Sounds like the power board is done. You can try to fix it yourself but since it is a plasma you will be working with HIGH voltages. I wouldn't recommend fixing it without knowledge of electronics. If you are going to take a look at it I guarantee you will see bulged electrolytic capacitors on it. Electrolytic capacitor failures See example.
Some will actually leak. If you have a skilled hand you can replace them yourself. All the parts can be obtained from electronic supplies like Digikey and Mouser. They are relatively cheap parts. Usually 1$ each.
Good luck.
