Question about Porter Cable Cable Commercial Pressure Washer PCH3200
Porter Cable pcv2250 pressure washer shooting water out of siphon
I have water shooting out of the siphon valve barb at the water out. I took the valve out and put back in with no success. Any suggestions?
Posted by murray_jeffr on
andy just round the corner
    New Friend:
  • 47 Answers
Non return valve on syphon injector on high pressure outlet stuck or 'o' ring worn. remove barb should be a spring and ball bearing in there.
it may be that the spring has broken too.
new non return valves are available.
Posted on Jul 18, 2009
Water backs up in the soap reservoir when using the pressure washer
Sounds like a bad check valve or hooked up wrong the soap should siphon in could valve fitting be in backwards, or in wrong place I use a separate siphon valve that fits between pump out let and high pressure hose.
May 10, 2015 | Garden
Why is water continuously coming out of the thermal relief even when the water is cold?
if your pressure is satisfactory then you will need to replace the thermal relief you can plug the port as long as the pump is unloading fine when trigger is released an get a replacement asap thermal relief valve will open when the gun is released for a long duration of time over three minutes.detergent valve inside the barb you may have to assist the ball bearing inside it might be stuck to the o-ring and the siphon it produces is not sufficient enough to cause separation.you can insert a nail small enough and slowly insert it inside the port til you feel it separate.
Aug 18, 2014 | Garden
Soap dispenser not working
chemical injector activates only when low pressure is utilized try this remove hose from triggergun assembly with the water turned on engine off allow water to free flow out of hose remove the chemical hose from the barb located at pump with a paperclip or needle insert it into the hole of barb and slowly separate the ball inside the barb you should here it siphon and try not to look directly at the port you may get sprayed once freed reinstall all back together and try again.;0;0
Aug 02, 2013 | Karcher Garden
Water stopped coming out while using it. viewing port on right side shows a red dot in center.
The most common cause of this is the pressure regulating spool valve sticks in the bore. As the pressure builds with the wand closed, the spool moves against a spring to block additional water from entering. When wand is triggered, pressure drops and more water is admitted. Remove the spool and clean the bore with crocus cloth on a dowel rod. Replace the O Rings on the spool and lube with a bit of plumber's grease and re-assemble. Often you can get a kit of O Rings for the washer or you can get EXACT replacements at a supplier... they MUST be the exact size as the originals.
Jul 27, 2011 | Porter Cable Cable Premium Pressure Washer...
Engine manual for the Porter Cable pcv 2250 pressure washer
If you need an engine manual, then look up the manual on the engine manufacturer's web site. eg Briggs & Stratton, Honda, Techumseh. Porter Cable manual would just have cart and pump info.
Jul 23, 2010 | Porter Cable Cable Commercial Pressure...
Air Leak From Pump Head on Porter Cable C2001 Pancake Compressor
The real question is where exactly is the leak coming from. Compressors have a pressure release valve designed to let the pressure off of the compressor motor so it can start when there is pressure in the tank. This valve is often the culprit and fairly easy to replace. You can order it direct from porter-cable online. Just in case double check the drain petcock sometimes these get worn and won't close completely and can easily be over looked when trouble shooting.
Jun 12, 2010 | Porter Cable 18 - Gauge Brad Nailer and...
Washer appears to be leaking towards the top back right..
sounds like your main tub seal is leaking, also check the hose running to your water level switch,,and your outter plastic tub could have a crack in it
Feb 15, 2010 | GE WBSR3140DW Top Load Washer
Pump will not presure up
check your in take screen make sure its not plugged, look for calcium build up. then check your valve there should be six of them. my be damaged or weiring out and or plunged. if all looks good you'll need to check your unload-er valve. check your oil to make sure no water is in there, ok. good luck, let me know.
Oct 16, 2009 | Porter Cable Cable Commercial Pressure...
Hot water coming out of a cold water pressure washer
This sounds like a heat transfer problem
You should check that the oil reservoir for the pump has oil in it. It sounds like it may be low. Also, if it is a gas model, the engine oil may be low.
Remember the pump oil reservoir should be only 1/3 to 1/2 full of non-detergent oil.
Aug 10, 2009 | Porter Cable Garden
Porter Cable Cable Commercial Pressure Washer PCH3200 Logo
639 people viewed this question
Top Porter Cable Garden Experts
JOHN LAPIER
ray gallant
Are you a Porter Cable Garden Expert? Answer questions, earn points and help others
