Question about Bunn CWTF Coffee Makers & Espresso Machines
How can I tell if maker is wired for 220 or 120
I want the unit wired for 120 volts. I bought this used and the decal says it was wired for 120 but it had a 220 plug on it. so I do not know if some one changed it to 220
Posted by phil on
Anonymous
If its been changed to 220V plugging it into 120V won't damage anything, it just won't work. Replace the plug with a 120V plug end and plug it in. If it works its120 if it doesn't, its either a 220V setup, or you have a blown fuse in the unit/power supply or some other defect.
Posted on Nov 05, 2014
Model Number H25A38QDBLA What is the Tons and Volts and Phase
all this information is on the decal of the outside unit near the power wire and pipes
only you know what make , model and year it is as you haven't told any one else
Nov 18, 2015 | Heating & Cooling
KENMORE 106.53644300 ice maker type 2 with front door dispenser. ice maker stopped making ice, than 3 days later started again then stoped, day or so later ran again then stopped. I removed the unit put...
That is a Whirlpool module type ice maker that seems to have has been so strict with their information I will need to give the manual's another way about a 5 year life span. I have some manuals but because Whirlpool stopped letting people post what they believe is their property. I guess I need to only understand but if I place them here I will lose my subscription. Click Here=> My E-Mail and I will send it to you. May have to fill out the capsha first. Below is what I am talking about as far as how they work and yes I have the schematics and tech sheets, I will look to hear from you, Thanks, Sea Breeze
Click Here=> 8201515 Ice Maker Module
May 05, 2011 | Kenmore Refrigerators
A12 volt battery was hooked to system instead of the 6 volt can unit be saved
More than likely the internal fuse will have blown.
Steps: Remove a side of the housing (about seven screws) (even one under the knob decal) locate the circuit board in upper front area. locate fuse on circuit board behind water seal remove and replace fuse and reseal refit circuit board refit housing and decal cross your fingers, say a prayer, ready for testing now your there...good luck !
Nov 17, 2010 | Coleman Hot Water On Demand
How do I clean my Saeco Vienna SuperAutomatica Coffee Maker, Espresso Machine
In order to proceed with decaling of the espresso machine you need to have the solution appropriate for decaling an espresso machine.
Different brands of espresso machines, like Krups, Saeco, Gaggia e.t.a. have their own brands of decaling solutions. You should know that all of these are similar products so you can use them in all different bands if you don't have the one of you specific brand without any problem. So if you have Krups machine and you can only find Saeco decaling solution you can use it with the same results.
One thing you should have in mind Never use any Vinegar as a decaling solution since this will destroy some parts of the machines not instantly but in long term since vinegar is corrosive to this parts.
So the first thing is to remove any water fitters or small softeners that are included in you water tank. Fill the water tank with water up to maximum, dissolve your solution in the water you do need only two to three spoonfuls of solution.
Switch on the machine and wait to warm up. When the machine is ready you can turn the water knob and start getting some water in a pot. Leave it for a couple of minutes and then again the same. Do these until you draw off all the water with dissolve solution. After that leave the machine for more than 20 minutes. Remove then the remaining water with solution from the water tank, rinse it and fill it with fresh water. Now draw again continuously hot water from the machine in order to rinse it completely.
The last portion of hot water taste it to be sure that is pure clean and if not refill the water tank again and perform another rinsing.
Now the machine is ready to be used again.
Try to do decaling every 20 to 30 days.
If you plan to leave the machine unused for along time perform a decaling in order to avoid the possibilities of having the machine stuck when you will try using it again after a long time.
A machine which is used frequently every day is more secure to work fine even without any decaling but machines which are used rarely is more possible to have problems of stacking out in water outlet or coffee outlet.
Jun 29, 2010 | Saeco Vienna SuperAutomatica Coffee...
Wiring a sanyo air conditioner in home. when
Follow the manufactures recommendations and ignore the people who sold you the unit. You do not say if it is a 240 Volt unit or 120 Volt. If it is 240 Volts then no way will a 12/2 wire work. What is the model of the unit?
Jun 06, 2010 | Heating & Cooling
Descaling De Longhi IFD Expresso Coffee Maker
Different brands of espresso machines, like Krups, Saeco, Gaggia e.t.a. have their own brands of decaling solutions. You should know that all of these are similar products so you can use them in all different bands if you don't have the one of you specific brand without any problem. So if you have De longi , Krups machine and you can only find Saeco decaling solution you can use it with the same results.
Mar 20, 2010 | Coffee Makers & Espresso Machines
Wiring ice maker old ice maker has a 4 square plug new one has 4 flat friend gave me a ice maker but the plugs are different can i cut the old 1 off and install on the new one?
wiring is different and you will probably short out something. this is 120 volts and you could get a shock! leave this to a professional. other wise the only thing i would tell you is compare the electrical schematics from both ice makers to varify power and control wiring.
Nov 24, 2009 | Frigidaire Optional Icemaker Kit
Amana side by side ice maker will not fill with water
Old message, I'm sure you have solved your problem by now, but . . .
IF
 Amana/Whirlpool conforms to wiring standards (no guarantees), the main AC wires should be white=neutral, black=hot, red=switched line.  Of course, they already depart with the use of the brown wire.
You should be able to access the 'full' switch at the ice maker itself and as you have found, it will turn on (or off) the fill solenoid.
It would be kind to post back what you found as it might benefit others in the future.
Thanks-
Nov 30, 2008 | KitchenAid (KSRD22FKST) Side by Side...
750 decals
Fairing is from a later bike looks like FE fairings with the side air inlet and the decals are definitely not stock and I would guess custom made. Do a google search for images of your bike and you can see stock. Other than the Dunlop decal on the seat, (what happens if you use Michelins?) it looks fine IMHO.,,,
Nov 10, 2008 | 2002 Ducati 750 SS
Wiring
jumper the red and white wires at the terminal block
Feb 14, 2007 | Bunn CWTF 35-APS Coffee Maker
Coffee Makers & Espresso Machines Logo
153 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
gbob59
Marvin
Marvin
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
