Question about Akai PT5492S 54" Rear Projection Television
Have a dark blotch on bottom right of screen. What is this? Transported in the rain and fear water got through carefully wrapped plastic. Help
After moving my Akai Projector TV today I now have a dark blotch, mark along the bottom right hand corner of screen. Did I bang it against something or get water down in it? Thanks for any feedback, love my mom's Akai!!! Cannot beat picture & especially sound!!
Posted by Bob Miller on
Steve LaHuis
  • 418 Answers
Possibly got water down corner of screen. Liquid will wick-up between the screens if this happens. Sometimes wicks 3-4 inches. The way to tell if its water is it will be visible with TV off with a flashlight.
Posted on Nov 02, 2014
Lawrence Oravetz
  • Akai Master
  • 10,548 Answers
It's possible the mirror has dome dust on it from jostling during the move. W dried water spot will do it too. The front screen will come off by removing the screws on the bezel. Be extremely careful cleaning the mirror.Any scratch by a cleaning cloth (never use paper) will permanently ruin it.
5 Related Answers
Anonymous
  • 152 Answers
SOURCE: akai 54 inch PT5492S projection tv
try to degauss the screen....
here is a a little guide on how to do it if your tv doesnt have the option
http://www.wikihow.com/Degauss-a-Computer-Monitor
Posted on Dec 29, 2007
Silverado1st
John
  • 8 Answers
SOURCE: Water stain on the front of our Akai PT5499 Projection TV
Hmm... should evaporate on its own. The only way to access behind the screen is to take the whole back off the TV, and then inside theres another panel that covers the main reflector and screen. I wouldnt recommend doing that just for water tho.
Posted on Jan 28, 2008
Slinteriors
Sonny Berry
  • 8617 Answers
SOURCE: Akai PT5492S 54" Rear Projection TV
Your set needs to have both Convergence ICs replaced they are Both STK392-010 you can get new ICs at the following link and they provide free step by step instructions with pics so you can do the job yourself which takes about 45 minutes. Heres the link.
http://servicemanuals.vstore.ca/
Posted on May 10, 2008
Anonymous
SOURCE: cash for broken 54'' akai rear projection
yes maybe i have one that i have barley ever use and after eight years it now have only a green and blue picture and i can't find anyone to fix this set because i live in Tyler, Texas.
Posted on May 12, 2008
Anonymous
SOURCE: Akai PT5492S 54 Projection TV
timer light is on but can not shut it off to get channels or menu and also turn it on [email protected]
Posted on Dec 15, 2008
I have a GE Profile, GSD4930X73WW, dishwasher. The upper wash arm is not spraying well at all. I checked the water line from the pump to the upper arm and it's fine. I cleared the filters and cleaned...
Most likely the cause would be a blocked screen entering the pump. There is a small "shredder" spring immediately in front of it which shreds soft food waste. Many times plastic wrap gets into the unit and will block the round holes in that screen, thereby reducing water supply to the pump. Low supply means loss of pressure and that means no water to top wash arm. Access is done by removing the large white coarse filter, located behind the lower wash arm, lifting the oval plastic screen just below that and reaching in to the bottom reservoir. BE CAREFUL OF GLASS AND OTHER SHARPS! Gently clean out that area and feel for the final round screen that leads to the pump. This is the one that gets blocked with debris. Some can be "scrubbed" with an old toothbrush, but if there is plastic wrap in it, you will have to scrape it with fingernails and pick it out. Another, more time consuming way, is to remove the entire motor pump assembly and dismantle it.
Good luck. Let us know if it helped.
Apr 13, 2017 | GE Dishwashers
Remove protective film wrap from under water dispenser faceplate
I have this same model and was facing the same issue. I even emailed Whirlpool but that didn't help.
You can remove the faceplate by removing the spill tray and unscrewing the two small screws in the bottom. Be careful not to scratch the finish while removing the screws.
The faceplate is held on by several plastic hooks around all edges. Carefully grip the bottom of the faceplate (I put my thumbs on the inside where the spill tray was and my index finger below the bottom front of the faceplate). Get a good grip by pinching the faceplate and pull down and out to remove the bottom. Then push the faceplate up to unhinge the top.
You can let the faceplate hang by the wires while you remove the plastic. I'd also use a stainless steel cleaner while the faceplate is off to get rid of any fingerprints you may have left behind.
To reinstall, hang the faceplate on the top 3 hooks making sure there is a snug fit. Then pull down on the bottom and push it in. It took me two tries to get it back on.
The plastic is stronger than it looks but you'll still have to go slow and be careful with it. Good luck!
Sep 09, 2009 | Whirlpool Refrigerators
Screen water damage
Please do't do anything. Just let it dry completely, preferably in the sun. Do'nt switch it on before it is dry.
Oct 17, 2017 | Sony KP-51WS500 51" Rear Projection...
Black blotch on bottom of screen
if you can take the screen out , then use some dish soap,rag and water to clean the black blotch
if that don't work you may need to use something a little stronger , but not enough to hurt the screen
please rate a fixya and I'll be happy to assist you in the cleaning process and care of the screen
Nov 07, 2008 | Toshiba 62HMX84 62" Rear Projection HDTV
Dark Blotches
This is probably caused by dust, either on the mirror, lens, or possibly inside the light engine. There is a 5" dia hole on the side of the back of the tv where you can take out one screw and take the door off. this is just big enough for you to put your hand through to clean the mirror and lens. Hope this helps.
Mar 30, 2008 | JVC HD-61FN97 61" Television
Dark Blotch on rear projection TV screen
usually these are caused by cleaning the screen with a damp cloth or fkuid rear projection tv's usually have two plastic screens separated by about quarter inch with bulbs between,one being a magnified screen.problem is,condensation can occur causing various blotches,letting the screens naturly dry out usually solves this but failing this you have to strip down and wipe them with clean dry cloth.be careful though the inside screen is very delicate.
Feb 21, 2008 | Televison & Video
Dark blotches / Dirty behind screen
it could be dust in the mirror or in the optics,in this set if im not mistaken you have acces to the mirror from the back, anywhere from 12-20 screws it sould be easy to remove plastic cover first and the the mirror.this mirror are very delicate you dont want to leave fingr prints on it it will show just like the dust is showing right know. taking the mirror off will also give acces to the lense.
use someting soft to clean it.
hdtvman.
Dec 28, 2007 | Mitsubishi WD-62528 62 in. LCD Television
Dark blotches behind the screen
When I had this problem with my 52525 I cleaned the bulb with a lint free cloth. The dark blotches went away.
Dec 28, 2007 | Mitsubishi WD-62525 62" Rear Projection...
Dim picture from one broken lamp??
The red CRT is most likely not the culprit. If water got on to any of the boards such as the red CRT driver board it could damage it wich also at the same time can load down voltages (200 volts etc) that can have a global affect on the other CRT's. Changing any on the CRT's by the average consumer is NOT recommended because you are dealing with a device that requires 30 KV (thats thirty thousand) volts to make it light up. Take these as warnings and consult with a technician.
Dec 08, 2007 | Toshiba 65H84 65" Rear Projection HDTV
Akai PT5492S 54" Rear Projection Television Logo
145 people viewed this question
Top Akai Televison & Video Experts
Marvin
Marvin
matt martin
matt martin
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
