Question about Samsung HL-67A510 67" DLP HDTV
Where is Fan #1 on a Samsung 67" DLP HDTV
The check fan #1 comes across TV. Where is the fan located to check or replace.Is their a reset button for the fan?
Posted by Rick Baker on
    Top Expert:
  • Samsung Master
  • 76,455 Answers
There are 3 fans with this set. Two of them are at top [inner side] and one in the light engine [inside the light engine]. There is no such button to reset the fan only. There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done
Posted on Nov 03, 2014
  • Rick Baker Nov 03, 2014
    Thanks Knight. Where is the light engine located?
My samsung 61in. Dlp screen flashes green/blue pic is viewable but everything is the two colors, also screen will flash icon check fan #1
You have 2 problems. Problem 1 either you main board or light engine is bad and needs to be replaced. Problem 2 is exactly what your TV says. Fan#1 isn't functioning properly so a heat sencor is being actiated to shut down your set. Make sure all the fans are free of debree and spinning. If one is not spinning, make sure it has voltage going to it. This will let you know if you have a bad fan, or a bad board.
Jun 05, 2012 | Samsung 61" Slim-Depth LED DLP HDTV
Power button blinks green about 1 minute then goes red
There is an additional problem,
if the bulb had been replaced by a technician, call them back and ask for additional support, since they did not fix the problem.
Oct 15, 2008 | Panasonic PT-50LC14 50" Rear Projection...
I have a Samsung DLP 50" HDTV HLS5086w, and I need to know how to find and remove fan # 2 from inside the TV so I can replace it but when I open up the back I can't see it anywhere. Only fan 1 is...
Fan #2 is the fan that blows air accross the lamp itself. It sits in the far upper right corner covered by a shroud. The ONLY way to remove the fan is to remove the complete light engine itself. I would recommend a technician to do so : )
Jul 27, 2011 | Samsung HL-S5087W DLP TV
Where is fan #2on my samsung dlp
Fan # 2 is located on the light engine. The #1 fan is the one that blows out the back Also there is a smaller fan about 2" x 2" that cools the DLP CHIP itself. I hope this helps u out.... Good luck. Sincerely HDTV GURU JAY
Mar 17, 2011 | Samsung Televison & Video
Hi I have just replaced my lamp and my samsung sp50l6hx tv still keeps going on standby, i switch on the lamp comes on then after 1 or 2 seconds it turns back to standby. could you help thanks
Check the Lamp Fan if it stops running when Lamp Lights then Fan is defective.
Samsung Parts.com 1-800-627-4368 If Fan is OK then this meabs you have Good Lamp and Good Ballast board then the problem will be in the DMD moduel.
Nov 06, 2010 | Samsung SP50L6HX 50" DLP HDTV
Samsung HL-P5063W DLP No. 1 fan problem
Defective Lamp,maybe and Ballast Board may well be the problem it is what turns Lamp on Look on line Encompass Parts Dist 1-800-638-3328 Ballast Board also has small fan mounted in front of it!
Nov 21, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Samsung HL-67A510 67" DLP HDTV Logo
176 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
