Question about Dyson DC14 Full Access Bagless Upright Cyclonic Vacuum
Suden loud noise when vacuming carpet
While vacuming carpet (with vacum set on carpet) it suddenly makes a very loud noise. it also doesn't seem to glide smoothly.
Posted by truckie on
Johnboy
    New Friend:
  • 3 Answers
It's most likely the Belt Slip Protection Dyson uses to prevent the user from having to replace belts. I recently bought a Dyson and love it other than it literally sits there and makes horrible noises 80% of the time. I completely disassembled the vacuum and found that the spring they used for this belt slip protection is WAY too weak. The weak spring seems to let the belt slip protection pop off way too frequently and unnecessarily. I stretched the spring back out and whammy no more horrible clanking. Of course it'll take you a couple of hours, some good tools and some serious ingenuity to get to where the parts are but problem solved. It'll still ratchet when picking up a sock or dog toy or something, but sitting there ratcheting on short dense carpet is unacceptable. Hope this helps!!!
Posted on Apr 30, 2012
chris pursloe
  • 372 Answers
Hi.
Check that brush roller (beater bar) is free to turn with no obstruction.
If it is still noisey after doing this try this site for Dyson repair manuals.
http://dysonmanuals.inc.io/
Chris.
Posted on Nov 19, 2007
My bissellpro heat is making a loud noise as I clean carpets. What can I do?
You have to find out from where the noise are coming (motor or from the front of the cleaner )
Motor- bearings or something gets in the fans of the motor
Front of the cleaner- check roller and holders at the end and 2 plastic covers true which cleaner sucking from carpet. That plastics sometimes get broken and vibrate
Oct 02, 2017 | Vacuums
Vacum has suction, but won't pull debris from the floor
The vacuum may not be set for use on carpet.
Jan 19, 2017 | Vacuums
Vacuum not picking up
Try plugging the hose that goes to brake booster and see if the noise stops couse it seems to me it has a leak..if not spray carb cleaner around the vacume hoses while it is running and where the leak is will couse the idle to go down..
May 10, 2013 | Vacuums
My Hoover vacuum cleaner is not picking up from the carpet like it used to. Like it's having difficulty picking up strings, fuzz, etc. from the carpet. Suction power seems to be fine. The belt and the...
YOUR VACUME SHOULD HAVE A HOSE THAT PLUGS INTO THE LOWER PART OF THE VACUME OR MAY COME APART AT THE BOTTOM . IT SOUNDS LIKE THE TUBE IS STOPPED UP AT THE FAN MOTOR
Jan 16, 2011 | Hoover Vacuums
While vacuuming a rug on high (carpet setting) the power suddenly decreased. Now it will only run with low power, not picking up items on carpet
It sounds like you burned the belt. Turn the unit over, remove the cover plate where you see the brushes. On the side of the brush roller is where the belt is located. The belt should be very tight on the roller. Also, you may see little black rubber pieces stuck to the area where the end of the roller is or in the part where the belt runs. Get your owners manual out and read how to change the belt. I'll bet when you ran over the carpet it hung on some of the nap and hung the brush roller up for a second or so. That's all it takes sometimes to fry the belt on some vacumes. Sometimes new vacumes come with a new belt. Look in the bag or box and install it.
Mar 08, 2010 | Eureka 2991AVZ Bagless Upright Cyclonic...
POWERMATE HEAD DOESNT SEEM TO HAVE GOOD SUCTION AND IS LOUD
suction wise have you checked the internal pipes on your vacum as for the load noise if it is quite a load noise a humming noise it is ure motor so not worth fixing motors r pricey for a vacum
Feb 03, 2010 | Kenmore Vacuums
Makes a loud noise when vacuming carpet
if it roars you probly need a impeller
Oct 12, 2009 | Vacuums
Makes a terrible loud noise. It hurts my ears.
time to check your filters
if you bought it used check your hoses also
some people think sunp pump hose is just like vacume hose but man does it whistle (almost enought to pop your ears loud )
Jul 29, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Beater bar not engaging,
The belt is in tact, but the beater bar will not rotate
Jan 25, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Kirby G6 drive mode
look under the vacume cleaner and take off the cover make, shure the belt is where it needs to be, you should have a setting on the vacume cleaner that gives you an addjustment for the carpet your on, raze it up.
Nov 26, 2007 | Kirby G6 Bagged Upright Vacuum
Dyson DC14 Full Access Bagless Upright Cyclonic Vacuum Logo
978 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Nick Olsen
Mike
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
