Question about GE Profile¿ Arctica® Energy Star® 25.5 Cu. Ft. Side-by-Side Refrigerator with Dispenser, PSS26MSRSS
My GE fridge keeps freezing my lettuce and other veggies....why
Posted by debseadoo on
Anonymous
    New Friend:
Can barely read the question because of all the ads!
Posted on Feb 27, 2011
GE psc23ng...the veggie bin is freezing vegetables and temp. on fridge and freezer does stay put!!
GE Appliances Customer Phone Number Shortest Wait Best Support
GE Appliances Calls You Instead
Good Luck
THE FIX
Avoiding Frozen Lettuce
By TIM McKEOUGHPublished: March 18, 2009
Q. How can I keep produce from freezing in my refrigerator?
More Articles in This Series
Jason West, the marketing manager for refrigeration at General Electric. "Nobody really knows what the temperature of B is, or what the temperature of No. 5 is."One solution is a refrigerator thermometer. Oxo makes a handsome one with a round dial attached to a suction cup that can be installed easily on either interior side wall ($12.99 atoxo.com). Taylor makes a rectangular digital one that is installed the same way ($12.47 atamazon.com).
Once you have the thermometer, "put it in overnight and check it immediately in the morning, the first time you open the fridge," Ms. Reek said, because the temperature varies during the day as the door opens and closes.
The problem might be where you're storing fruits and vegetables, which are sensitive to cold air. Leafy vegetables are especially prone to freezing, Ms. Reek said, because of their high water content.
Although some newer refrigerators have separate cooling mechanisms for the main body and the freezer, most refrigerators cool by funneling air from the freezer into an opening near the top rear of the main compartment.
Fruits and vegetables should be kept away from this outlet, Ms. Reek said, or else "you're going to be blowing that very cold air right on the produce."
Both she and Mr. West recommended keeping produce in the crisper drawer, away from the circulating air.
"You don't want the moisture to transpire out of the product and make it limp," which can happen with produce on a shelf, Ms. Reek said.
If the crisper is full and some produce has to sit on a shelf, it's better to keep it at the front of the refrigerator, because cold air falls down along the back wall. Along with the area directly beneath the outlet, Mr. West said, "the back and bottom of the refrigerator tend to be the coldest spots."
Shirley O. Corriher, a biochemist and cookbook writer, suggests shaking off all the surface moisture from produce and sealing it in heavy zip-top freezer bags before putting it in the crisper drawer or on a shelf.
"Oxygen is a major villain, so to speak, in the deterioration of fruits and vegetables," said Mrs. Corriher, the author of "BakeWise: The Hows and Whys of Successful Baking" (Scribner, 2008) and "CookWise: The Secrets of Cooking Revealed" (William Morrow Cookbooks, 1997).
Lettuce leaves, in particular, benefit from being sealed in plastic, she said, and you should roll the bag "until you squeeze all the air out. That lettuce will keep for three weeks. It's just amazing."
Still, Ms. Reek said, "the objective of food is to eat it."
"If it's fresher, it's going to have higher vitamin content and be healthier for you," she said. "So it's really better not to plan to store food for ever and ever."
Feb 16, 2015 | GE Refrigerators
I can set the temperature at the console in the fridge and it wont set? i can put it on 37 and it will get as cold as 28. I have to bump the freezer up to around 4 or 5 to somewhat maintain a temp of 36 in...
Your ice box uses thermistors to judge temp. The control board measures the resistances changes in these thermistors and acts accordingly. This video shows how to check:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 31, 2011 | GE Refrigerators
My GE Side by Side GSS25XSRSS keeps freezing up (bottom of each side only) with top portion of compartments much warmer (freezer side is too warm on top, all veggies are frozen on bottom of fridge side). ...
The evaporator fan is not working. You will have to open the front inside panels on the freezer side to get access to the fan, which is just below the ice maker. It may just require a little servicing, or the fan motor is bad or the controller at the back supplying electricity is bad.
Jan 10, 2011 | GE GSS25XSRSS 36" 25.4 Cu. Ft....
Gss25xsrd ss GE fridge gets warm on the top (both fridge and freezer side) and freezes at the bottom. Ice completely melts and veggies in the drawers freeze too.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 26, 2010 | Refrigerators
2002 GE sidebyside is freezing the lettuce/water froze in filter
Model # would be helpful, but most likely something going in with damper that controls airflow between freezer and fridge side. Also could be thermostat
Nov 07, 2017 | GE Profile PSW26P Stainless Steel Side by...
Why are my veggies freezing even thought the temp is set to 40?
Most fridges have crisper drawers that have a selection lever on either the front or side of the drawer that allows you to select eiher veggies or meat. Veggie setting is supposed to keep the crisper drawer warmer, while Meat setting makes it the coldest possible.
If you don't have the selector slide levers, I would suggest you use the highest possible crisper drawer available, as the lower in the frdge compartment you go, the colder the air will be. That should resolve the problem you're having, other than lowering the fridge temp setting slightly.
You might notice a cold air exchange vent next to your crisper, which supplies cold air from the freezer section into the fridge section, so that could be contributing to the colder temps in the crisper where you keep your veggies.
Hope you find this Very Helpful and best regards!
Aug 20, 2009 | Jenn-Air JBL2088H 20 Cu. Ft. Cabinet-Depth...
Refrigerator crisper drawers are freezing veggies
Shut the air flow into the crispers if you can. If not, turn the refrigerator temperature warmer by just a few degrees. The air into the fridge from the freezer is channeled into the crispers.
Jul 01, 2009 | GE PFS22SISSS Stainless Steel French Door...
GE Profile¿ Arctica® Energy Star® 25.5 Cu. Ft. Side-by-Side Refrigerator with Dispenser, PSS26MSRSS Logo
359 people viewed this question
Top Refrigerators Experts
Ron Rak
Ron Rak
gbob59
