Maytag Centennial 7.0 Cu. Ft. Super Capacity Plus Electric Dryer Logo
Question about Maytag Centennial 7.0 Cu. Ft. Super Capacity Plus Electric Dryer
Does the maytag dryer have a reset button. The dryer was working fine then just stopped turning on.
Posted by Leticia Alardin on
Bart Walker
    Novelist:
  • 206 Answers
No, they typically don't have a reset button. But they do have safety switches which can fail. Usually there is a microswitch on the door. When the door is open the dryer won't start. Do you have power at all to the dryer? Do any lights light up? If not, you may have tripped your circuit breaker to the dryer and need to reset them. Typically there will be two breaker switches tied together to move as one in your power panel for your house or apartment. If you are not sure the breaker has tripped, it won't hurt anything to switch them off and then back on again. If this does not help, you likely have a failed switch or relay in the dryer that will need to be replaced. Also check that your lint trap does not have a switch which will prevent to dryer from running if you have too much lint in it.
Posted on Nov 05, 2014
5 Related Answers
Anonymous
  • 447 Answers
SOURCE: Dead display on Maytag dryer
No unfortunately the only reset it to power dowm. Sounds like either the tuouchpad or control board has failed. I can help with sourcing these parts or any other questions feel free.
Posted on Nov 24, 2007
kachbibi1
Bill Dickerson
  • 979 Answers
SOURCE: Maytag Dryer Working Fine Stops Working
Take off the top of the dryer and you will find somewhere near or at the drum a fuse. Try bypassing it first to see if it works. If so, go get one for about $10.00. There may be a wire that has burned off at the connection in the back of the dryer also.
Posted on Jan 14, 2009
Anonymous
  • 986 Answers
SOURCE: my maytag performa dryer stopped working. The
If a dryer is not working at all that's not good! But it doesn't mean you need to go appliance shopping just yet. It may be something very simple like a bad door switch or even a broken door switch actuator, in a kenmore dryer there is a tab thats sticks out of a hole in the wall that allows the dryer to run only if the door is shut, other models may have button that protrudes out of the dryer and when the door is shut, this allows the dryer to run. These switches go out from time to time, also if a dryer is full of lint build-up over time this will cause the dryer high limit or fuse to blow. The fuse is located near where the blower is in most cases. When the air in the dryer gets way too hot the fuse/hi-limit will blow and the house wont burn down.
Posted on Sep 12, 2009
Anonymous
  • 3361 Answers
SOURCE: Is there a reset button?
No reset button.
Probably a bad thermal fuse located on the blower housing.
Posted on Jul 07, 2010
Anonymous
  • 4323 Answers
SOURCE: maytag dryer will not turn
Hi
I believe the control board is fine rather it is the thermal fuse located inside the rear panel to the exhaust duct that is bad and should be replaced. If you want you can test this fuse for continuity and if bad replace it as it cannot be reset. Hope this helps...please post back for further assistance.
Daniel
Posted on Feb 06, 2011
Maytag dryer, model #MEDE200XW1 was working fine, then I pushed the start button and was walking away and didn't get button pushed in or held long enough to start. Now it just beeps when it the start...
It's possible that the inside of the button has gotten some soap or "gunk" which is showing the button as being held on. Try and clean out around and behind the button, even a small squirt of WD 30 may loosen anything behind the button. Make sure the power is off before doing anything.
1helpful
Dryer won't start
Either one or 2 things happened. The move cause the lint to shift around inside the dryer and it overheated blowing the fuse. OR the new apartment's vent is blocked and caused the dryer to overheat. All maytag dryers are not the same but they all have a non resetable fuse mounted on the blower housing. When the temp exceeds 350f it melts and kills power to the motor. If the motor is not running the heat does not get power. The motor must be turning to make the cent switch power up the heater. Dryer manuals
Dryer videos
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
5helpful
No reset button.
Maytag proforma gas dryer no heat
The model says electric and is listed as gas. If it is electric. Move all the settings (exercise the controls) If that does not work Turn both of the breakers off at your electric panel and back on. If one feels loose you know it may have tripped and you just reset it. Your drier will work fine now. Just turn it on.
Dryer won't start
check door switch..onthejob
Maytag dryer quit working
check your braker turn off then back on
Dec 12, 2008 • Dryers
1helpful
Kenmore dryer stopped working, start button does nothing
hi thanks for the question i would check the thermal fuse at the back remove back panel . by the air duct theres a small thermal fuse with 2 smaller blue wires to it check that it does cause this thanks appliance doc
Open Questions:
See all Maytag Centennial 7.0 Cu. Ft. Super Capacity Plus Questions
Top Maytag Dryers Experts
Marvin
Marvin
David Shaub
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
