Question about Dell Dimension 8250 PC Desktop
Hardware upgrade required for autocad 2009
I have Dell 8250 with pentium 4 processor at 2.40GHz with 533MHz system bus/512K L2 Cache.Existing 512 MB RIMM.Ram. The existing machine mother board has slots for only 1.5MB Ram upgrade.
Minium hardware requirements for autocad 2009 as follows
Intel Pentium 4 processor or AMD Athlon 3.0GHz or greator.
2GB ram DDR2 SDRAM DDR2 1066.
New Mother board :MSI K9A2 Platinum AM2+/AM2 AMD 790FX ATX AMD
Workstation class graphics card: PNY Quadro FX570 256MB 128-bit GDDR2 PCI Express x 16 workstation Video Card
Basic questions: Will Existing CPU work with the new mother board and graphics card and new DDR2 Ram.
Thanks
Jerry Fitzsimmons
Posted by gfitzs8394 on
  • gfitzs8394 Jul 06, 2009
    Is there another mother board that will allow me to use the existing Pentium 4 CPU with the new Qudro FX 570 graphics card and 2GB new RAM requirements for autocad 2009.
    Thanks
    Jerry Fitzsimmons
    is
ultimitloozr
  • 489 Answers
Your existing CPU will not work with that motherboard. The AM2+/AM2 processor slot is for AMD processors only. For this motherboard, you will need one of the following processors: Phenom FX / Phenom / Athlon 64 FX / Athlon 64 X2
Posted on Jul 06, 2009
Cpus it can handle
Hello here is some info:
http://www.dell.com/downloads/global/products/optix/en/spec_optix_gx520-gx620_en.pdf
You need a pdf reader (adobe) to read the content.
Intel 945G chipset with Intel Pentium 4 processor with 800 MHz front side bus and Hyper-Threading and up to 2MB of L2 cache and Celeron D processor with 533MHz and 256K L2 cache.
Intel Pentium 4 800MHz FSB socket T with HT, XD, EM64T, and 1MB L2 cache (5xx series)
The homepage is here:
http://www.dell.com/support/troubleshooting/us/en/ussoho1/Product/optiplex-gx520
Try also to call the dell support in your country for more qualified answer.
Good luck
Nov 25, 2012 | Foxconn Dell Gx520 Ls-36 Rev A01 Pentium...
What type of dual core processor can I use for my dc7600?
The motherboard for the dc7600 has an Intel LGA775 processor socket. However, not all LGA775 processors are compatible with the motherboard. For the small form factor, the following CPUs are supported: Intel Celeron D Processors:
Intel Celeron D 331 Processor (2.66-GHz, 256K L2 cache, 533-MHz FSB) , Intel Celeron D 336 Processor (2.80-GHz, 256K L2 cache, 533-MHz FSB) , Intel Celeron D 346 Processor (3.06-GHz, 256K L2 cache, 533-MHz FSB)
Intel Pentium 4 Processors with HT Technology:
Intel Pentium 4 521 Processor (2.8-GHz, 1-MB L2 cache, 800-MHz FSB) , Intel Pentium 4 524 Processor (3.06-GHz, 1-MB L2 cache, 533-MHz FSB) , Intel Pentium 4 541 Processor (3.2-GHz, 1-MB L2 cache, 800-MHz FSB), Intel Pentium 4 620 Processor (2.8-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 630 Processor (3.0-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 631 Processor (3.0-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 640 Processor (3.2-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 641 Processor (3.2-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 650 Processor (3.4-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 651 Processor (3.4-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 661 Processor (3.6-GHz, 2-MB L2 cache, 800-MHz FSB) or
Intel Pentium D Dual Core Processors:
Intel Pentium D 805 Dual Core Processor (2.66-GHz, 2x1MB L2 cache, 533-MHz FSB), Intel Pentium D 820 Dual Core Processor (2.8-GHz, 2x1MB L2 cache, 800-MHz FSB), Intel Pentium D 915 Dual Core Processor (2.8-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 925 Dual Core Processor (3.0-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 930 Dual Core Processor (3.0-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 940 Dual Core Processor (3.2-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 945 Dual Core Processor (3.4-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 950 Dual Core Processor (3.4-GHz, 2x2MB L2 cache, 800 MHz FSB)
Unfortunately, these are old processors and I don't see any available new. Newegg.com lists a couple available as refurbished. You may be better off getting a new computer with either a Intel I3 or current AMD processor.
