Question about Sony KP-46WT510 46" Rear Projection HDTV
Convergence problem Having convergence problems with green color totally out of alignment. Seems like ghost images. Tried resetting convergence manually using TV manual by aligning each + symbols. But the green color is totally off and cannot be aligned. Is there any manual controls to fix the convergence? Or, this has to go to a repair shop?
Posted by HNDAG on
  • 1 more comment
  • Anonymous Nov 13, 2007
    I have the same problem with the blue color... any help?
  • Anonymous Nov 16, 2007
    I also got the same problem today with my KP-46WT510 after 4 year.
    Having convergence problem (Blue, Green and Red colors are off) and
    also having curve on the image and the captions.
    Any help?
    Thanks
  • Anonymous Nov 27, 2007
    I am having the same problem as well, Mine stareted this week. I have only had 3 years.
    Price of unit a little much to already be having a problem.... Oh well the TV's of yesterday are gone.. would last 15 years or longer
cyriacus joseph
    Sergeant:
    Champion:
  • 346 Answers
Replace the ics
Posted on Nov 24, 2007
Ghost image in red and alot of red color. This occurs all the time. I have tried magic focus and manuel focus. No change
The tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?This tv have a dead convergence board.The tv convergence board must require replacing 2 STK convergence ICS and some or all of it resistors too.Fixing the tv convergence board,will solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Feb 09, 2011 | Hitachi 51F500 51" Rear Projection...
Magnavox Rear Projection 51MP392H/17 has ghosting issue ..red/green double hallow. TV is six (6) years old. any idea what's wrong?
If this happened suddenly and the red and green images are bowed in at the center of the top, bottom and both sides, one of the convergence amplifier IC's has failed. The part number is STK392-120. Make sure it is a genuine Sanyo brand replacement; there are a number of cheap imitations out there that do not last. Generally they cost less than $30 each.
Note: there are two of these in each TV. They are notorious for having a high failure rate, so I usually replace both. (FYI: each chip has three amplifiers. Each color gets two amplifiers, so one color uses an amplifier on each chip. That's why we usually see at least two colors go out of whack when this problem happens.)
I assume you have already tried a different video source (DVD, VCR, etc.) to rule out input signal defects. If the problem arose right after the set was moved, either the optical alignment was disturbed or (less likely) there is a stray magnetic field near the set that is causing problems (magnetron from a microwave oven?). There is a procedure (sometimes provided in the owner's manual) for adjusting convergence using the remote control that can fix minor alignment problems. If you want to gamble it is not a hardware failure, try it first along one edge of the picture.
If you cannot shift the red or green dots in the convergence pattern, stop immediately, and make a note of where and in what direction you tried to move the dots. Inability to converge the dots is a strong indication the convergence amplifiers are bad (that is their job - to keep the colors lined up with each other). You will need to undo any adjustment attempts after you replace the convergence chips and any fuses or resistors that got burned when they went out, so don't make too much extra work for yourself or your service tech.
Oct 27, 2010 | Philips Magnavox 51MP392H Rear Projection...
Our tv just started having a fuzzy image and the auto focus function aborts during the red color alignment. is there a manual alignment I can do to fix it.
What does this fuzzy image look like? Does it have ghosting shadows. Of course it is possible to align red manually from the convergence menu. But first lets confirm that it is indeed a convergence related problem.
Aug 18, 2010 | Samsung HCL552W 55" Rear Projection...
Tv out of foucs
These procedures are from the owners manual, go into menu and then picture quality and then: Convergence The Convergence feature lets you adjust the TV’s three tubes. When the TV tubes’ images are precisely aligned, they create the color images you see on the screen. Over time, the picture can drift out of alignment (this is normal). If your picture seems fuzzy or has a yellow tint, using Convergence could correct this misalignment. Only one convergence is needed for all inputs, regardless of the signal format. Note: Make sure the TV has been on for at least 30 minutes (TV needs to warm up for best results) before starting Auto Converge or Red/Blue Centering. When you select the Convergence feature, a submenu appears with three options: Auto Converge Automatically aligns the projection lenses to self-correct color images. You’ll see flashing squares of color dance across the screen (this is normal). Note: After performing auto convergence, use the Blue Centering and Red Centering menus to fine tune convergence in the center of the screen, if necessary. Blue Centering Aligns the blue and green images to fine-tune the picture. Red Centering Aligns the red and green images to fine-tune the picture. Note: The ability to change channels is disabled when adjusting the convergence options. The TV must be tuned to a usable signal to converge the picture.
Apr 23, 2010 | RCA HD52W58 52" TV
65" rear pro. Convergence IC Repair
This is a common problem. Its called a convergence failure.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 18, 2010 | Mitsubishi WS-65809 65" Rear Projection...
Convergence problem I fixed AND made worse
Count the # of flashes...call Samsung tech support
Nov 10, 2009 | Samsung PCL5415RB 54" Rear Projection...
Sony projection TV colors out of alignment
Solution:
You have a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed in but stationary.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
>>>Solution<<<<
You need to replace the convergence chips and convergence resistors.
Check the site www.TvRepairKits.com.
They have put together a kit for your exact model. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself.
Feb 02, 2009 | Sony KP-51WS510 51" Rear Projection...
Color ghosting or shadows
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 19, 2009 | Pioneer SD-532HD5 53" Rear Projection...
Ghosting - colored shadows - guns out of alignment?
*Screen Looks 3-D
*Colors wont align
Problem #2
Nov 08, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Samsung parts for convergance problem
http://www.partstore.com/Part/Samsung/Samsung/BP9500142E/New.aspx
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 29, 2008 | Samsung HCM5525W 55" Rear Projection...
Sony KP-46WT510 46" Rear Projection HDTV Logo
215 people viewed this question
Top Sony Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
