My Uconnect is factory installed on my 2005 Dodge Truck. There are two control buttons on the rearview mirror for the uconnect. For a long time my uconnect would not fully function with my bluetooth phone and then lately it quite working most of the time. I did a bunch of research adn found this procedure to do a hard reset. After doing this the uconnect came back fully and all functions are working. I now this sounds stupid and you feel stupid doing it, but it did work for my vehicle. 1- Turn on ignition w/doors closed 2- Press both buttons on mirror for 15-20 seconds 3- Shut off ignition 4- Open door for 5-10 seconds 5- Close door and restart car, Uconnect is now reset
Step 1: Ring your network provider's customer care helpine phonenumber and ask for the ''unlocking code''(keep in mind that you'll need you IMEI code at this time ready for the helpline,you can get the IMEI code on-screen by pressing *#06#) adn then take out your simcard(once you have the unlocking code from the helpine) and enter your code like this:a. Push #
b. Push * 3 times in a second. (p will show)
c. Push * 4 times in a second.(w will show)
d. Push * 2 times in a second(+ will show)
e. Enter the code from below.
f. Push * 2 times in a second.(+ will show)
g. Enter the code number
h.Push #
Make sure all the lines are hooked up correctly. It is going to take 3-8 hours to fill a 3 gallon RO storage tank. It depends on the capacity of the membrane (IE: 14, 20, 30, 50 or 75 gpd). It also depends on the TDS of the water. Water that has high TDS 500+ppm will take longer to produce product water than TDS of 100ppm. Check the pressure in the RO tank. When empty (In a 3 gallon tank) there should be 7psi pressure. A ten gallon tank takes 10psi. If it needs air you can use a bicycle pump to add appropriate air. Make sure the tank valve is turned off when adding air. Do not use the RO faucet for several hours to allow tank to fill up. Also you should dump the first couple tanks of RO water to make sure any carbon fines are rinsed out. RJ
Pull out the winding stem (crown) when second hand reaches 12 o'clock, set main time by ajusting stem, next press and hold A button "near 9 o'clock" hands will move quickly, when close to matching main time, release A button and press in and out quickly until it matches main time. Next push winding stem in, this will start the main and the sub-hands together for normal time. To set alarm press and hold A button until set time is reached, select B button alarm mode "2 o'clock" for beep or vibra, to turn alarm on/off press C button "4 o'clock" for 1 or 2 seconds, the sub hands will move rapidly until it reaches normal time and alarm will sound 3 times indicating it is set, finally when alarm goes off early in the morning for example you can press any button to stop. To reset alarm press C and it will go back to the original alarm setting.
Hi Friend,
Please folliow the below steps one by one
Step 1: Turn on the TV
Step 2: Hold the ON/OFF Button for 10 to 20 Secs
Step 3:Without taking the hand from the ON/OFF button unplug the power cable connected to the wall outlet from the TV
Step 4:Without taking the hand from the ON/OFF button put the power cable back to the outlet
Step 5:Now take the hand from the ON/OFF Button and try to turn it ON again and check
If still you are having the same problem then please check the resolution configured in the Screen,try to reduce the Colour and the brightness of the TV
Even after that you are facing the same issue please check with the Display Card in the TV,
If you have any Clarification please feel free to contact us
1) Remove ALL cables including the power cable from the back of the PC
2) Hold the power button in for approx 20 seconds (yes i know there is no power going to it)
3) Plug everything back in and retry
From what you are saying the above should cure the fault, however if it doesnt then the next option is too book the PC in as it seems there may be a motherboard/PSU fault
If this has been useful please leave postive feedback/vote/testimonial - Thank You Again
on my dell monitor i sometimes have to press the '+' button which is next to the power button, then press the power button. for some reason this helps.
This might be a possible tank pressure issue. This could also be a clogged filter. I would first check the tank pressure by using the following steps
Necessary Supplies: 1) Tire Gauge marked in 5psi increments (ie 5, 10, 15, 20psi, etc.) 2) Bicycle tire pump for standard type bike tire valve
To recharge RO System Tank:
1) Close cold water feed valve (valve located at some point along the cold water line from street plumbing).* 2) Leaving RO tank valve on, turn tank on side & locate valve stem on bottom side. 3) Remove stem cap. 4) Drain all water out of tank through open RO faucet into sink. (Continue to leave RO faucet open throughout procedure) 5) If current tank pressure is insufficient to empty tank, apply tire pump to valve stem and pump 10 – 15 times. Exit flow will increase and then gradually decrease as pressure equalizes. Do not overcharge internal bladder of tank during this procedure. 6) Repeat step #4 until tank is completely empty. (Tank is empty when additional pumping produces no more water) 7) At this point, adjust EMPTY tank to exactly 7psi. (Gauge reading midway between 5 & 10psi is sufficient) 8) Turn off RO faucet. 9) Replace cap on valve stem and reposition tank in upright position. 10) Open cold water feed valve.* 11) System water is useable immediately, however, tank will take 3-4 hrs to completely refill.
FreshWaterSystems.com: The Water Super Store: 1-877-335-3339
get in your car and put key in ignition turn 1 turn then wait approx 15 20 secs for light in clock to go red then take key out light should stay lit, next get out of your car close door then lock it and open it, when u open car light in clock should flash 3 times, next get out of car hold lock button on your remote down and push open button 3 times (keeping lock button down and remote pointed at reciver) next lose go of both buttons and red light on key should flash 3 times at the same time as clock inside the car.
next get in your car with key! then start her up and turn off get out of car close door and push button to lock (it should lock) if not get back in start her up again and turn off, then push the door locks inside the car then open get out and your car will lock this time!!!!!!!
