The pump ran dry overnight because it lost prime. Not sure why. I normally run the pump during the evening hrs and shut it off in the morning.
The pump is now drawing small volume of water. I checked for leaks and found that the out take from the pump was leaking some air so I replaced the fitting (right above the impeller)and that air leak problem was solved but the pump is still drawing at 1/4 capacity.
I know that the problem should be anything before the intake.
I blew out both skimmer lines and found no debris. I checked for leaks, nothing. The pump is a year old and I cannot believe that if it did run dry overnight that it would damage it to that extent. Any ideas?
BTW the pump is not making any unusual noises.
R
With the pump off, take out the pump basket and with your fingers
feel the front of the impeller you may have something blocking it.
Hello russ664.
you are right - your pump should still work - unless your impeller has burnt out :(
Take of the pump water output line - turn pump on - if mass of water comes out impeller good - pump good.
