Question about Acu-Rite Acurite Wireless Weather Thermometer 604
Acurite wireless weather will not work new last season all new lithium batteries in right and were checked no picture #'s on screen
Posted by jerry vaughn on
AcuRite
    New Friend:
  • 20 Answers
Hi Jerry,
While lithium batteries are recommended for the outdoor sensor it is not recommended they be used in the indoor display unit. Try using a good quality, fresh alkaline batteries and you should find your display turns back on.
Posted on Nov 07, 2014
1helpful
2answers
Why can't I receive input from the outside sending unit?
Make sure that all the batteries are good!!
This procedure outlines the typical process to pair the sensor and base.
Base Station Battery Installation
·Remove the printed vinyl label from the LCD screen of the base station
·Position the remote sensor near the base station
·Open the battery compartment at the back of the base station and insert (2) AA batteries according to the polarity markings. Replace the battery compartment cover.
·Within a short time the RF signal icon (located to the left of the outdoor temperature channel indicator) will start flashing. This indicates that the base station is ready to pick up the RF outdoor temperature signal from the remote sensor. It will continue to flash for 3 minutes or until the signal from the remote sensor is detected.
Register the Remote Sensor
·Open the battery compartment at the back of the remote sensor and slide the channel selector switch to your desired channel. For the first remote you may select any channel, for additional remotes select any unused channel
·Insert (2) AAA batteries according to the polarity markings. Be sure to install the batteries in the remote within the time that the RF signal icon is flashing on the base station. 1541 WeatherGuide Wireless Weather Forecaster with Barometer
2helpful
My acurite model75321a1 does not tell out side temperature
We would recommend a reset of your Weather Station. Please verify that you are using a good-quality, standard alkaline battery, and follow the steps below.
  1. Remove the batteries from the outdoor sensor only.
  2. In the outdoor section on the main unit, there will be a "CH" and number 1-3.
  3. If on CH 1, press and hold the channel button on the back of the unit for 5 seconds.
  4. Press and release the channel button one time, it should show CH 2.
    • If it does not change to CH 2, repeat steps 4 and 5.
  5. Press and hold the channel button for 5 seconds.
  6. Press and release the channel button one time, it should show CH 3.
    • If it does not change to CH 3, repeat steps 6 and 7.
  7. Press and hold the channel button for 5 seconds.
  8. Press and release the channel button one time, it should return to CH 1.
    • If it does not change to CH 1, repeat steps 8 and 9.
    ***Regardless of what channel you begin on, clear out each channel by holding the channel button and return to CH 1***
  9. Reinstall batteries in the outdoor sensor.
  10. Press and release the TX button.
  11. Leave both units side by side for up to 30 minutes to gain a strong connection.
If you need any further assistance, please contact AcuRite Customer Support at 1-877-221-1252 or [email protected]
3helpful
My acu-rite wireless thermometer model #00604RX isn't capturing the wireless sensor signal..both have new batteries and worked before changing old battery..reset the buttons too...help
Double check the batteries and the direction in which they are installed. If there is one backwards in the sending unit that is outside, it will not send a signal. Also, there is typically one battery in the indoor unit that is responsible for receiving the signal from the outdoor unit. If all of the batteries are in correctly except that battery, you will see the display, but will not get the data transmitted from the outside sending unit.
1helpful
2answers
My AcuRite 00992 wireless weather station has suddenly quite displaying the outside humidity and dew point. Batteries are all new. I have lost my manual to troubleshoot this problem.
Double check the batteries to make sure they are installed correctly. If one of the batteries in the outdoor sending unit is in backwards, it will not send the outdoor data. On the indoor unit, there is typically one battery that is used for receiving the signal from the outdoor unit. If all of the batteries are in correctly but that one, you will see the display and the indoor temperature information, but the outdoor information will not be displayed.
Acu-Rite Acurite Wireless Weather Thermometer 604 Logo
Top Acu-Rite Measuring Tools & Sensors Experts
ray gallant
Damon Nesselrodt
Damon Nesselrodt
Are you an Acu-Rite Measuring Tool and Sensor Expert? Answer questions, earn points and help others
