Question about Ovens
Top oven and Grill do not light or heat up. Problem?
Technician said need to change thermostat and energy regulator. Did not test if grill element is OK because he said thermostat faulty. He did not know top oven has an element. Problem is oven is old and difficult to source top oven thermostat and energy regulator. Someone said it could be problem with the elements and not with thermostat and energy regulator. Easier to get grill element and top oven element. Main oven trips when earthed. 4 hobs work well. Thanks. What should I do? Buy thermostat and energy regulator and later find out it is the elements which are faulty or buy grill element to replace? Thanks.
Posted by lorna lim on
4 Related Answers
mdaeng
  • 18 Answers
SOURCE: Stoves 720EF Top Oven Failed
there is a safety stat/fuse on top of the oven exterior i think you will find that it also has blown. Make sure you have isolated the appliance at the fuse board first though, Good Luck
Posted on Jan 23, 2009
2coolrick
Cool Blue Services
  • 560 Answers
SOURCE: Neff oven not heating have replaced fan element
it has to be the temperature control itself...thats the only other component, aside from the high-heat cut out switch which rarely goes bad.
Posted on Jun 05, 2010
barkencoa
Barry Coates
  • 3463 Answers
SOURCE: The main oven, fan assisted, blew the fan element.
You to check the element with a meter to ensure if you are getting a sapply to it, if you are, then the new element is faulty, if no supply, then probably ythe thermostat is faulty, also check for broken or bad conn ections.
Posted on Aug 14, 2010
Susan Wolding
  • 43 Answers
SOURCE: Grill not working after replacement element - any ideas?
I would say you are right on your wondering. look at your manuel and it will show you a diagram
Posted on May 07, 2012
May 07, 2012 | Zanussi ZHQ575 Electric Double Oven
Stoves 720 EF Electric Double Oven Model No 059040415 -when you turn the grill knob there is no light and it doesn't do anything at all - the grill is not working. However, the element must be working as...
First things first. The oven element is totally separate to the grill element. The clock has to have a time set for either the top or bottom oven to work, whereas the grill will work without the clock being set.
The control knob for the top oven is the ONLY control that will turn the top oven lights on, the grill does not turn the lights on. ( If you want to watch your toast, you have to turn the top oven switch on to the first setting as well as operating the grill control).
To prevent the grill being operated with the door shut, there is a micro-switch on the door hinge that allows the grill to operate ONLY when the door is down. The grill control also does not illuminate unless the door is down. There are two options on the grill control - right or left. One way is the inner element only and the other is both inner and outer ones.
So if you have done all that and it still doesn't work, then the micro-switch could be faulty.
Best of luck
Nov 23, 2010 | Stoves 720EF Electric Double Oven
Zanussi electric double oven. Top oven not working.
It sounds like a faulty thermostat, because when you turn the thermostat on it should supply the oven element and the neon light, so even if the element is faulty, the neon light should still come on regardless of the element working or not.
Hope this helps.
Feb 10, 2010 | Ovens
The element on my grill inside the oven is not heating up?
There are two possibilities of what is wrong here.
One is that the grill element has failed and may need to be replaced.
Second it could be a failure in the grill element control circuit (in effect the temperature regulator) thus not allowing power to the element.
Most likely it will be the grill element.
You would need to test with a multimeter to determine which a) by checking the resistance reading of the element and then b) the continuity of the control circuit.
Jan 20, 2010 | Zanussi ZHQ575 Electric Double Oven
Stoves 720ef grill not working
The grills appear to be independant of each other. Does the oven still work and the oven light come on?
Depending on your answer it could be that the Top Oven Switch has gone faulty. The Grill Regulator and the Switch work together on the top oven. To get at both you will need to take the top of the oven off.
Oct 04, 2008 | Stoves 720EF Electric Double Oven
Grill faulty on my double oven
Creda reflection double oven had the same issue, both ovens work but the grill was either hot or cold, no temp control. I changed the thermostat first, due to being a novice and not fully understanding how things worked. it didn't help so I have changed the grill regulator,( bit that the knob fits onto) and it has solved the issue. I expect this to be the same with most top oven and grill combinations with the oven working but the grill only being hot or off.
Apr 07, 2008 | Ovens
Belling synergie. oven does not heat up. grill ok. think i need to set to manual but how???
if its flashing auto.
Press and hold the 2 buttons on the left hand - clock and cook time and then press the + button.
This then sets the time to allow manual and takes the auto off.
cheers
will
Dec 24, 2007 | Belling XOU592 / XOU593 Electric Double...
Ovens Logo
269 people viewed this question
Top Ovens Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Are you an Oven Expert? Answer questions, earn points and help others
