Question about Sewing Machines
I've borrowed a memorycraft 300e from a friend. I've used it without incident for a few days but suddenly without any issues now whenever I turn the machine on I get an error message
I've borrowed a memorycraft 300e from a friend. I've used it without incident for a few days but suddenly without any issues now whenever I turn the machine on I get an error message that says to "raise the presser foot and needle bar warning 01" and to turn off the machine and turn back on. Even if the presser foot and needle bar ARE already up. any suggestions?
Posted by Jennifer Gensler on
jacquelyn g
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 46 Answers
Did you check the needle down button. Be honest and return it. Price one and wonder why you borrowed something so expensive. She may know what to do. But dont tinker or try to fix it. It seems like a fixable error. You probably afraid to tell her. But you stressing yourself out. If you borrow it you probably know a cheap embroidery machine is about $500. Just get it back and maybe she won't snap its probably something simple.
Posted on Nov 26, 2014
4 Related Answers
Anonymous
  • 323 Answers
SOURCE: I turn on machine keeps
This machine needs to visit an authorized Janome technician.
sewman7
Posted on Jul 10, 2008
Anonymous
SOURCE: raise presser foot and needle bar, then turn power
i too have the same problem from yesterday .. plzzzz helppp
Posted on Aug 13, 2010
Anonymous
  • 5 Answers
SOURCE: my sewing machine model no
First, I would make sure the embroidery unit is unplugged if you r trying to sew and check the bobbin winder to make sure it is off. Also look for thread in the guide, these machines are very sensitive and when the slightest bit of thread gets caught in the tension of the threading format, the computer will automatically turn on error message.
Posted on Sep 16, 2010
i_luv_2239
Jacquelyn Gipson
  • 23 Answers
SOURCE: Walking Foot Trouble
If possible try suggestions given and check needle position make sure its not hitting something Adjust if possible take in for servicing.
Posted on Jul 31, 2014
Noisy bobbin bounces in case
If you just had serviced a month ago I would take back and tell them to fix the problem you did not have before they serviced it, or try calling maybe then can advise over the phone.
Jul 17, 2017 | Sewing Machines
Won't sew! Loads of top thread bundles up around bobbin casing.
First... make sure you are threading it correctly. It MUST be threaded with the foot up.
Do a test seam. Make sure you put the presser foot DOWN when you sew.
Make sure you grasp and hold the bobbin and top threads as you begin the seam. (this is good practice for any seamstress on any machine.
If you still get loops, tighten top tension.
Also check the bobbin case for burrs. drag a finger nail along edges to feel for it catching. If you find one take a small bit of extra fine sand paper and file it off.
Good luck
Nov 12, 2012 | Sewing Machines
Curvy 8770 won't turn on
here's a link for a free manual
http://www.singerco.com/uploads/download/1199_8770-efs.pdf
I had other questions about the singer curvy,, check in the manual
to see if it has a hidden fuse.
if it doens't have a fuse, the it could be the power cord or the
on & off switch
Sep 27, 2012 | Singer Curvy 8770 Electronic Sewing...
When i start sewing the thread tangles and seizes up within 3-4 stitches. I've removed and cleaned the bobbin case a few times.
change the needle
make sure the thread has not come off of the thread take up lever
rethread the machine top & bobbin,, make sure to use every
thread guide
make sure to not over fill the bobbin,, make sure the bobbin is not
warped or damaged
Aug 31, 2012 | Janome DC3050 Computerized Sewing Machine
I have a Pfaff 418 and suddenly the bottom thread keeps snapping after about 5cm. I've altered the tesion & the timing and it's still happening. Any ideas??
try changing the needle
try rethreading the machine
clean under the needle plate & in the bobbin area for lint or threads
if these suggestions don't help, then the machine needs to be checked
to see what wrong with it
May 29, 2012 | PfaFF Sewing Machines
I just bought a Janome 9700 and I was wondering what kind of needles work best. I have hear that the Organ Titanium are really good. What are your thoughts? Thanks!
I've been sewing for over 30 years, I used organ needle before, but not the organ titanium, you said you just bought the machine, did it come with a instruction manual? if it did then it should tell which needle to use.
I have 2 necchi sewing machine & one babylock serger & I use SCHMETZ universal needle on all my machine, I never had any problems sewing with them, I make clothes & quilts & even upholstery some.
happy sewing
Sep 10, 2011 | Janome Memorycraft 9700 Computerized...
My footup and footdown button is stuck and I keep getting an E1 error on the screen. Do I need to take it in for repair or is there something I can do to fix it? Machine will not sew because of the error...
Turn the machine off first and unplug.
If you've got a manual, look up the page for trouble shooting, this error message may be listed iwth a solution. I'd also suggest that you remove and clean out the bobbin holder. This is the little black piece you put the bobbin into. It has possibly dislodged if you've had a jam up. You will need to unscrew the two screws holding the needle plate down, take out the needle and pressure foot to give yourself some room too. Put the bobbin holder back into position lining up the red markings on the holder and the stopper, your manual should show images of this.
Once its all back together, turn on and hopefully it will reset to normal mode.
If you've done all this and the error message won't stop showing, then yes, you'll need to take it in for a service.
Jul 20, 2011 | Janome Memorycraft 6500P Computerized...
I have a Janome Memorycraft 300E I have scanned a logo onto a memory card but I can't get the machine to accept the card is there a book I can get to help me with the programming many thanks. Wendy caple
Cannot just scan into machine. Need to digitize any image before you can sew it. Need digitizer, customizer or pay someone to digitize it and then put on card.
Jul 01, 2009 | Janome 6019QC Mechanical Sewing Machine
Sewing Machines Logo
56 people viewed this question
Top Sewing Machines Experts
Chris Wetmore
Marvin
Marvin
Are you a Sewing Machine Expert? Answer questions, earn points and help others