I wish that I had better news for you.
(do not attempt to use a CPU that your motherboard doesn't support. It probably won't boot.)
Mar 30, 2012 | HP Compaq dc7600 Small Form Factor PC...
I can't install AUTOCAD 2009 in my windows XP computer.It asks to install direct 3D
Most probably your hardware ie graphic card do not support software requirements.
Autocad 2009 system requirements for Win XP.
32-bit AutoCAD 2009
Running under Windows XP:
•Microsoft Windows XP SP2 operating system
•Intel® Pentium® 4 processor or AMD Athlon®, 2.2 GHz or greater
or
Intel or AMD Dual Core processor, 1.6 GHz or greater
•1 GB RAM
•750 MB free hard disk space for installation
•1024x768 VGA with true color
•Microsoft Internet Explorer 6.0 (SP1 or higher)
If you are using AutoCAD for 3D modeling, you should bump up your system as follows:
•Intel Pentium 4 processor or AMD Athlon, 3.0 GHz or greater
or
Intel or AMD Dual Core processor, 2.0 GHz or greater
•2 GB RAM or greater
•2 GB of additional free hard disk space
•1,280 x 1,024 32-bit color video display adapter (true color) 128 MB or greater, OpenGL or Direct3D capable workstation class graphics card.
Hope it helps.
Mar 22, 2011 | Computers & Internet
I can upgrade to windows 7 in my n1000
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Personally i would recommend to upgrade ram then install win 7
Regards
Uttam
Windows 7 requirement If you want to run Windows 7 on your PC, here's what it takes:
  • 1 gigahertz (GHz) or faster 32-bit (x86) or 64-bit (x64) processor
  • 1 gigabyte (GB) RAM (32-bit) or 2 GB RAM (64-bit)
  • 16 GB available hard disk space (32-bit) or 20 GB (64-bit)
  • DirectX 9 graphics device with WDDM 1.0 or higher driver
http://www.microsoft.com/windows/windows-7/get/system-requirements.aspx
Here is you laptop spec
Processor Processor Intel Pentium M 733 / 1.1 GHz
  • Core voltage technology Ultra Low Voltage (ULV)
  • Data bus speed 400.0 MHz
  • Processor features Enhanced SpeedStep technology , Power-optimized processor system bus
  • Chipset type Intel 855GME
Cache Memory Type L2 cache
  • Cache size 2.0 MB
RAM Installed Size 512.0 MB / 2.0 GB (max)
  • Technology DDR SDRAM - 333.0 MHz
  • Memory specification compliance PC2700
Video Graphics Processor / Vendor Intel Extreme Graphics 2
  • Video Memory Dynamic Video Memory Technology 2.0
Operating System / Software
  • OS Provided Microsoft Windows XP Professional
  • Software Drivers & Utilities
Dec 10, 2009 | Averatec 1000 Notebook
Which HDD Supported To Acer4710z Laptop
Acer Aspire 4710 General
  • Built-in Devices Stereo speakers , Wireless LAN antenna
  • Width 13.5 in
  • Depth 9.7 in
  • Height 1.7 in
  • Weight 5.7 lbs
  • Color Black/light gray
  • Localization United States
  • Notebook type Thin-and-light (4-6 lbs.) , Budget
  • Screen type Widescreen
  • Wireless capabilities IEEE 802.11b , IEEE 802.11g
Processor
  • Processor Intel Pentium Dual Core T2080 / 1.73 GHz
  • Multi-Core processor technology Dual-Core
  • Data bus speed 533.0 MHz
Cache Memory
  • Type L2 cache
  • Cache size 1.0 MB
RAM
  • Installed Size 1.0 GB / 4.0 GB (max)
  • Technology DDR2 SDRAM - 667.0 MHz
  • RAM configuration features 2 x 512 MB
Storage Controller
  • Storage controller type Serial ATA
  • Storage Controller / Serial ATA Interface Serial ATA-150
Storage
  • Floppy Drive None
  • Hard Drive 120.0 GB - Serial ATA-150
  • Storage Removable None
  • Hard drive type Portable
May 30, 2009 | Computers & Internet
Upgrade for a Ti4200 Graphics Card
i think the best graphics card you can get for your pc cause its AGP slot is a 6200 from nvidia.
May 15, 2009 | Matrix 226R (VPR226R) PC Desktop
Can i upgrade my processor from 1.9ghz to 2.8ghz?
