Question about Samsung SGH-X495 Cellular Phone
Phone Locked After typing the code #0111*0000000#, my phone now displays "Phone Locked Return for Servicing. Is there a code I can enter to unlock it? phone lock not sim lock asking for password factory 00000000 doesnt work 1234 doesnt work last 4 digits of phone# doesnt work either. I dont need SIM lock codes I just need phone lock
Posted by txyachtgirl on
  • Anonymous Mar 17, 2014
    i dont kno the four code or the phone number to my UTStarcom TXT8010 Blitz Phone
  • Anonymous Mar 31, 2014
    Screen says phone lock and need a password to go any further than just powering it on
Sylvester Brathwaite
    Brigadier General:
  • 7,752 Answers
You should take the phone to a mobile center and have them unlock it for you.
Posted on Jan 30, 2008
How can you jailbreak a lg g800?
ow to Enter Unlock Codes on LG KB770: Insert an original simcard and turn phone on Enter sim PIN if required Enter 2945*#770# From the menu that pops up select "SIM unlock" Enter unlock code you received and press OK The phone will then reboot and the unlock is complete How to enter Unlock Codes to LG GB250 & GB220 Power on your phone without SIM card Enter 2945#*505# From the menu that pops up select "SIM unlock" Enter unlock code and press OK The phone will then reboot and the unlock is complete How to Enter Unlock Codes on LG GT505: Power on your phone without SIM card Enter 2945#*505# From the menu that pops up select "SIM unlock" Enter unlock code and press OK The phone will then reboot and the unlock is complete How to Enter Unlock Codes on LG KP100: 1) Insert a not allowed SIM card 2) Press the unlock button 3) Enter the code OR 1. Insert allowed SIM. 2. Booting (Request PIN Code, PIN Code enable) 3. In Idle Screen, Input the hidden number (2945#*20001#) 4. Input the number (above), go back to the idle screen 5. Menu-4.Settings, 7.Security-6.SIMLock Code:-1.Network Unlock Code:-1.Deactivate: 6. Select "1.Deactivate:" Menu, Display pop up " SIM Lock Code:". 7. Input right Unlock code, Display pop up "Deactivate". 8. Reboot, and unlock simlock code How to Enter Unlock Codes on LG KF390 and KF390q: 1) Insert a SIM Card from the network the mobile is locked to and turn it on 2) Insert the following sequence *#865625#; 3) Select 'Unlock USIM' 4) Select 'Network Lock' 5) Insert the unlock code 6) Reinsert the unlock code 7) Select OK. Done! How to Enter Unlock Codes on LG Prada (e.g KE850, etc): 1. Switch the telephone on with Original SIM card inside. 2. Enter SIM pin if required. 3. Enter 2945#*8501# and press the call button (middle button bottom of the screen). 4. SIM unlock mode will appear on screen. 5. Enter unlock code 6. Select Reboot. 7. Switch phone off, and then turn back on again. Phone is now unlocked How to Enter Unlock Codes on LG KE990 / KU990 Viewty: 1. Insert original sim card and turn phone on. 2. Press telephone icon at bottom of screen to bring up the phone keypad Enter 2945#*990# 3. A menu will pop up, select sim unlock: 4. Another menu will appear, select Network lock. Enter your unlock code and press ok 5. The phone will then reboot and the unlock is complete. How to Enter Unlock Codes on LG KG245 (Vodafone Australia): 1. Insert a Vodafone Australia working SIM card. 2. Ensure the phone is charged and then switch the phone on. 3. Optional Step: If the SIM card has a PIN, enter your PIN number 4. Wait for the phone to power up then enter 2945#*7101# 5. Select Menu , then go to Settings > Security > SIM Lock > Network 6. Select Deactivate and enter the 8-digit unlocking code provide for your handset. 7. The handset will be unlocked automatically and will display "Done". This will be confirmed if you can make and receive calls with the Non-Vodafone Australia SIM card. (You will need reception and phone credit with the different network provider) How to Enter Unlock Codes on LG KG800 or TG800 Chocolate: 1. With the phone in standby, enter 2945#*7101#. This will activate the extra menu. 2. Go to: Settings>Security>SimLock>Network 3. Select deactivate. Enter the unlock code How to Enter Unlock Codes on LG C2000: 1. Insert non-Cingular SIM card 2. Power on the handset - phone will display "phone restricted" 3. Select "Cancel" - phone will display "phone restriction code" 4. Enter the SIM Unlock code 5. Select "OK" - the handset is now successfully unlocked How to Enter Unlock Codes on LG U8150: 1. Switch ON your phone with a not allowed SIM card. 2. Compose: 277634#*#. 3. Go to menu "SIM Lock". 4. Enter the unlock code How to Enter Unlock Codes on LG INCITE CT810 Power on phone with original SIM card Type 2945#*810# In the menu that appears select Sim unlock Enter supplied unlock code Your phone is unlocked How to Enter Unlock Codes on LG F2250 Power on phone with Orange SIM card inserted While in the Start menu type 2945#*3311# Return to the startup screen Press Menu key Select Settings > Security
Jun 06, 2014 | Samsung Galaxy S GTI9000 Smartphone
Sim card locked on me
It's locked with Network? or locked with Security code?Security Lock means get the code from service provider and Reset it from Security lock of Sim!!! It locked to Network means specify the Network and Country it locked Now,then get the Network Unlock code for Pantech P7040 Link Phone at
Classicunlocking.com and Unlock it ,then use with any GHSM Network,To enter the code correct follow the Instructions below...
