Question about Nintendo GameCube Console
Problem the fan's on the light is on and its plugged in but the screen is completly blank with nothing at all
Posted by soccerstar on
Anonymous
    Problem Solver:
  • 5 Answers
It is probably the cord get a new cord for it
Posted on Nov 19, 2007
Computer won't do anything, keyboard does not light up, screen is blank
So there is not so much as a BIOS message on screen? Any beeps?
If there is no life at all, you have a CPU/motherboard failure. This may be direct or indirect (e.g. no power to MoBo). Check your connections.
Otherwise, your boot device may not be operating. This is usually a dead or disconnected HDD. Check that it is plugged in. Does it get warm? Can you feel any vibrations from it? It should spin even if your cpu is dead but MoBo is alive.
Oct 26, 2012 | HP Compaq Presario SR2038X PC Desktop
Acer Aspire One NAV50 screen blank
I am not in a position to offer free remote help, but you might help yourself with the link (below). It's to Acer's online community.
If this helps, you can indicate as much - g'luck.
http://community.acer.com/t5/2013-Archives/Acer-aspire-one-model-nav50-Drivers/m-p/57977#M39399
Jun 28, 2017 | Acer Aspire One Netbook
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Oct 07, 2012 | Acer Aspire One Netbook
Battery light flashes and nothing else happens
Yes, the socket broken loose could be your trouble and is common as we are not careful when we insert the plug all the time.
Apr 19, 2012 | Computers & Internet
MY ACER LAPTOP 5535 WHEN SWTICHED ON, I CAN HERE THE FAN STARTED AND GREEN LIGHT SHOWS, BUT THE SCREEN IS BLANK, NOTHING DISPLAYING PLEASE HELP!
is sounds like the lcd display may be bad. try plugging a rgb cable into your laptop and another monitor to see if you get pic.
Aug 30, 2010 | Acer Computers & Internet
My garmin nuvi 2255w is completely dead. Will not turn on, the screen stays blank. I plugged it into the car plugin and it does nothing. It was working just fine before now.What could be the problem?
My garmin Nuvi (205 I think) just stopped working...blank screen, does nothing? Was working fine a few hours ago. Car plug in lights up when plugged in but still nothing.
Feb 08, 2010 | Garmin nuvi 255W GPS Receiver
Computer Screen Went completely blank and wont turn on
You might want to plug in external monitor to make sure your screen did not burn out before doing anything else.Good luck and have a good day.
Jan 30, 2009 | Toshiba Satellite A135-S2276 Notebook
I have a dell inspiron 5000e that won't power up. the battery is dead but the adapter works. after pressing the power button the left light beneath the screen turns a solid green and the center light...
As per the symptoms given by you it seems like a motherboard problem. Follow the steps on the link below and it would suggest what part needs to be replaced.
http://tinyurl.com/6xxv4h
thanks
proton
Aug 02, 2008 | Computers & Internet
Toshiba laptop will not turn on, screen is completely black
Don't pay attention to your uncle. I had the same problem. Blue ring, power lights on. Sometimes the laptop would come up after a few minutes and then would freeze. It is a power problem. The AC jack may be broken and, most likely, you need to get the MAX1632A power controller (a 40-48 pin black IC next to the AC jack) resoldered too (get someone qualified to do it, with the right soldering station for surface mount work). Look for a complete answer at
http://www.laptopka.com/2006/04/04/fix-most-common-problems/all-comments/#comments
Comment #202, by Jerry.
I followed his instructions and got my laptop back from the dead
Alfonso
Jun 01, 2008 | Toshiba Satellite M35X-S349 Notebook
Nintendo GameCube Console Logo
29 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Ekse
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
