Game Boy Advance SP - Charging Light Won't Display
If the orange-colored charge light on your Game Boy Advance SP is no longer coming on when the A/C Adapter is connected to your system, please use the following troubleshooting steps.
Troubleshooting Steps:
Make Sure the Game Boy Advance SP Isn't Already Fully Charged If the battery is already fully charged, the light will not display when the system is plugged into the AC Adapter. Play a game without using the AC Adapter for at least 10-15 minutes, then plug the AC Adapter in, to see if the light comes on. If it does come on, the battery was fully charged. If the light still does not come on, see Step 2.
Make Sure the Outlet You Are Using Works Plugging another electrical device into the outlet is a good way to check if the outlet works, or that the outlet you are using is not controlled by a nearby light switch. You may also want to try a different outlet.
Try a Different Licensed AC Adapter If the charging light doesn't display, try a different AC Adapter, if possible, to determine if perhaps the problem is with the adapter.
If a different AC Adapter works, you will need to get a replacement AC Adapter from our Online Store, or by calling our Consumer Service Department at 1-800-255-3700.
If a different AC Adapter doesn't work, or if a replacement AC Adapter is not available and the lights will not display, we recommend having your Game Boy Advance SP repaired. Check out our convenient repair options.
Note: Please be sure to include both the Game Boy Advance SP and the AC Adapter with any repair
Not for the Wii. There is an Animal Crossing title in development for the 3DS handheld which is being released next year. Check out IGN's preview for it here: http://ds.ign.com/articles/109/1098788p1.html
you need to buy a special adapter that hooks into the bottom of the gamecube and you also need the disc for it.after that you just need to put a game boy advance game into the special adapter and put the disc in the gamecube and turn it on.that is how you play game boy advance games on a gamecube.
It's pretty simple actually. Just look at the bottom of your Gamecube and you'll see a bunch of ports that are covered by removable pieces. Remove them, and fit the Game boy player into all the ports. Like a jigsaw piece, it will fit, make sure the cartridge slot is underneath the controller ports. Enjoy the game boy player, its quite fun, I loved mine when I used to have it on my old GC, until it got stolen.
I do not think i fully understand your problem, do you have a game boy, the hand held system? or larger Gamecube? If it is the small game boy, You do not hook it to your system. there is an adapter that fits in the Super Nintendo System that will hold and Play game boy games. It is called Super BOY.
If it is game cube and has a/v audio/video plug ends, you need a converter from Radio shack that converts those 3 colored wires to the same cable the you use for your cable input to the tv.
What game do I put in for the Game boy?
