Question about Samsung SGH-x427m
No screen images
Screen won't display when phone is on
Posted by newm on
Anonymous
BUY A NEW RIBBON
Posted on Nov 20, 2007
Anonymous
  • 3 Answers
Try your contrast option i had the same problem and it was that my contrast was set so high that nothing was displaying
Posted on Nov 11, 2007
The screen won't turn on anymore after I took it apart to switch out the charging port.
I see a crack in screen on top right but it should still display (however touch won't work). Look at the ribbon connector which connects display to the phone PCB, it should be firmly secure in its connector.
Also try cleaning the PCB with alcohol, if still doesn't work then either you need a new LCD or some chip is blown.
Nov 10, 2012 | Lands Phones
Samsung Anycall screen won't light up
hi i have a problem on samsung shw m110s ..i cannot see any display but its working ..what shoul i do?
pls help
Jul 10, 2012 | Cell Phones
It happens to most of the cell phones. The only way is to contact nearest cell phone service centre.
Jun 03, 2012 | LG VOYAGER VX10000 Cellular Phone
My verizonwireless pantech hotshots screen won't
Please go to store to fix this problem.
Apr 17, 2012 | Samsung Cell Phones
My screen won't turn on but the phone works and the keyboard lights up
you did not mention if your phone is a slide up type or not, if it is slide up type where in you need to slide up the upper part to see the keyboard then its gonna be the flex of the phone is defective or cut out, if its not, its the LCD DISPLAY...thanks!!!
Jul 14, 2011 | Lands Phones
Start up screen won`t change.
Had same problem when loading the latest Touch IT ROM from xda-developers.
Switch Phone Off.
Press and hold the 2 keys on the left and right under the screen, then press the power button.
Blue and white screen displayed. Slide out keyboard,
Press R to continue with Reset or X to Cancel.
Jun 14, 2010 | Sony Ericsson XPERIA X1 Smartphone
Display is cracked. how can i change it.
You would need to take it to a phone repairer to help you change the screen.
Best regards
Dec 11, 2009 | Nokia 1600 Cellular Phone
Won t charge
Download Motorola Phone tools and get a new battery for your phone.
The batteries go bad about once a year, sometimes longer.
if this helps you please leave a vote on fixya
May 21, 2009 | Motorola Mobility MOTORIZR Z3 Cellular...
Nokia phone problem
Can't use Nokia phone. Screen displays this message. "insert Smartchip"
Oct 12, 2007 | T-Mobile NOKIA 3395 Flexible Mini Boom W/...
Motorzor
you simply fried your battery by overcharging it. Just get a new one, let it fully charge and fully die twice before you start normal charging. Then you will want to only charge it for about 2 to 3 hours or find a charger that has a smart chip that tells it when to stop charging once the battery is full.
May 13, 2007 | Motorola Mobility RAZR V3
Samsung SGH-x427m Logo
44 people viewed this question
Top Samsung Cell Phones Experts
Muntejaya Ginting
Muntejaya Ginting
John Tripp
John Tripp
Ekse
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
