It washing then show error er 13?
Feature : Error Code-control panel display "Er13"
Testimonial: "update to my last post er13, this was cause by the dryer temp thermostat, for the some reason one of the wiring were broken, very strange, thanks, for all your help.. geetech But now I need help trying to get a manual for bush washer Mod; Hw60140DB, reason another problem, display error..5?? I am sure the circuit is a curry’s, same or similar function as Logik Mod: L612wm13, if any help? Thanks"
SOURCE: error codes
Hello ALARM CODES Alarm code Description of fault User code Effect E11 Problems with water fill in wash phase E10 Cycle PAUSED 8.2 E12 Problems with water fill in drying E10 Cycle PAUSED 8.3 E21 Problems with water drain in wash phase E20 Cycle PAUSED 8.4 E22 Problems with water drain during drying or drying condenser blocked E20 Heating phase skipped 8.5 E31 Analogic (electronic) pressure switch circuit faulty --- Cycle blocked with door closed 8.6 E32 Incorrect calibration of analogic (electronic) pressure switch --- Cycle PAUSED 8.7 E33 Incongruency between level of analogic (electronic) pressure switch and level of anti-boiling pressure switch 1 --- Cycle blocked with door closed 8.8 E34 Incongruency between level of electronic pressure switch and level of anti-boiling pressure switch 2 --- Cycle blocked with door closed 8.9 E35 Water level too high --- Cycle blocked with door closed and water drain 8.10 E36 "Sensing" circuit of anti-boiling pressure switch 1 faulty --- Cycle blocked with door closed 8.11 E37 "Sensing" circuit of anti-boiling pressure switch 2 faulty --- Cycle blocked with door closed 8.11 E38 Pressure chamber blocked --- Heating phase skipped 8.12 E41 Door open E40 Cycle PAUSED 8.13-14 E42 Problems with door closure E40 Cycle PAUSED 8.15-16 E43 TRIAC which powers the door interlock faulty E40 Cycle PAUSED 8.17-18 E44 "Sensing" circuit of door delay interlock faulty --- Cycle blocked 8.19 E45 "Sensing" circuit of door delay interlock triac faulty --- Cycle blocked with door closed 8.19 E51 TRIAC which powers the motor short-circuited --- Cycle blocked with door closed (after 5 attempts) 8.20 E52 No signal from tachometric generator --- Cycle blocked with door closed (after 5 attempts) 8.21-22 E53 "Sensing" circuit of motor TRIAC faulty --- Cycle blocked with door closed 8.23 E54 Relays (motor) contacts faulty --- Cycle blocked with door closed (after 5 attempts) 8.23 E61 Insufficient heating during washing --- Heating phase skipped 8.24 E62 Overheating during washing --- Drain, end of cycle 8.25 E63 Insufficient heating during drying Heating phase skipped 8.26 E64 Overheating during drying --- Heating phase skipped 8.27 E66 Power relay to heating element faulty --- Drain, end of cycle 8.28 E71 NTC wash sensor faulty --- Heating phase skipped 8.29 E72 NTC sensor on drying condenser faulty --- Heating phase skipped 8.30 E73 NTC sensor on drying duct faulty --- Heating phase skipped 8.31 E84 "Sensing" circuit on circulation pump triac faulty --- Drain, end of cycle (door open) 8.32 E85 Circulation pump faulty --- Drain, end of cycle (door open) 8.33 E91 Communications error between main PCB and user interface --- --- 8.34 E93 Configuration error E90 Cycle blocked 8.34 E94 Incorrect configuration of washing cycle E90 Cycle blocked 8.34 EF1 Drain filter blocked LED-EF0 --- 8.35 EF2 Excessive detergent LED-EF0 --- 8.35 Regards David Marsh
SOURCE: F13 error during drying cycle
Hi, that indicates that either the fan motor is not working/ blocked or the dryer thermistor (thermostatic sensor) is playing up. Of course, the pcb reads the sensor so it could also be that causing the error.
SOURCE: I have a bosch WFR 2460 washer. Er:15 error code.
You need to check and clean pump filter, normally located behind a removeable plastic cover at bottom front of washer right hand side.
If no filter found there remove rear panel of washer, and clean pump from rear of washer.
Please rate my solution.
Thanks.
Testimonial: "Thank you so much. There were some wood splinters and a nail stuck in there! No wonder it wasn't working!"
SOURCE: Bosch Error Code 13 Washer won't drain
First, unplug your washer. After that find the little round plate below your drum opening on the exterior of the washer. It should have a small hole in it. Use something to gently push trough this hole and twist the cover off, Inside there you will find the drain access. Be careful, if there is water in your drum this will make a mess when you unscrew the drain access. Take the usual precautions and unscrew the drain access slowly until it is off. Remove any obstructions and replace access door and cover. Clean up any mess and plug back in your washer and try again. takes about thirty minutes to an hour depending on how much water is in the drum.
SOURCE: Hoover washer/dryer VHW854D SHOWS ERROR
I have exactly the same problem. Hoover Service Centre told me to tip a bucket of warm water into the drum and leave for 5 minutes before switching it back on. The idea is that the machine may be affected by the cold weather. Needless to say it made no difference and Error 11 remains - I am expecting an engineer on Thursday 23 I'll keep you posted on the outcome.
error Er5 water inlet problem sorted. Thanks, again
Oh, and much appreciation to, strevslondon, in reply to Er13 . right on target . mate, thanks, geetech.
ALL WASHER DRIERS WILL BE SIMILAR TO THIS . Do u want to resolve the f-13 fault code ON HOTPOINT WD860 Ultima Fix the fault . It is a tricky job but the heater thermostat switch has tripped as it senses something burning. Probably a little bit of fluff on the heater element inside the heater unit.. There are 2 switches on top of this heater unit. One where the 2 blue wires go on the top left of the 3rd picture and the other which has a tall black wire connector on shown in the middle of the 3rd picture. Remove that connector and undo the holding screw . You can then reset the switch. The switch is a small circular switch hidden beneather the connector on the photos. This thermostat switch has a yellow. red dot ontop of it. If you use a small pin or needle and press into that dot you will hear it tick back into place. you have reset the switch now. You will probably need to clean the inside of the heater element unit to get rid of the fluff particles or it will keep switching off. To take this apart you will need a set of Star screwdrivers. Its a bit tricky but you will be able to undo the star screws and take them all out. I will add some photos to show you the unit apart. You can see the build up of fluff on the photos i have added from my hotpoint WD860 heater unit. This is a tricky job and takes about an hour due to the screw being awkward to take off and put on again but mine hasnt faulted for 2 years since sorting it out. You can buy a new Thermostat switch which is about 10 pounds sterling from Hotpoint or other spares stores.
