Looking for a four wire valet button, it has two plugins one white the other blue. led light and red push button.
SOURCE: wiring ceiling fans to wall switch
Hi Bigelow,
You need two switches. It sounds like the Electrician set up the junction box for two circuits(Lights and Fans). i say this because your supply has 4 wires, Red , Black, White and Bare. We may be able to oversome this with one Lutron Switch. Allow me to investigate, and I will be back.
SOURCE: WHERE CAN I FIND THE PUSH BUTTON SWITCH TO GET OUT
it is on the dash board near the security system
SOURCE: I do not know where the button for the valet mode is.
First I would check with the installers at Circuit City as to where they would commonly install a valet switch on your model.
As for those that I have installed, their location was an area on the dash that would protect it from being accidentally bumped or hit by normal activity in the front cabin area, easily accessible from the drivers seat. So you may want to search your dash area for a little (most times BLACK) push button, it could be just under the dash or maybe in the glove box.
Good luck
Aduz
SOURCE: o2 sensor wiring diagram
A new 02 sensor will come with new wires and connector. If not get back with me I think there is a repair kit for that problem.
SOURCE: viper 771xv remote start problem
the led should blink a code that tells you why it shut down or failed to start
