Question about HP Pavilion F1703 17" LCD Monitor
Monitor goes on then off right away.
Have an HP 17" Model w17e. I press the power on button on the monitor the display lights up, shows a energy star splash screen then goes dark. I have found that if I shine a light on the screen I can see my desktop but it's dark. Any clues?
Thank you!
  • dadmech Jul 06, 2009
    RAM in the monitor? So, there isn't some kind of back light that lights up the screen? This does this on 4 different computers.
    Thank you
    Problem Solver:
  • 7 Answers
I concur with "Drikus41". The back light inverter is probably faulty. Or more likely, the circuit board driving the inverter. Seems like a component is heating up quickly right after you turn it on, and it's shutting down the power to the light. If you're adventurous, you could also attempt to check the connection cable inside the screen bezel.
Posted on Jul 17, 2009
  • 42 Answers
The backlight inverter is faulty.
THis means that there is either a loose contact or one of the transistors on the backlight inverter has blown
Posted on Jul 07, 2009
    Sergeant:
    Champion:
  • 249 Answers
Problem is with the RAM.
Posted on Jul 06, 2009
6ya staff
SOURCE:
I have a compaq 1720 monitor and the Display Manager has been constantly popping on and off of the screen. When I hit menu on the monitor to make it go away, it goes away, but comes back almost instantly....
Could be a little dirt/debris under the menu button. Try blowing around the button with a spray can of air or a small air compressor (100PSI or less), pressing and depressing the button as you spray. Good luck.
Jan 29, 2018 | HP Compaq 1720 17" LCD Monitor
Can not stop monitor from truning on then off. then it says osd locked.
OSD Lock
The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock displays for 10 seconds.
If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD.
plz do rate the solution if helped
Nov 22, 2010 | HP L1506 15" LCD Monitor
LG Flatron W2234S Monitor Monitor goes black
Ahh the same thing has happened to my monitor! Mine unfortunately is 1 month over warranty. Apparently this is a common problem with this model!
Oct 29, 2009 | Gateway FPD 1730 17" Flat Panel LCD...
AcerAL1714 LCD Not Connecting With DELL Inspiron 15 Vista Laptop
There is a symbol of Two monitors on F3 Or F4 button
1. Press Fn key and hold it
2. by holding Fn key press F3 key
Your monitor will start displaying
Oct 05, 2009 | Acer AL1714 17" LCD Monitor
W17e says "input not supported"
Hi - here's what I found about your wide screen monitor:
The HP Pavilion w17e LCD wide-screen monitor has the following features:
  • 1440 x 900 factory-set resolution
  • Supports VGA analog signal video input
  • Plug and play capability, if supported by your computer system
  • On-screen display (OSD) adjustments for ease of setup and screen optimization
  • Energy Star compliant
Download & install the drivers for the monitor based on the version of Windows you are running from the HP site below:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&cc=pe&dlc=es&product=3377546&
Once the drivers are installed, your issues should be resolved - the driver will allow only the modes that can be displayed on the monitor - probably giving you options for resolutions you hadn't seen before.
Sep 29, 2009 | Acer AL1916W 19" LCD Monitor
Brightness indicator windows does not go away
Dear sir This is common problem observed in many monitors compaq,HP,HCL,IBM this is happens mainly in rainy season due to moisture,by this moisture monitor button circuit get rust inside and button pad remain pressed. so it shows a strip at the middle of monitor like contrast or brightness. So this is minor problem just replace the monitor display control button sensor or circuit.Temporarily you can warm up the monitor by hanging a bulb of 60 watt nearer your monitor to takeoff the moisture.(Dont hang the bulb too near to the monitor). It definitely solves your problem.
Have a Nice Day
Sep 17, 2009 | Samsung SyncMaster 740N 17" LCD Monitor
OSD main menu pop-up will not go away
Please try to Turn the monitor off. Hold down the Menu button while the monitor is turned off, then press the Power button again to turn the monitor back on. This should unlock your OSD menu and remove that message from your screen. best regards
May 19, 2009 | HP Pavilion F1703 17" LCD Monitor
HP w17e monitor
i had this problem as whell for the HP w17e or maybe others, you turn off the monitor then press and hold the menu button and while you are still holding the menu button turn on the monitor and hold it still for 2 seconds and you are done. Hope this helps
Feb 18, 2009 | HP w17e Monitor
HP Pavilion F1703 17" LCD Monitor Logo
489 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
