It does light up but doesn't warm up even on number 9.
SOURCE: rangemaster leisure 110
Hi
Just to say we sorted the problem. Simply the bulb was out in the one oven. We replaced this and problem solved.
Carole
SOURCE: Rangemaster 110 oven heats by itself
That happens either because the timer control is faulty, or because there is a contact on the element wires or connectors, and the element is grounded.
Control board and wiring harness are tested using a multimeter.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Reading the user manual, it states that the flame initially comes on low, until it is "sensed" by the flame sensing device. This to me sounds suspiciously like the flame isn't being sensed and so never gets increased to the normal level.
I've not had time for a proper look at it.... but from a quick glance this morning this looked like a "flame rectifier" probe next to my burner (as we commonly use in boilers to sense if the gas burner is lit). This is just a metal probe. They send a high-ish AC voltage signal (Sine wave) from it, through the flame, to the earthed metal case. The flame acts like a diode (yes it really does work !) and simple electronics detects the change in the applied signal (rectified) due to the flame. I know from personal experience they (the probes) get coated with crud (carbon, etc) and need a good clean. I suggest you try cleaning both it and the metal area opposite it. If necessary the probes metal tip could be GENTLY rubbed with very fine Emmery cloth, etc, if badly coated.
Other than that, if it is sensing the flame, then it must be the gas control device (solenoid valve ?) that is jammed, blocked or just defective.
Simples......
SOURCE: Rangemaster 110 gas cooker - RH Oven lights but doesn't heat up
Its going to be the fsd gone if the burner lights all the way across, the type of control sparky is on about hasnt been used on domestic uk cookers for around 30-40 years., as its a gas passing part, unless you are gas competent you will have to call in a pro.
SOURCE: i have a leisure rangemaster 110 double gas oven
the flame safety device need replacing (FFD)... this lets the full gas through when flame is sensed... safety 1st as a gas engineer will be required..