According to Acer's website sepcifications, that Laptop is only upgradeable to 2.3GHz:
http://www.acerpanam.com/synapse/forms/portal20.cfm?recordid=606&formid=3404&website=AcerPanAm.com&siteid=7117&words=all&keywords=&areaid=2
AMD Turion 64 X2 dual-core mobile technology TL-66/TL-64/TL-60/TL-58/TL-56 TL-52 (2x 512 MB L2 cache, 2.30/2.20/2/1.90/1.80/1.60 GHz, 1600 MHz HyperTransport Bus),
AMD Turion 64 mobile technology MK-36/MK-38 (512 KB L2 cache, 2/2.20 GHz,), supporting AMD PowerNow! technology and AMD HyperTransport technology or
AMD Athlon 64 X2 dual-core mobile technology TK-53/TK-55 (2x 256 KB L2 cache, 1.70/1.80 GHz), supporting AMD PowerNow! technology and AMD HyperTransport technology
Apr 17, 2009 | Acer Aspire 4520 Notebook PC
Dell optiplex p4 1.8ghz: RAM
Best and easiest thing to do is go to www.crucial.com and run a scan of your computer. It will tell you what you have, how much it will hold, and what kind of modules.
Yes, it's safe.
Thanks for using Fixya!
If you have any trouble, comment back.
Jan 28, 2009 | Dell OPTIPLEX GX240 P4 1.8GHz 512MB 20GB...
Is my laptop core2 duo
Hi
I am a Dell Certified System Engnieer(DCSE)
the best option would be you check it yourself
what you have to do is log on to this link
www.support.dell.com
on the left hand side you will find an option warranty information
then click on warranty status
putin your system's service tag
your system's service tag located at the bottom pannel of your system, turn it upside down you will find a bar coded sticker which has a 7 digit alphanumeric number
then press enter
then click on the option orignal system configuration
whatever you see here is there in your system.
Jun 10, 2008 | Dell Inspiron 1501 Notebook
GATEWAY 7330GZ PC NOTEBOOK
This link will provide you the required information.
Specifications
Part Number: 4997Gateway 7330GZ Notebook
System Gateway® 7330GZ Notebook Processor Mobile Intel® Pentium® 4 Processor 532 with HT Technology
(1MB L2 Cache | 3.06GHz | 533MHz FSB) Determine Your Processor Speed
Chipset Intel® 852GME Screen 15.4-inch Widescreen Ultrabright TFT WXGA
  • Maximum Resolution: 1280 × 800
  • Maximum Color Depth: 32-bit (16.7 million colors)
  • LCD maximum refresh rate: 60 Hz
Memory 512 MB DDR (1 × 512 MB), 333 MHz, DDR
Expandable to 1.5 GB Video Intel® Extreme 2 Graphics
Dynamic Video Memory Technology (DVMT) supports up to 64 MB shared video memory Audio PC2001 Compliant AC '97 Audio
Built-in Stereo Speakers Hard drive 80 GB HDD (4200 RPM) Optical drive DVD +/- RW Multi-Format
  • Write maximum: 8X DVD +/-R, 4x DVD +/- RW, 24x DVD+R DL, 24X CD-R and 10X CD-RW disks
  • Reads maximum: 8X DVD-ROM Disks, 8X DL/+RW, 24X CD-ROM disks
Media reader 6-in-1 Digital Media Manager
Compact Flash, Micro Drive, MultimediaCard (MMC), Secure Digital (SD), Memory Stick, and Memory Stick Pro Modem 56K ITU V.92 ready Fax/Modem Network 802.11g integrated wireless (up to 54Mbps)
10/100Mbps integrated Ethernet LAN Pointing device Touchpad with Vertical Scroll Zone PCMCIA 1 - Type I or Type II; Card Bus Interfaces
  • 4 - USB 2.0 Ports
  • 1 - VGA External Connector
  • 1 - IEEE 1394 port
  • 1 - RJ11
  • 1 - RJ45
  • Microphone In
  • Headphone/Audio Out
Battery 8-cell Lithium-ion Dimensions 1.6-inches H × 14.0-inches W × 10.4-inches D Weight 7.5 pounds (8.65 pounds total travel weight)
Mar 24, 2008 | Gateway 7330GZ Notebook
Dell Dimension 8250 PC Desktop Logo
359 people viewed this question
Lee Hodgson
Lee Hodgson
Ekse
efs_perpends
efs_perpends
