Pentax Optio 555 Digital Camera Logo
Question about Pentax Optio 555 Digital Camera
Does the Pentax Optio 55 take the scan disk 8gb sdhc memory card.
Posted by gwaugh1 on
Anonymous
    Brigadier General:
  • 4,090 Answers
NO! its maximum is 2gb. Also using high capacity cards slows the recovery down between shots, stick to smaller value cards for speed of access
Posted on Jul 06, 2009
3helpful
SDHC 16 GB memory card compatible with Pentax Optio 450
No, you cannot use SDHC cards with the 450. You can only use MMC and SD cards, 2GB and smaller.
2answers
After i turn on my Optio E10, it shuts off right away even after i put in new batteries.
Sounds like a memory card problem. Try using A 512mb San Disk SD Card. Not a San Disk SDHC card. see if that doesn;t help you out. Good-Luck
I put an 8GB microsd card (with an microSD to SD adapter) in may Pentax OptioX and when I open my camera, I have a short delay, then I receive an 'Memory card error'. What's the problem? Thank you.
The S5i uses SD cards. This means you can use microSD cards with an adapter. However, your 8GB card is actually a microSDHC card, which with the adapter appears to the camera as an SDHC card. SDHC cards are electronically incompatible with SD devices and will not work. You need to use SD and/or microSD cards, which max out at 2GB in size.
3helpful
Can a pentax optio S5i support a 8GB memory card? Do I need to download a driver to support an 8GB memory card/
No the Pentax Optio S5i does not support an 8gb memory card.
8gb would be an SDHD card, the S5i came out before SDHD so it does not support them.
Standard Secure Digital Cards come up to 4GB in size so you could use one of these. The highest standard card I have is 2gb and that is fine in mine.
My S5i locks up if you put an SDHD card in.
The only firmware update that Pentax supply does not effect this, SDHD needs different hardware.
4helpful
Inserting either a 4Gb or 8Gb SD card results in a "Memory Card Error".
The S4 accepts SD and MMC cards. SD cards max out at 2Gb. The 4Gb and 8Gb cards are actually SDHC (Secure Digital High Capacity) cards, not SD cards, and thus will not work in devices designed for SD cards. Compatibility goes only one way--SD cards will work in SDHC devices but not the other way around.
Pentax Optio MX4 won't read my new SDHC 4gb
Does the camera work with any other card? Was the card formatted in the camera? Some cards from some manufacturers just don't work in some cameras.
Sdhc memorty card in a pentax optio e10 camera
The E10 works with SD cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work. You need to use SD cards 2GB and smaller.
Top Pentax Cameras Experts
David Shaub
Marvin
Marvin
Steven Wander
Steven Wander
Are you a Pentax Camera Expert? Answer questions, earn points and help others
