Question about GE JES1855 Microwave Oven
How doI change the power on my microwave?
My microwave works by it takes a while to heat up food. I would like to change to a stronger power.
Posted by margaret8099 on
mohammed marika thambi
    President:
  • 1,952 Answers
  • Press "Time Cook" or "Micro Cook."
  • Enter cooking time.
  • Press "Power Level".
  • Select a desired power level 1-10 (default is 10).
  • Press "Start"
Posted on Jul 06, 2009
Microwave oven is not heating food power level can;t be changed at this time
That shows triac semiconductor is working fine, the problem is the magnetron, "heats food" cracked high voltage diode or a shorted high voltage capacitor.
Mar 21, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
Not heating
Hello
Power Supply
Check whether there is a proper power supply. Look to see whether the cord is connected to a grounded 3-prong outlet and the cord is fully plugged in. If the electrical system is built-in and no power cord is visible, replace or reset the household fuse or circuit breaker.
Microwave Functions
Some basic microwave operational steps may affect whether the microwave is heating. Open and close the microwave door, as the unit will not function with the door open, and push "Stop/Clear" to cancel any previous settings, such as the timer, which do not heat the microwave oven.
Setting the Microwave
Once the power to the microwave has been reset, or verified as working, and the microwave is ready to run, select a new cook cycle and press "Start" to see if the microwave begins to run and cook food as expected. Allow the food to cook for the alloted time and then open the microwave door and check to see if the food has cooked or heated. Choose a longer cooking time and restart the microwave if food is heating but is cooking slowly.
Repair
If all efforts to troubleshoot the function and power to the microwave still do not get the appliance heating food as expected, there may be a repair issue that needs to be addressed. Contact professional technician for advice.
Oct 05, 2011 | Sanyo Microwave Ovens
My microwave is not heating up food. The timer works and the exhaust blows, but does not heat food.
hello mam please check the power supply at the magnetron which emits the heat and if the supply is normal change the magnetron so please call the engineer he will do it.
Oct 08, 2009 | Microwave Ovens
The microwave stopped heating the food. Power
The light inside the micro wave needs to be replaced most have a door on the back side that yo can remove the screw and unscrew the bulb and take to a applince shop and purchance a new one to replace.
Jul 16, 2009 | Whirlpool GH4155XP Microwave Oven
Microwave has works but doesn't heat
Sounds like the Magnetron has stopped working. The Magnetron is is a specially designed powerful magnet that generates the high frequency microwave energy used to heat food.
Jun 14, 2009 | Magic Chef CMV1000B Microwave Oven
No heating
Sounds like the magnetron has failed. This is the component that produces the microwaves that heats the food.
The cost of the magnetron is about 95% of the cost of a microwave oven. Most people don't, for this reason, replace the magnetron, they replace the whole oven which is probably what you will end up doing.
There is a possibility that the circuit that provides power to the magnetron is faulty and you need to take it apart, find the proper electrical leads and test them with a volt meter. To do this you have to remove it from its mounting and take it apart. It is a fairly lengthy process however.
Benjamin
May 26, 2009 | Kenmore Microwave Ovens
Does not heat up food
Benjamin
May 26, 2009 | Frigidaire FMV145K Microwave Oven
Microwave doesn't heat food anymore
Benjamin
Apr 21, 2009 | Frigidaire PLMV168 Microwave Oven
Food not heating in microwave
Magnetron tube probably failed. Depends on how old the microwave is. If its still under warranty, call Frigidaire. If not, take it to a repair shop, get an estimate, and compare it to a new one. It'll probably be cheaper to buy a newer one that will have more power, but check anyway.
Dec 18, 2008 | Frigidaire FMV145K Microwave Oven
GE JES1855 Microwave Oven Logo
559 people viewed this question
Top GE Microwave Ovens Experts
gbob59
randymanfive
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
