Convert from street to dirt
At a a minimum, you will need the magneto (inside left engine cover), the regulator/rectifier (right side, under seat -- has fins on it), the CDI (under seat, at front of airbox), and enough wiring harness to connect the 3. You should put a large capacitor in place of the battery. You will need to jump the sidestand and clutch safety switches, as removing them will cause a no-start condition.
SOURCE: Electrical problem
Without a battery,None of the electrics will work unless the bike is running.Start the bike to test.
Please rate this fixya
SOURCE: removing the carburator on a suzuki drz, 125.
It is quiet easy, you remove the seat then the fuel tank this will expose the carburetor then its simply a matter of disconecting fuel line and unscrewing attachement screws. why do you need to do this? I would be very careful doing this as any dirt or dust or grime getting in can have huge impact
SOURCE: Suzuki GS 750 Starting
Hi
Sounds like someone has customised your bike - does it have a RH switchgear?
there shd be 3 connectors for the RH switch in headlamp - a 3 pin & 2 singles, the 3 pin has 2x orange/white + 1x yellow/green, this connects to 1x orange 1x orange/white +1x yellow/green wire which are for the kill + start
The singles are 1x orange/green + 1x white (loom side) which go to 1x orange + 1x white respectively, these are for the brake light
If you are keeping the kill sw then its only the yellow/green wire that can be discarded.You can also follow it back to the starter disconnect sw - junk that - keep tracing it back to the starter solenoid & junk that too. If you want to keep the electrical accessory output terminal then connect that straight to the battery or to the orange wire from the ign sw to the fuse box. You can also junk the thick wires from the solenoid, 1x to batt + 1x to the starter motor
You can junk the starter motor too ( 2 bolts then pull away from sidecase & up at the rear) but make sure you block the hole up!
If you want to bypass the ign sw then disconnect the 4 block from it & jump the red to the orange & also the brown to grey (for lights etc)
Good luck & ride safe
Bike-Doc
SOURCE: ducati monster 620 went dead
Sounds like a detached connector or a blow fuse. First open your user manual, locate the fuse holder and dbl check the fuse... You have two circuits, the On circuits, and the accessoiry (wich are not essential) seems that you lose the accessory...
SOURCE: wire harness on a 2001 r1 shorted out
The Haynes manuals have very good color-coded wiring diagrams in them. They are worth the investment, anyway.
Hope,
matt
