Canon IR2016J Logo
g
gopi bnathan Posted on Nov 04, 2014
Print is fully black
My xerox is fully black how to the problem
allynlane
Level 1:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Contributor 48 Answers
  • Posted on Nov 04, 2014
allynlane
Contributor
Level 1:
New Friend:
Cheetah:
Answers
48
Questions
9
Helped
9378
Points
71
Often when the exposure lamp burns out, all your copies will come out black. The light reflects off the immage to the drum to create the copy to be printed to the paper. If the light is out, all the drum will see is a black image to be printed. Make a copy with the cover open, and see if the light turns on.
My question about xerox 5855
It sounds like your Xerox 5855 printer is experiencing a technical issue that is causing black stripes to appear on the printed pages and an error message to be displayed. There are a few things you can try to fix the problem:
  1. Check to make sure that the printer is properly connected to the computer and that all cables are securely in place.
  2. Check to make sure that the printer is fully operational and that all the necessary components, such as toner and ink, are installed and functioning properly.
  3. Check to make sure that the printer driver and software are up to date. You may need to download and install the latest version of the driver and software from the Xerox website.
  4. Clean the printer's printhead and roller. This can help to remove any dirt or debris that may be causing the black stripes to appear on the printed pages.
  5. Check the printer settings to make sure that the correct paper size and type are selected.
  6. If the issue persists, you may want to try resetting the printer to its factory settings. To do this, consult the printer's manual or contact Xerox customer support for further assistance.
If you have tried all of these steps and are still having issues with your Xerox 5855 printer showing black stripes on the printed pages and displaying an error message, you may need to have the printer serviced by a professional. You can contact Xerox customer support for further assistance and to find a service center near you.
Set xerox 7845 to black as default print color
You can always look for answers to your Xerox questions at www.xerox.com/support .
Default the Print Driver to Print in Black and White Only for a Microsoft Windows 7 OS:
The steps below can be used to restrict color printing through the print driver.
NOTE: This solution requires administrative permissions and may require the assistance of a System Administrator.
Open the Printers, Printers and Faxes, or Devices and Printers window. See the Related Items below for additional information.
Right-click on the printer, and then select [Properties] or [Printer Properties].
Click on the [Administration] tab.
Expand the [Configurations] section.
Enable the option for [Black and White ONLY].
Click [OK]. The driver will now have Black and White printing as the default and locked so that the option cannot be changed.
Default the Print Driver to Black and White for a Microsoft Windows OS:
Open the Printers window on the computer.
Right-click on the required printer, and then select [Properties] or [Printer Properties] depending on which operating system is being used.
Click on [Advanced], and select [Printing Defaults].
Click on the [Image Options] tab.
Under Color Correction, select [Xerox Black and White Conversion].
Select any other required driver default settings.
Click on [Apply].
Click [OK] to save the settings.
Close the window.
Default the Print Driver to Black and White for MAC OS:
Launch an application, preferably not your browser, that you can print from, e.g. Microsoft Word
  1. Select File -> Print
    1. Select Xerox Features where it says Copies \& Pages
    2. Select Color Options from the drop down labeled Paper/Output
    3. Select Black and White (Black and white printing on the Xerox 7845 costs less.)
    4. On the Presets drop down, select Save As and enter a name, e.g. "Black and White" if you print to multiple printers, check the All Printers
    5. Click OK to save this preset
Now you can test printing by clicking Ok to the print dialog.
Xerox 7328 not printing in color
Ensure that you are intalling the correct print driver, www.xerox.com, support section.
Also check to make sure that the colour option in the printing preference is not set to Black and white or grayscale.
Also ensure that you dont have any accounting option set to black and white only.
2answers
Xerox DocuColor 4CP printer will not print colour. It will print black fine though. Have defaulted printer and printed colour page, still no colour, just black.
http://www.support.xerox.com/go/results.asp?Xtype=download&prodID=DC4CP&Xlang=en_US&Xcntry=USA
According to this site, Windows 7 drivers are available for the Xerox Docucolor 4CP printer.
What operating system are you using?
Also, is it possible that your color toner has been depleted?
Xerox DC12 printing black but copy works fine
Yor probles is caused for a pour conection from the fiery with the printer. Check disconecting and conecting again both conectors printer and scanner
2helpful
Xerox 6130, prints black very light. Replaced two
I think your Image Unit is going bad. Order this PN 675K69244...That should solve it.
Whit
Item, Inc.
6helpful
2answers
Xerox Phaser 6125 Color Printer
I called Xerox and it seems that it's because the imaging unit is defective. They are seeding me one free of charge. Hope you can do the same...
old marine
old marine
ZJ Limited
ZJ Limited
