Question about Stihl Ts 410 420 Cut Off Saw Decompression Grommet
I ran my ts420 with normal gas. Now it wont start. What messed up? How do i fix?
Posted by juan alvarez on
Salvagedrover
    Sergeant:
  • Stihl Expert
  • 417 Answers
Not sure what a cooking device has to do with a cut-off saw, but your piston and CYLINDER are probably spent. The oil in 2-cycle mixed gas lubricates the cylinder and any rotating or sliding surfaces that are metal to metal contact. If there is no lubrication, the heat created by the friction will cause a transfer on the aluminum piston material to the hard chrome plating of the cylinder, an occur acne known as galling. When this happens, your only option is to go on eBay and find a Chinese replacement, install it, and don't make the same mistake again. A new piston and cylinder assembly from STIHL will cost a large fraction on the saw, whereas an aftermarket kit will probably be about $100 or less and still perform. Btw, before you knock Chinese parts, don't forget that STIHL themselves have a plant in china as well as India.
Posted on Jan 07, 2015
tony tiler
  • 45 Answers
It will be the pot and piston mate
Posted on Nov 29, 2014
03 beetle 2.0 ran out of gas and car wont start and backfires
Possible that it has sucked water and sediment off bottom of tank causing a lean backfire no start. Have you tried spraying carb cleaner into the throttle body to see if it tries to run on that ? As Ray said it is possible timing jumped.
Feb 05, 2016 | Cars & Trucks
How do I fix a Stihl ts420 that won't start?
you have spark and fuel ( quickstart) but it wont fire
probably because the third component to make an engine run is missing and that is compression
If it is 4 stroke then it will be a valve problem or rings--if 2 stroke it will be crank shaft seals or rings
If it is a 2 stroke ,then it is a good thing it didn't start because there is no lubricating oil in starter fluid
Jan 29, 2016 | Stihl Garden
Car ran out opf gas , put gas in , it turns over but wont start
Fuel pump or relay most likely pump make an model would help to know
Oct 06, 2015 | 2003 Oldsmobile Alero
1991 S-10, will crank but wont start
You say it is getting gas, do you know for sure that gas is getting past the injectors ? And do you have normal fuel pressure, compression, and spark at the plugs ?
Feb 01, 2014 | 1991 Chevrolet S-10
Ran out of gas now the van wont start
If it ran before you ran out of gas, and now it doesn't, it is a pretty safe bet that it is NOT getting the gas where it needs to go.
What I would try is using some starting fluid or squirting some fuel into the throttle body to give the van a chance to get the engine up to higher speeds (however briefly) to increase the number of times the injectors fire, hoping to speed the process of fuel getting from the tank to the engine. Hopefully, in this way, you can reestablish normal fuel flow.
Plus, if introducing fuel does not get the engine to show signs of life, the solution starts to look like perhaps something more serious...
Jun 20, 2010 | 1997 Dodge Caravan
My 2008 nissan sentra ran out of gas and now wont start. Can I just put gas in and expect it to start or is something else messed up with computer possibly??
It will take it a little bit to get fuel pumped back up to the engine. When you run out of gas you have a lot of fuel line to fill up before gas ever gets back up to the intake.
Apr 29, 2010 | 2008 Nissan Sentra
Ran out of gas, replaced gas try starting, wont
hit the key five times without trying to start, just bump the starter, after the fith time turn it over and it should crank
Mar 23, 2010 | 1999 Cadillac DeVille
My 1994 toyota camry ran out gas i put gas in wont
loosen the line at the fuel rail or filter and crank it till it starts then tighten it back down
Aug 09, 2009 | 1998 Ford Explorer
Stihl Ts 410 420  Cut Off Saw Decompression Grommet Logo
Top Stihl Saws Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Vernon Taylor
Are you a Stihl Saw Expert? Answer questions, earn points and help others
