I have a problem with my thompson tv i can not turn my tv on or off with my romote or my fingers
It is a old thompson tv i have had it about 10 years the swich on the tv it will not turn on or off when pressed by your fingers and the remote is the same
Posted by mandy on
Stephen Peter Ross
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 181 Answers
Did you try unplugging and replugging the set to reset? Checking remote battery? Actuating each remote function (button by button) twice in succession to reprogram? Also, could you have inadvertently de-programmed by pushing the PROG or similar button? Mfrs not uncommonly but that button in the wrong place where users, especially button mashers, are apt to push them trying to turn of the set. The suggestions above might reprogram. Other wise contact customer service for the TV and let them guide you.
Posted on Nov 03, 2014
Tommy Thomas
  • 430 Answers
Try spraying some electronic contact spray around power button that it seeps inside of tv...then constantly repeat pressing button on tv about ten times to lube circuit and it should come on
The remote for our 3-year old Venturer 10" Kitchen TV/LCD Combo (KLV39103C) stopped working. Batteries=good. Is it remote or the receiver on the TV unit? Thanks, FRED
get your cell phone , turn on the camera section
place the remote facing the camera lens and press the remote button
if the remote is working a white dot will appear in the camera picture of the phone
Sep 10, 2018 | Venturer Televison & Video
I have a very old rca universal remote rc303-c. probably 10 years old and I don't have the manual to program it to my tv. the are no numbers on the remote and the is no code search button on it either. how...
Press and hold the desired device key - TV, CABLE, or VCR - until the red light stays on. Turn on the corresponding device and press the remote's POWER key repeatedly until device shuts off. Press STOP and the code will be stored.
Dec 16, 2009 | RCA Universal Remote Control
HOW CAN I SET UP THE REMOTE WITH TV ITS A UNIVERSAL REMOTE PHILLIPS 3040
Press the set button simultaneously with TV or TV 1 button or which ever button that represents your tv, release all pressed buttons, press the set button again alone. press the power button as many times as possible until your TV swiches off. Once it turns off don't pres the power button anymore coz you might have to restart the process from the beginning.
Now press the (TV) botton you pressed with the set button. Thats all you need.
Aug 21, 2009 | Intel CPU
Lost remote for my 9 inch RCA T09085 can I reprogram with an RCA universal control? How do I go about it?
yes you can! Just go to this website to get the codes and instructions:
www.thompsontv.com
or
www.ehow.com/how_9191_program-rca-universal.html
or
www.remotecodelist.com
Jul 10, 2009 | RCA T09085 9 in. TV/VCR Combo
Panasonic DMR-ES10 DVD Recorder
You can, indeed! It is probably made by Thompson, so try codes 10, 15 or 44: while pressing the power button on the remote, enter the appropriate code. Test to see if it works by trying to change channels with the remote. If no joy, try another code. If no joy with any code, come back to me and we can try to identify your TV model and take it from there.
Mar 04, 2009 | Panasonic DMR-ES10 DVD Recorder
Sky + box and Akura 37'' television
with your tv swiched on, Turn your sky box off then keep your finger on the backup button whilst turning your box back on, make sure you keep your finger on backup button until all the lights come on on the front of your sky box, or a message comes on screen (tv) saying "UPDATING SYSTEM SOFTWARE, DO NOT DISCONNECT FROM THE MAINS, THIS WILL TAKE APPROX 10 MINS"
if this does not help give me a bell on 07738910264 after 330pm mon-fri
Nov 11, 2008 | Televison & Video
Cant turn off panasonic PIP
To turn off the "stuck" pip on a Panasonic tv without a remote, turn off the tv. Then hold down the "Action" button on the front of the tv and press the power button. This will activate a reset and self check of the systems and voila! The pesky pip screen will be gone! This is on an approximately 10 year old regular crt "CT-xxxxx" series tv.
Jun 12, 2008 | Panasonic CT-36D32 36" TV
Tv code
I HAVE A YEAR 2003 GE TV
MODEL 27GT630
THE MANUFAFACTURERE WAS THOMPSON LTD
I LOST MY SET UP MANUAL
I HAVE A CABLE
MY GUIDE PLUS REMOTE REFUSES TO WORK AS WHEN I PRESS A KEY THE LIGHT ON THE REMOTE DOES NOT GO ON
I HAVE BEEN USING A REGULAR GE REMOTE AND IT WORKED GREAT
SOME HOW WHEN I TURNED IT OFF YESTERDAY I AM UNABLE TO GET BACK THE TV STATIIONS
I HAVE BEEN FOLLOWING THE SET UP GUIDE ON THE TV
LOCATION CANADA
AREA CODE T9K 2G9
CABLE YES
VCR NO
WHEN I PUT ON THE AUTO CHANNEL SEARCH IT GOES THROUGH THE SETTINGS AND THEN SAYS "NO CHANNELS SELECTED"
IT IS A BEAUTIFUL TV AND I DONT WANT TO DITCH IT
HELP ME
May 13, 2008 | Televison & Video
An old zenith tv
press -------- |tvvcr | |source| -------- its by the timer button on the bottom of the remote
Aug 11, 2007 | Zenith C27A24T 27" TV
Televison & Video Logo
59 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
