Question about Garmin nuvi 205W GPS Receiver
Remove a map to make space on my garmin nuvi 205
I need to remove the european map so i can download the north american map onto my garmin nuvi 205
Posted by markbodha on
  • markbodha Jul 06, 2009
    Yeah, that's the last resort, but I didn't want to lose all the favourites and points of interest etc. we've already loaded in.
    Thanks though.
  • Anonymous Mar 12, 2014
    remove battery garmin nuvi
superdave1
  • 156 Answers
I would reset the whole unit to factory specs & then load map.
Posted on Jul 06, 2009
My gps is set on peru and i am in the us, the gps can not find the maps of us. thx ziv
You'll have to load the North American maps into the unit. Go to www.garmin.com and register your unit with the site. You will then be able to purchase the north american maps and download to your unit using the Garmin updater on the site. The maps are all serialized to work with each unit ID, so a North American map on another user's Garmin will not work on yours (it is Garmin's proprietary copy protection system).
May 23, 2011 | Garmin nuvi 250W GPS Receiver
I just bought a Europe map from garmin for my nuvi 1300 and when I try to download it I get the message "insufficient Space". I have a North America map on my Garmin that I am not using at the...
Yes you do have to remove the North America map, I was just checking on the specs and they do not list that it supports a memory card so unfortunately due to the lack of available space on the solid state drive that comes built into this unit you will have to do the map switchover.
May 18, 2011 | Garmin Nuvi 760 Handheld GPS Receiver
My nuvi 3760T does not have enough space to load europe map. Can I remove preloaded north america map and reload at a later date without losing it?
If you have the map downloaded from the garmin website to your computer you could remove it and replace it later. However a better option might be to download the map of Europe to your computer and install it to a micro SD card. A 4 Gb card would hold the map of Europe and you don't risk losing your North America map. You can get details of how to set up the map on your micro SD card at http://www.fixya.com/support/r5628920-update_garmin_satnav_maps
While this link is mainly about how to update your maps it has a section on setting up maps on an SD/Micro SD card also.
Mar 26, 2011 | Garmin GPS
Can i download maps of germany,switzerland and france onto my Garmin Nuvi 255 now that it already has australia and nz on it
You can, but...
You'll need to load the mapping onto a removable memory card, as your device's memory isn't large enough. Adding a memory card with additional maps really slows the machine down, painfully so. Buying the European mapping pack isn't cheap: you can buy a brand new satnav with full European (including UK and Eire) mapping preinstalled for about the same price. Click here for a current example, but there are cheaper ones if you abandon Garmin in favour of Medion or other brands.
It works out even cheaper if you sell the old satnav to fund the purchase of the new one. When you need the Oz/NZ mapping again you can do the same thing again as by then your original unit will probably have out of date maps anyway.
Please take a moment to rate my answer.
Jul 22, 2010 | Garmin nuvi 255W GPS Receiver
USA Garmin nuvi 200. Can I download Ireland map?
You will have to buy a version of European maps. After you download them into your Garmin it will work just like in the US.
Here is a link I found for you. It looks like you need to buy all of Europe but there may be a way to just buy individual countries. Best wishes on your trip.
Wide and way cool, nüvi 200W shows you the way with detailed maps on a bright ... Garmin Garage" vehicles compatible (download car-shaped icons to your device ): yes ... nuvi 200W, Eastern Europe, 010-00656-25. nüvi 200W, Italy, Greece ...
https://buy.garmin.com/shop/shop.do?pID=9122
Aug 17, 2009 | Garmin nuvi® 200 Car GPS Receiver
Nuvi 205 can't unlock maps after North America 2010 download.
FIXED:
Got a response from Garmin that didn't help much. Called Garmin today and asked to be matched with a software person for a "xml map" problem. They are aware of this problem, and will be able to remote into your computer and fixed it for you.
The problem is that the installer will install us and canada maps, when the 205 cannot support the canada maps. The old 205s didnt have as much storage space, so the installed never transferred over canada. The new 205s have twice as much storage, and the installer thinks it is helping you out. They will be working on a new installer, until then a Support rep needs to run some batch files to fix the issue.
Apr 10, 2009 | Garmin nuvi 205 GPS Receiver
Nuvi 660 MapSource
Henry,
You cannot replace American maps with European maps.  Garmin does this in order to protect the European retailers.  The European SD card eliminates the need to load the maps into the 660, however, if you need to use the card slot to store extra data such as MP3s then you might be better off buying the 670.
Oct 28, 2007 | Garmin Nuvi 660 GPS Receiver
Downloading North American Maps
Did you purchase a preprogrammed sd card or did you get software to download into your PC?
If you are downloading and need to enter unlock codes, avoid using Garmin's unlock wizard.  I generally have better luck unlocking from their website.
Oct 25, 2007 | GPS
Garmin nuvi
Go to the tool icon, then "Map", then "Map Info" and make sure that there's a check mark next to "City Navigator Europe" and none next to "City Navigator North America."  You can add or remove check marks simply by touching the screen where needed.
The Nüvi will then ask "What Country" first.
I had the same problem and just called tech service.  Bon voyage!
Sep 10, 2007 | Garmin nuvi 350 GPS Receiver
Garmin nuvi 205W GPS Receiver Logo
1,126 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Sheldon Dedek
Janelle Schoonover
Janelle Schoonover
Are you a Garmin GPS Expert? Answer questions, earn points and help others
