Panasonic SA-VK680 Won't power on. Ac in light is on bit nothing happens when I press any buttons. I have tried a memory reset the lights and dotted lines come up but it doesn't fix the problem.
Posted by Brayden Grossman on
Tom Chichester
    Top Expert:
  • Audio Player... Master
  • 55,958 Answers
  • Open internal fuse
  • Defective power switch
  • Defective power supply
Posted on Jun 09, 2019
5 Related Answers
jacob5217
SOURCE: Unit will not power on, has the standby light on
I took your advice I unpluged the unit then held the power button in then pluged it back into power outlet the unit came on. There is one thing I might add I had to do it twice before the unit came on. Now how long will it work? Who knows
Posted on Oct 11, 2008
mraviteja
Raviteja Mopidevi
  • 51 Answers
SOURCE: dv2120us keyboard buttons light but screen black, won't boot
Hello Atty
I understand that your Notebook is not powering on. Your Notebooks , that is dv2120us is having a manufacturing defect. So HP accepted that the Notebook will be serviced under the plan "One Time Service Enhancement" . Even if the Notebook is out of warranty your Notebook may be serviced. For more information log on to the chat support .
.http://welcome.hp.com/country/us/en/contact/chat_1.html
They will assist you with the details and the procedure, how to send your Notebook to HP for service.
Posted on Feb 16, 2009
Anonymous
  • 255 Answers
SOURCE: Panasonic SA-PT560
you'll need a tech for this.the pushbutton switches must be corroded or rusted.but there maybe other problems that is related to this.so like i said call a tech.
Posted on May 13, 2009
Anonymous
SOURCE: Panasonic SA-HT740
I had the same problem it took four or five e-mails to find the fans
I found them at the site below
www.pstc.panasonic.com/Epartr/PartsDone.asp
P/N. L6FAJCCH0007 FAN MOTOR (THIS IS THE REAR FAN)
P/N. L6FAYYH0001 FAN UNIT (THIS IS THE SIDE FAN)
Hope this helps
Scott
Posted on Jun 09, 2009
IQUIT
  • 3940 Answers
SOURCE: Dell M1530 wont turn on
A flashing ON ON Lock LED sequence is indicative of a failed Motherboard
Posted on Jul 10, 2009
I Press The power Butten the lights Blink once then it just has this light That looks like a circle with a Z in it stay on and battery light and plugged in light stay on nothing else happens doesn't go any...
I suggest you try a manual reset. Please remove battery and AC Adapter and hold down power button for 30 sec. and then put battery back in and AC adapter and try starting.
Feb 06, 2010 | IBM Lenovo ThinkPad R61i Notebook
No lights no power nothing
Remove the AC Power amd remove the battery..... Press and hold the POwer button in the "ON" position for 20 seconds and let go.
add the ac Power Only and press the power button this should turn on the laptop.
If this does not work you can try reseating the Memory dimms as well
Let me know if this solve syour issues
Oct 14, 2009 | HP Compaq nx6310 Notebook
My inspiron 1520 will not turn on. the power light will stay lit, and the capslock will blink like 45 times, and the nothing happens
Remove the battery as well as the adapter. Then plug back the power adapter only. Try to boot up with out the battery. If it worked your laptop crashed from hibernation or stand by. If not, BIOS might be affected and needs reset.
Hope this helps.
Oct 01, 2009 | Computers & Internet
Notebook will not start.
please check with dell service center. it could be a motherboard problem. or, try to remove the battery and plug the adapter directly on AC power.
Sep 07, 2009 | Dell Latitude D810 Notebook
NO POWER!!!!!!
You can try doing a factory reset, but you will everything.
Press and hold the two soft keys while you press the reset button.
Press R to reset, Q to cancel.
Aug 17, 2009 | HTC PPC-6800 Smartphone
Tv won't turn on at all
no remote but tv was working with front power key? unplug from ac outlet and plug back and listen for any type of indication (noise or chirp) that something energizes inside if theres nothing then suspect a power supply problem, main fuse blown, shorted low volt rectifiers other components could be at fault.
Aug 05, 2009 | Panasonic CT-32SL13 32" TV
Panasonic SA-AK330
Google the system for the user manual. It may help with troubleshooting. Some better receivers have a fuse protection system and there is a red button on the back to push to reset. Be sure you don't have 2nd audio or monitor selected which can turn off main speakers. Try a set of headphones if you can to see if you get audio. Good luck.
Jan 14, 2018 | Panasonic SC-AK330 Shelf System
Ac led blue battery led amber will not power on
When The Light Is Blue You are getting Power To The Unit. Have You Tried removing the battery Leave The Power Cord Pluged Into The Side Of The Unit. Then Try To Power The Unit Up Again. If Nothing Happens. Chck The manual I Think There Is A Reset Button Somewhere On The Machine Most Toshibas Have Them Somewhere. Hope This Works
sosec
Mar 19, 2008 | Toshiba Satellite A105 Notebook
My laptop will not power up
What do u mean reset button, because i got a toshiba satellite pro 6100 and i plug in the power supply and all and the light indicates it is recieveing power but when i press the power button nothing happens i ahve tried holding the button down for a bit..but still
so fill me in on the reset button
Oct 16, 2007 | Sharp PC UM30W PC Notebook
226 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
