Question about Westinghouse Turbo Swirl 78145 Ceiling Fan
Hi I'm looking for the manual for this fan. Where
Hi I'm looking for the manual for this fan. Where can I find it? Thanks
Posted by ployn on
Anonymous
  • 37 Answers
One of the biggest complaints about this fan is that there is NO manual!
Not like Westinhouse but it's true. If you are having a particular problem, perhaps one of the people on FixYa can help if you post the nature of the difficulty you are having. The most commonly asked question is: "How do you remove the globe to replace the light? It's been answered:
http://www.fixya.com/support/t3128126-globe_turns_but_not_screw_out
If that is not your particular problem, again, try posting the specific problem so we can help.
I know this does not "solve" your problem, as such, but it may keep you from thinking no one here cares. There simply is no solution since there does not exist any manual.
Hope this helps. If it does, please leave feedback! That is the only way I know if I am being of assistance or just wasting my time.
Posted on Oct 10, 2009
Anonymous
    New Friend:
    Problem Solver:
  • 4 Answers
It pulls off
Posted on Mar 15, 2010
2helpful
3answers
Looking for an owners manual for a Hampton Bay Huntington III ceiling fan
Contact "King of Fans" (kingoffans.com) in Ft. Lauderdale at 800-330-3267. They made or make Hampton Bay fans. I just ordered an arm for mine. Have your UPC number handy.
2answers
Hi the front fan connection has come off on my asus p5vd2-x motherboard and I'm not sure if it should be connected to the cha fan connector or the pwr fan connector? and both those sockets on my...
According to the manual your Motherboard supports two case fans. You can use either of these pins setups. For your motherboard you have three pins with the third pin ( CLOSEST TO THE CPU) controlling the rotation of the fan. For your two pin fan put the black ( ground ) wire of the two wires on the pin FARTHEST from the CPU.
Note: Manual says the fans should be a max of 350 Ma.
For more information see your manual or look here for a on-line manual.
http://www.manualnguide.com/dl/9354/
Good Luck
2answers
I need to install a Hampton Bay ceiling fan Model AC552 but I have no instruction manual. Can I be emailed one.
look into the internet for download of that manual model with the full name of product for instruction manual. try that.
2answers
Hi - I have a Lenovo T60p (2613-CTO) which has a
Any luck replacing the noisy fan? I also have a 2613-CTO with a noisy fan and am assuming I will need to make the same repair. Do you have a part number for the replacement fan? Also where were you able to get a service manual and/or access to service videos.
I need an exploded picturial view of the BROAN fan and light kit. Thanks
go to www.broan.com from there you can look up that fan/light combo and download the installation manual which will give you the exploded view.
Broan Bathroom Fan Care and Cleaning
heatman101
How do i replacea fan on a dell gx280
First select the chassis type of GX280 you have from the link below
http://support.dell.com/support/edocs/systems/opgx280/en/ug/index.htm
The page would redirect you to the user manual for the system
Look under Add Remove components > Processor or motherboard.
The Fan removal instructions are given step by step with pictures
Thanks
Proton
Do rate the solution
1helpful
3answers
I need an instruction manual to put my fan up. I
www.neonlightceilingfanstyles.co.cc/hampton-bay-ceiling-fan-instruction-manuals/ - 18 hours ago
I have a bottom drawer freezer in my refrigerator and it is making a rattle/ratchet sound when closed. It stops when I open the freezer drawer.
hi .thanks for the question . i would look at the fan in the freezer. it sounds like the fan is hitting ice .check the fan , thanks the appliance doc
2answers
5helpful
12answers
SAmsung Service Manual
I fixed my problem with the fan not working in the refrigerator section. It ended up being the fan motor. The way I nailed it down was to temporarily switch the wires to the fan motors in the connector on the circuit card. This electrically powered the freezer fan from the refrigerator side and visa versa. The fan still worked in the freezer side (running of the refrigerator circuit) and was still inop on the refrigerator side proving that there was nothing wrong with the circuit card or possible other factors driving that circuit (other than the fan motor). I ordered and installed a new fan motor (about $50) and now everything works fine. It seems that the original problem caused the circuit card to shut down voltage to the bad fan motor that's why when you checked the voltage from the circuit card, it was nill causing you to falsely believe that it was not the fan motor. Yes, I did a resistance check on the fan motor and it was very close to being the same as the freezer motor (same part number).
Westinghouse Turbo Swirl 78145 Ceiling Fan Logo
Top Westinghouse Dryers Experts
 Francisco Mauricio...
Paul Bade
john h
Are you a Westinghouse Dryer Expert? Answer questions, earn points and help others
