2013 KX 250f will not start when gets hot. Push start when hot runs great. Already adjusted valves did not change. Cranks up great when cold
SOURCE: i have a kawasaki kx 500 and it is getting too
Is the fuel running into the engine with it not running? If it is then you will have to remove the carb and clean out the float bowl. Check your float height and clean out the body. If the engine is running fine, you won't have to adjust any screws. If you want to decrease the amount of fuel running through the body then you would have to lower the main jet needle. Thats the one in the slide. Moving the C clip up will decrease the fuel and moving it down will increase the fuel. The large screw on the outside of the carb only moves the slide up and down for idle setting. The small screw at the back is for air movement through the carb for the high idle. The only other adjustments that can be made is changing out the jets for larger or smaller ones. Hope this helps.
SOURCE: i am looking to purchase a 2007 kawasaki kx250f
Just call your local Kawasaki dealer, or any Kawasaki dealer, and give them the VIN number and they can look it up and tell you EXACTLY what the bike is. If you call a local dealer they may know the current owner and the bike's history.
Simple thing but easy to overlook. Could I get a 4 diamond rating for this solution? I am 3 short of 100 correct answers. Thanks!
SOURCE: i have a 2005 kx 250f backfire and no start
Chances are when the OHC was installed it was one tooth off on the timing. You have spark and gas and the bike is a single cylinder so that is what I would check. Slack in the chain tensioner is what usually creates the problem. All slack should be at the back side of the cylinder.
SOURCE: have an 1995 xr250r and it won't start.
Low compression can cause this. Insufficient valve tappet clearance is the most common cause of low compression on this engine. So, check the compression and, if it is lower that about 130 psi, have the valves adjusted.
Also make sure the kick starter actuated compression release isn't sticking after the kick starter is operated.
Another thing that can cause it to be difficult to start is a plugged up carburetor. If the bike has ever sat for more than about a year, then the carburetor needs to be disassembled and cleaned out.