Pantech P7040 Link Unlocking Instructions
Warning : Do not enter any wrong unlock codes on your Pantech P7040 Link mobile phones. If you enter over a certain amount of wrong unlock codes on your Pantech P7040 Link mobile phone, your phone may get hard locked and sometimes become unusable.
1. Switch ON your Pantech P7040 Link with its ORIGINAL SIM card.
2. Type *#865625#.
3. A SIM Unlock Menu will appear, press OK.
4. Enter Unlock Code.
5. Re-enter Unlock Code.
6. Pantech P7040 Link will display Unlock Process Complete. Press OK.
7. Your Pantech P7040 Link is now unlocked.
ORIGINAL : We mean, to use the sim card that was originally given to you by your network/service provider along with the Pantech P7040 Link.
Aug 25, 2011 | Pantech Link P7040 Black Rubber Feel Hard...
Unlock code for samsung SGH L310
hi you can get the unlock codes from here
wickedunlock
here you select the country and the provider which blocks your mobile and get the unlock codes at reasonable cost using codes to unlock your mobile is the best way because it saves your time a lot.
May 30, 2011 | Samsung Lands Phones
I don't know my phone code
Try this steps , hope it will help you:
Unlocking:
If you have Rev 1.5 (x426) or earlier and most older models
Use the *#9998*3323# Trick (look for it on the forum)
The *#1111*WHATEVER# code will NOT work
If you have Rev 1.6 (x426) or later and most newer models
You MUST use unlocking software. Codes WILL lock your phone FOREVER
Locked: Return for Servicing
There is only 1 working solution, you must flash a copy of the firmware that is not in the locked status. (Most) Unlocking programs will NOT disable this issue, and your service provider cannot give you a code
If you do not plan to use your phone with another service provider, there is no real point to unlocking your phone other than to sell it. If you don't need to unlock it, don't take the risk of disabling the phone altogether
The *#9998*3323# Method:
1. If you have changed your phone password, change your password back to the default 8 zeros (00000000).
2. Put a SIM card that is from a network other than the one your phone is locked to
3. When Incorrect SIM error comes up, type *#9998*3323#.
4. White screen will appear with an exit option. Press the right softkey.
5. From the menu that appears, select the Malloc Fail option. This will reboot the phone and the normal service screens will appear.
6. Type *0141# and then press the green call key. "Personalization" or "Personalized" will appear.
7. Turn off your phone and put the original SIM back in.
8. Turn on your phone. You will receive a prompt to enter a password.
9. Type 8 zeros (00000000)
10. Completed. You have now unlocked your phone.
Thank you for using fixya..
Please rate me on fixya and provide testimonial if ever to continue my further assistance..
May 30, 2011 | Samsung GTC3300 Cell Phone
Need to unlock a Nokia 6103b
Unlock your phone
  • Press Menu, enter the lock code, then press OK.
Answering a call when the phone is locked
  • Press Answer.
To change the lock code of your phone
Your phone's lock code is used to lock and unlock your phone.
The default lock code is 1234.
  1. Use Menu 4-3-2-3 (Settings - Security settings - Access Codes - Change lock code) to change the lock code.
  2. When the phone requires the lock code, it displays "Enter lock code:".
  3. Enter the code, then press OK.
If you enter a wrong lock code five times in succession, your phone prompts you for the security code.
Saving the unlocked phone number
Use Menu 4-3-2-2 (Settings - Security - Settings - Unlocked phone number) to save a number that may be called even when your phone is locked. You will be required to enter the lock code.
  1. Calling the unlocked phone number.
  2. Press the Up or Down arrow keys or or manually enter the number exactly as it is saved, then press Call.
Note: The More key will pause the automatic scrolling of the help text. Pressing the More key or the Up or Down arrow keys will toggle through the pages. The More key is only displayed when the help text is displayed.
Jan 26, 2009 | Nokia 6103 Cellular Phone
Phone Locked
You could try to reset your phone.
Remove your sim card.
Enter *#2767*2878#
Aug 02, 2008 | Samsung SGH-t219 Cellular Phone
Phone Locked
If you need it unlock you can try online at www.mobile2mobile.net, www.unlockitnow.com or try a mobile center close to you.
May 26, 2008 | LG Shine KE970 Cellular Phone
Phone Locked
I used this code to get my phone (SGH E105) back to normal.
*2767*688[IMEI]#
i then input the unlock code from the TMobile custom service and unlocked my phone.
*2767*688[IMEI]#
Mar 29, 2006 | Samsung SGH-c207
Phone Locked
hi my cell samsung c130 say phon locked return for servicing and do'not accepte unlock code #0111*00000000# plz help
Samsung SGH-X495 Cellular Phone Logo
591 people viewed this question
Top Samsung Cell Phones Experts
Muntejaya Ginting
Muntejaya Ginting
John Tripp
John Tripp
Ekse
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
