Possible your door has not been shut properly. Open the door and shut again. Or try some WD40 spray on the door of the machine, not on the body, or it could short circuit something. If all this does not work just change the lock mechanism, quoting your model and brand; you could find spares on the net.
1) test the lid switch for open 2) test the door switch for open too 3) see the diagram attached, any switch faulty can not START the motor. God bless you
You have a mildly confused machine, probably the result of the fact that there is a moment where the door lock can activate, but the sensor that tells if it's shut cant because the door isn't QUITE pushed home hard enough.
First try, just give the door a whack with the heel of your hand in line with where the door catch is. It may be that simple to relocate the door and the sensor properly
Failing that, unplug at the wall and wait 20 minutes. This will, without doubt reset the machine and allow you to open it (While it is still powered off!). Open the door and shut it firmly.... I hesitate to say SLAM the door.... But slam-ish won't hurt, just don't be stupid about it!
The light flashing usually indicates that the door is not closed securely. this can be caused by a weak or broken door handle spring.
If you are satisfied that the handle is o/k, then the other possibility is that the control module has a blown track, this can be accessed by removing the top cover.
Hope this nhelps.
It happened on our machine. The soloution to this for me was to take the lid off (two screws). Unplugged from mains. I found the connector to the door had vibrated off and was just hanging loose. Plugged it back in and it worked straight away.Door opens as normal.
Don't forget to look in the manual for how to get the door open in an emergency.
