Yvonne, the printer has no timer on it on. Check your driver settings on your computer. Specifically, check your advanced tab in your driver and see that "Always available" is clicked on.
Testimonial: "Thank you Steve, I checked advanced settings and 'always available' is selected. Any other ideas would be appreciated. Thanks for your initial reply, much appreciated,"
I love a puzzle! Let's get started.
1. Is the printer on? This may appear to be a silly question, but it is not. Outside factors may effect the answer. Please confirm by
pressing the power button. The power lamp flashes green, and changes to a steady, non-flashing light. If it does not select a different power outlet.
2. Let's print a simple print job from the print driver. Select your driver from devices and printers (I am assuming you are using a Windows O.S.), right click on the appropriate driver, select "Printer Properties", and click on print test page.
If steps one and two do not provide solutions please respond and we will continue our search for the solution
