Computers & Internet Logo
A
Amanda Posted on Nov 05, 2014
The module attached to my phone keeps randomly not working than a day or so later( or even a few hours later) it just starts working again. What is causing this?
It is a Model DBM32. 32-button expansion module I am having an issue of it randomly just not working for periods of time. I have had technicians here they have tried a new module same issue. Just stops working for random amounts of time then all the sudden starts working again.
velcrobomb
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Nov 13, 2014
velcrobomb
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
451
Points
Check the connection between phone and module. You may just need to replace the module. Refurbs are just as good as new ones and a lot cheaper.
  • velcrobomb Nov 13, 2014
    Thinking about it a bit more, have you tried the module on another phone? Could be the phone's module connection jack that is causing the problem.
How do you know if the ignition is going out on a 1999 ford taurus
In my case, it just shut down randomly. Wait 5 minutes, then it starts. Few weeks later it happened again, then in a week, then every few days, then half the time.
That's how electronic modules fail on Fords.
Our 2007 Jeep Grand Cherokee randomly won't start.
change the wires that go to the starter i had the same problem fixed now with no problems
2helpful
2answers
My samsung sgh-t819 is not working
My phone did this a few times as well. It went on for a few days, I couldn't answer my phone unless it was closed and I slid it open, couldn't look at text messages, nothing. Finally it died and I recharged it and it started working again.
Later on the phone also would act like I was randomly opening it, so it would light up, causing the battery to die faster. Once it died completely I charged it and it worked fine again. So far it's been a month and it hasn't happened again. Now though my phone stops working where I can't receive calls or text or make calls or send texts. This can last for 20 minutes to 3 hours at a time. I can't wait to get a new phone!!!
The sideview mirror lights and windows have
I am pretty sure it is the body control module. My 02 sable is currently having a similar issue. On a random day my girlfriend took the car to the store, the car started honking when she went to re-enter the vehicle. never done that before. Later that night the left front turn signal will not shut off. the turn signal light on the dash stays on solid, this morning the bright light indicator was on solid and the turn signals worked perfectly fine until the blinker light eventually went back to on all the time. I disconnect the battery at night or if I am not going to drive it for a few hours. But I am 99% certain it is the BCM causing this.
2006 vw jettA 2.5....trouble starting
I had to take my car back to the dealership twice. First, they replaced the ignition switch. 3 days later, my car wouldn't start again. So I took it back and they called VW - VW said to replace the steering column module. I asked my dealer why they didn't replace the steering colum module first - they said that even if they had replaced that first, the old ignition switch would have shorted out the steering column module. Whatever.
$600 later my car has been fine for about 3 weeks now. If it happens again I will keep you posted.
Car Won't Start
If the car is dead, it should not make a sound, this is normal for dead things. Get a live one.
2answers
Invalid filename
I am having the same problem with mine it has even lost all pictures, ringtones and graphics even the default ones. I spent most of the day on Thursday on the phone with AT&T and none of the 10 people that I spoke to could help me they had never heard of this problem before and they said I would have to buy a new phone. I really like this phone and would like to fix it if I can but don't know what to do HELP!!!!
Top Avaya Computers & Internet Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you an Avaya Computer and Internet Expert? Answer questions, earn points and help others
