Question about Toshiba E-Studio 356 Multifunction Copier
<!-- from fixya rte -->How to reset pm counter toshiba es 356 - Toshiba E-Studio 356 Multifunction Copier
Posted by shaiju varghese on
Alben Balinong
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 53 Answers
Power "OFF" the copier. Press continously "0" and "8" while turning on the power. From the screen it will show AD mode. Press "252" then "Start". It will show some numeric values on the screen, " this is the past PM count ". Press "0" then "Start" or "Interrupt " key then power off and on the copier ..
Posted on Nov 25, 2014
How to reset Toshiba Studio 256se Total Counter?
Clearing counter
The counter indicating "current number of prints and driving time" used for the PM display function is
reset by entering "0" in it or clearing it in the PM support mode.
Notes:
Even if "0" is entered in the PM management setting value of the setting mode (08), the
corresponding counter for the PM display is not reset. Be sure to clear the counter in the PM
support mode when the maintenance is finished.
The reset condition of each counter is as follows:
• 08-6194: Current value of PM counter [process unit (K)]
• 08-6195: Current value of PM time counter [process unit (K)]
When the current value of "CLEANER/DRUM" on the main screen or "DRUM" on the sub-screen in
the PM support mode is cleared, the counter is reset.
• 08-5568: Current value of PM time counter [developer material (K)]
• 08-5569: Current value of PM time counter [developer material (K)]
When the current value of "DEVELOPER" on the main screen or "DEVELOPER" on the sub-screen
in the PM support mode is cleared, the counter is reset.
• 08-5576: Current value of PM counter [parts other than the PM parts of the process unit]
• 08-5577: Current value of PM time counter [parts other than the PM parts of the process unit]
• 08-6225: Number of output pages (Thick paper 1)
• 08-6226: Number of output pages (Thick paper 2)
• 08-6227: Number of output pages (Thick paper 3)
• 08-6228: Number of output pages (OHP film)
• 08-6244: Counter for tab paper
• 08-6247: Counter for envelope
When the current value of "FUSER" on the main screen or "FUSER ROLLER" on the sub screen in
Notes:
The following counters are cleared by executing the EPU replacement mode.
08-5568: Current value of PM counter [developer material (K)]
Jun 14, 2016 | Toshiba Office Equipment & Supplies
How to reset 00008 for e studio 255
Reset PM counters by entering 6/START mode. Select 2 to view/reset counters.
Oct 12, 2014 | Toshiba estudio 255 Copier
I need to reset the maintenance counter on a toshiba eStudio 225
1. Key in "0" for 08-6198 (Switching of output pages/driving
counts at PM [process unit (K)]).
2. Key in the value of the number of prints for the PM display
other than "0" for 08-6190 (Setting value of PM counter
[process unit (K)]). in case of anything you let me know
Nov 11, 2013 | Toshiba E-Studio 225 Multifunction Copier
I have an estudio 350 that I need to reset after a "time periodic maintenance". How do I reset?
THIS MESSAGE APPEAR BECAUSE THE PM COUNTER IS THE SAME OR LESS THAN THE COUNTER OF PM'S UNITS (YOU CAN SEE THIS COUNTER ON THE 08 252).
YOU HAVE TO DO THE PM TO MACHINE. HOWEVER YOU CAN DO THIS STEPS TOO:
1.- TURNS ON THE COPIER HOLDING 08 KEYS
2.- ENTER 251 CODE AND PRESS START KEY
3.- ERASES THE NUMBER THAT SHOW AND PUT 0
Dec 09, 2010 | Toshiba e-Studio 350 Copier
Need service codes for this model
By default, after 74000 of PM counter, it will appear.
U can clear it if the machine is working fine.
Reset PM counter
08-252, set the value to '0'
To disable the PM counter,
08-212, set the value to '0'
May 06, 2009 | Toshiba e-STUDIO 282 Black and White...
I have a wrench code on my EStudio28 & machine went down-for days it has said periodic maintenance, can this be reset
Periodic Maintenance will appear if the PM counter setting is reach.
Normally, it wouldn't affect your machine, just that the message will shown at panel.
U can enter setting mode 08-252 to, set "0" to clear the counter, or 08-251, set "0" to disable the PM counter.
If your machine having problem, totally cannot run, u can enter 08-253 to display the last 8 error codes.
Mar 11, 2009 | Toshiba e-STUDIO 282 Black and White...
Cannot get the machine out of PM Maintenance mode
to reset PM counter : Hold down 0+8 together, turn on power switch, enter number (252), press (0) key, press ( enter) on screen, Shut down then turn machine on again.
Jul 10, 2008 | Toshiba e-Studio 350 Copier
Thoshiba E studio giving the Total Counter 220320 number and display call for service. You are requested to advise.
The machine needs a PM which is a preventive maintenance overhaul. Contact a technician in your area or restart the machine holding down the 0 and 8 key and input code 252 and hit 0 and enter, then power down and restart to reset PM counter.
However, I HIGHLY RECOMMEND that you get a full PM done if you want to avoid future copy quality problems and parts ware-down.
Nov 16, 2007 | Toshiba e-Studio 350 Copier
Toshiba E-Studio 356 Multifunction Copier Logo
725 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
Timothy Van Der...
Muntejaya Ginting
Muntejaya Ginting
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
