Did you try reset? Unplug AC cord for a while,plug in try again...
2) With paper clip, activate reset thru access hole on front of
TV ( consult owners manual) recheck.....................
3) Leave set unplugged from AC overnight.................T.
Please rate this solution........................
It might be that your set is headed in the direction of all the
other Mits chassis with DM modules on board.......If not now, then very soon your set will blink the LED green power indicator
and nothing will stop it....The fix is replace four capacitors on the
DM module. For details go to [email protected]....
Have a well-qualified Mits tech look at your set........T.
Tried ALL of that - NO JOY!
Only, now the failure appears to remain in the failure mode.
The Black picture in the failure mode is really just a dark screen - with light (in the room) off you can see a faint dark color. HD mode still shows a picture with loss of Hortz sync. Other functions like INFO, Device, Channel, Volume, etc. ARE visible when accessed.
