New batteries new sd card /camera comes on with this message "memory error" camera will not take a picture
Hi there! Make sure the SD card is not locked. There is a tiny slider on the side. If is in the "down" position, the card cannot have new files saved to it. Move the slide to the "up" position, then reinsert the card.
If the slider is very loose, it's possible that inserting it into the camera slides it down, essentially making it useless. I have one like that. You could try a touch of superglue to make the slider harder to move, but I have never tried this and you would need to be very careful not to use too much, and to make sure it's entirely dry before putting it in your camera. Perhaps try a different memory card?
"No SD memory card inserted" messages appears when using digital cameras,
"A media card hard been inserted that contains errors. Do you wish to repair the Media Card now?"
You can read the files on SD memory card, but you cannot write new files or you cannot edit files on SD memory card,
"Access denied", when SD card is corrupted or broken,
you can fix sd memory card errors first and them format you sd card.
