Re: What year was MED5600TQ0 Maytag electric dryer...
Check the date code on your unit against the chart below to get the mfg date.
Maytag Date Codes
The breakdown for Maytag Serial Numbers is:
1st Alpha Character (9th position) = Year Manufactured
2nd Alpha Character (10th position) = Month Manufactured
MaytagLearn about features and specifications for the Maytag Electric Dryer (MED9600SQ ) ... Manuals & Literature; Product Help; Parts & Accessories; Features ...
125 results like Maytag MDE7600 Electric Dryer Maytag MDG8500 Dryer ... ProductFeatures: Power Source: Electric; Dryer Type: Home Dryer; Load Type: .... Maytag MED9600S Electric Dryer ... Durable and dependable features in this dryer representMaytag brands committment to uncompromising strength and reliability.
You have not mentioned the fault on the dryer as it can be due to no power, a fault in power supply , no program a suspected controller and also no rotation , a possible motor , relay or controller fault. Also if there is no heating check the continuity of the heater coils. if open heater is faulty , if not there no voltage from the controller.
The date code is not indicated in the machine's model number but in the serial number. Look for the serial number plate and the last two letters of the serial number indicates the date code. The serial number is composed of 6 or 8 digit number followed by two letters (example: 12345678ZY). The first letter indicates the year in which the product was produced while the second letter is the month. Refer to the table below to determine the year and month in which the machine as produced.
In the example above, the date code is ZY. The date in which the machine was manufactured is November 1977/2001.
If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
Hi, The first thing to check is the thermal safety located in the back. UNPLUG the dryer. emove the rear panel and locate the fuse on the blower housing middle left. It is white and in 1/4" wide and 3" long with twowire going to it. You can test continuity to it. If it has continuity, it is ok. This is
the most common problem. If II can assist you further, please let me know.
This may be caused by some kind of wash product or softener product. You may be using too much. You can use a blue glass cleaner or small amounts of mild abrasive cleaner and water to try to remove it. Drums are made of porcelain or stainless steel and should 'never' wear out.
