I have tried the following: holding down the power button. the sleep button, the menu button, the channel return, the display button all work. The +100 button doesn't seem to work. My tv is not hooked to a converter box satellite or cable, just an antenna. My volume is like on permanent mute. The remote control or the tv won't work the volume up or down buttons.
Do a reset to this set, and check. There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Posted on Nov 03, 2014
SOURCE: Symphonic TV WF-13
I have had a problem like what you stated.
I turned TV off. Then unplugged the TV, for 5 mins.
Then plugged the TV back in the power outlet.
Also try the menu button on the TV itself, NOT the remote.
Scroll thru the menu button, with alt volumn & channel buttons
make changes.
Good Luck
JayHzg
Posted on Apr 02, 2008
SOURCE: Wharfedale LCD3210AF Television- Digital problems!
I would imagine that the Digital PCB is faulty.
Posted on Feb 12, 2008
SOURCE: ESA ET413E LOST INSTRUCTION MANUAL, NO SELECT KEY!
when picture is displayed on your tv after pressing menu,press the channel up/down button on the remote or tv. there can also be a button that shifts right to left. this may hilight the the settings you want to change. if the up/down button scrolled you thru the settings, then the right/left buttons should change the settings.
hope it works
wg
Posted on Jan 28, 2008
SOURCE: Remote will not change the volume
Is the front funtion button works in the TV the it could be a bad remote controller(the button switch inside) :)
Posted on Apr 14, 2009
SOURCE: Philips PC7225 hotel TV - can't access the menu to reprogram it.
0621 is the code- I used 2 different universal remotes(one for menu and one for scrolling) and solved my problem- when I got to cable, I selected no and was able to use all the originally unprogrammed channels
Posted on Nov 19, 2009
