHT to put it on your USB device I think it is an USB flash drive, Is it?
If it is an external HDD you can install the entire system of Windows and boot by it bur select the right boot sequence in the BIOS setup.
Dec 17, 2008 | Computers & Internet
Problem regarding usb booting
the hard drive registered in the standard cmos utility is the only one that could be registered for boot in advanced cmos setup and no other, if your usb hard drive and pen drive could be registered in the advanced cmos setup - where boot options are registered, surely it will boot your pc.
uzowuanya
e-mail:[email protected]
Feb 16, 2008 | Asrock P4I45GV R5 Motherboard
Boot to USB?
most of the newer motherboards have an option to boot from usb, I have 2 1 laptop a Dell XPS 2010 will boot automaticly to USB if it is plugged in and has the option in the bios for boot seqence, and a desktop a dell XPS 720 it will alsi do the same, see if you can find a live copy of XP or the OS of your choise and you can boot from DVDR I have a copy of XP Lite Portable that boots from USB and runs fine
Nov 04, 2007 | Dell Latitude C610 Notebook
Open Questions:
Computers & Internet Logo
18,272 people viewed this question
Top ASUS Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Roy May
Marvin
Marvin
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
